Results 1 to 6 of 6
    Active Member One Ring B1polarb3ar's Avatar
    Jan 30 2017
    California
    Disable Allroad Air compressor?
    Hey all, I recently bought a manual 2.7t Allroad and just finished installing coilovers (i know, blasphemy or whatever). The only problem is that the compressor likes to randomly turn on and try to pump up the suspension that's no longer there. I've been searching for threads on how to disable it but all I was able to find is that the relay is in the trunk somewhere. If somebody could give me some advice or link me to a thread that would be appreciated!
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    there should be a fuse in the main panel that you could pull, i think
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Unplug it.
    Feb 07 2008
    The boonies, near Seattle
    Unplug the computer in the driver rear quarter panel. It's kind of a pain, but you can get it by just removing the door and getting creative.
    If not, there's a fuse under the dash that runs the compressor. It's either a big 30 amp of 40 amp. I don't remember.
    -dre
    Jan 30 2017
    California
    Thanks! I found a fuse diagram and you're definitely right, i must have been looking at the wrong fuse box :P
    Apr 29 2009
    Quadzilla
    Longmont, CO
    if the compressor isnt too old, you could always pull it and send it to me
    that would shut it off for good
    Rockin' the Rockies
