My oil consumption is steadily getting worse. All the reading that I have done indicates that it is the PCV's rubber flap that gets old and starts letting oil by under hard vacuum. Every bit of evidence points this direction. When I drive stop and go traffic, I can burn through a Qt in 200-300 miles.
If I am on the highway or driving hard (boost), It will last twice as long. Exhaust tips get black very quick, but it's hard to notice oil burning from the pipes, so it's low enough that it doesn't look like blown rings.
Anyhow... I've spent a good deal of time looking for the part and found this as the latest version: 06E103547AC ECStuning indicates that this one does not fit our cars, but they've got it wrong on this part. Doing some more searching, I found a part that seems to be JUST the orange rubber valve. This is the actual part that gets worn out so I am going to replace it first. $26 ($18 + $8 shipping) is a hell of a lot better than $100-150. I'm thinking that the rest is hard plastic and will hold up if not cracked. And from being in there the last time for the waterpump, I'm fairly certain this will work.
https://www.ebay.com/itm/The-membran...n/222324858386
With the funds that I save from not buying the full unit, I'll go ahead and replace the intake gaskets that I passed up on last time as well as buy medium for blasting the ports.
What do you guys think? Will that part do the trick?
