Results 1 to 40 of 44
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    Big Turbo RS7 vs Big Turbo RS3 IrozMotorsports
    Little drag race/rollrace between Sean West's @ SillyRabbitMotorsport in development Big Turbo DBB Garrett RS7 on100oct and our in development Big Turbo RS3 with Hank @ Iroz Motorsport's Xona Rotor Turbo kit on E85.
    Both cars have a ton left in them, excited to
    See what the future holds for both cars.
    https://youtu.be/M02uPbhPtXw
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
    Veteran Member Four Rings HBird's Avatar
    Jul 18 2015
    2019 Ranger, 2023 4Runner
    Snohomish, WA
    fak
    - Hunter
    I got me a Ferd now
    Oct 02 2017
    Rs7 whp?
    May 08 2015
    uu
    Quote Originally Posted by OE2 View Post
    Rs7 whp?
    +1
    Apr 07 2011
    Home of the mighty beaver
    Rs7 made 621whp on 23psi and a mild 91 octane timing map. To say there is power left on the table is an understatement! Im watching these carefully because i see an s8 in my future... :)
    Apr 07 2017
    Baltimore, MD
    Crazy!
    2019 S5 Sportback Prestige
    (SOLD) 2018 RS3 - Daytona Gray Pearl w/ Alu-optics (Tech,Driver-Assist,Dynamic)
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    Coming from the 4.0tt community, we all know that Apr has the quickest and fastest tune for the 4.0tt their stage 1 cars have run 10.3's and stage 2 cars are close to 10.0.
    The upgrading of a turbo is just adding heat to an already over worked charge cooler, I am not referring to the radiator portion but the actual charge cooler, unless that guy was running meth he was heat soaked after the first hit.
    As for a roll race, we all know the rs7 is a terrible roll race car and that the 8spd zf is geared for dig racing more so than roll.
    I think your rs3 is stupid fast and probably the fastest out there right now, but I do think that particular rs7 is not the fastest.
    Personally I think you should come to wpb for the Audi versus the world event that is going to happen at pbir at the end of the month so we can see an iroz car run what it can at sea level in Florida.
    Sent from my SM-N950U using Tapatalk
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Mar 26 2007
    Colorado
    Quote Originally Posted by sciblades View Post
    I agree that a basic APR stage 2 RS7 would probably roll with this Big Turbo one. Only thing I am impressed with here is the RS3
    CURRENT:
    2021 Atlas
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    My eyebrows raised when I saw the races(dig and roll). the videos that I seen on the internet put the RS7s with stage 1 or 2 in the 10s easily and traps of low 130s so with that been said I was expecting the big turbos to put insane power on the RS7. Some of the points brought in about the overheating makes sense but you would think a person that spends $130k on s RS7 and another $15000 on a bigger twin turbo set up would figure the tune out.
    The drag strip will tell who is who.
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Never mind the RS7....George needs to roll with that supercharged R8!!
    REVENGE!!
    Jan 09 2018
    Rancho Murieta, CA
    I don’t know much about the RS7... but I’m pretty sure they run a “hot V” turbo setup where the cylinder heads are reversed and the turbos sit in between the heads. I’m betting that “big turbo” on an RS7 is pretty limited due to packaging constraints. Also, that arrangement, while good for turbo spool and response, can be very challenging to keep cool.
    2018 Audi RS3 - Daytona Gray w/Aluminum Optics, Dynamic & Tech
    - Signature Wheel SV104’s in brushed black tint
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Dang,
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    May 08 2015
    uu
    Quote Originally Posted by S4James View Post
    in the race the rs7 on 100oct fuel, so much more than 620whp
    Jan 07 2018
    So CA
    George, I presume you got a TCU tune with the turbo install. Still getting any torque limiter intervention at peak torque or during shifting?
    Oct 24 2008
    Quote Originally Posted by jiannu View Post
    REVENGE!!
    Yessir, hopefully he’s there Saturday night
    Had some fun today
    https://youtu.be/LmdRTATzktc
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by NYEuroTuner View Post
    Had some fun today
    Sounds like it's slipping the clutch a ton when it tries to clamp down in 2nd and/or 3rd
    Aug 29 2017
    Tucson, AZ
    ^^^^ +1. I noticed the same thing.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Apr 27 2004
    San Diego
    So are you running full E85? Any changes to the fueling system to support the turbo?
    Oct 24 2008
    Quote Originally Posted by TeKiZeRo View Post
    Yes and yes.
    Full brushless pump upgrade, bigger injectors and now running full e85 with ethanol content sensor from innovate
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Oct 24 2008
    Quote Originally Posted by S3DUDE View Post
    It’s struggling as I’m running prototype trans software, and working towards perfection.
    But so far so good and the car boogies. I’ll definitely report any changes or updates
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Oct 24 2008
    Quote Originally Posted by Xtyper View Post
    Yes and yes.
    Slightly TQ limiter intervention to ensure engine is safe, but hauls ass for sure.
    Brother you coming Saturday night for rollracing ?
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Active Member Two Rings Emokeff's Avatar
    May 03 2017
    Hampton Roads VA
    Had some fun today
    This video makes my RS3 sound like an A3 lol. One of the best sounding cars out there IMO.
    I wait for new videos more than my favorite TV series lol.
    Mar 23 2016
    Ontario,Canada
    To me it sounds like the trans is bouncing off the rev limiter and not changing fast enough.... did Hank suggest upgrading the clutch packs on the dsg?
    I am sure if you get that sorted out, your times will improve.. and drop into sub 3 seconds for 0-60Mph.
    Sent from my SM-N950U1 using Tapatalk
    Apr 27 2004
    San Diego
    Yes and yes.
    Awesome! Is it pretty much the same setup as what Hank did for his ~141mph run?
    Oct 24 2008
    Quote Originally Posted by Emokeff View Post
    Wow, that truly means a ton man, thank you so much for the kind words ❤️
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Oct 24 2008
    Technically we’re making more, he was at 650whp, we’re at 668whp.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Oct 24 2008
    Yea really it’s the engine ecu, TQ limiting. Capping wtq to 500-520.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Hey George, I've been following your progress now for a few weeks. Keep up the great entertainment! I've thoroughly enjoyed watching all the videos. Later this summer, I'm moving back to SoCal and look forward to seeing your beast in person. BTW, ex-devil dog are ya?
    Youtube: The Automotive Fanatic
    Apr 27 2004
    San Diego
    That is amazing! What a beast your car is lol. Can't wait to see the roll race videos!
    Oct 24 2008
    Quote Originally Posted by zcspec View Post
    Yessir, got out in 2015, let me know when you get to SoCal we’ll link up for sure.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Oct 24 2008
    Thank you, excited for Saturday too lol
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Aug 29 2017
    Tucson, AZ
    So what is the deal with the DSG? it sounds in the videos like the clutch packs are fried. Does IROZ have a back up plan? We are all like WOW!!... that is tons of power but now comes the reliability part. Kudos to you for documenting everything on video and for taking the risks.
    at 3100ft elevation
    Oct 24 2008
    I mean I’m driving the car everyday, and wanted to drive her for atleast a week or two and compete in some events and then plan on doing a full review.
    To date I have not had any slipping or issues. Car accelerates like an animal and trans is holding up. We’ll see how she does Saturday night at the Roll Racing event.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Aug 29 2017
    Tucson, AZ
    ^^ I take your word. Long life to the RS3 DSG then.
    at 3100ft elevation
    Active Member One Ring Flsupraguy's Avatar
    Feb 22 2018
    FL
    Because of you I now have to buy a RS3 and also do a turbo upgrade.
    Thanks a lot......
    BTW, love your youtube channel. Post some more vids!
    If you ever come to Florida hit me up and I'll take you for a spin in my turbo R8.
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    Quote Originally Posted by vdubjetta02 View Post
    Quote Originally Posted by iceman302 View Post
    Nice to see I wasn't the only one questioning the whole Big Turbo Rs7 reality / power out put, I mean hell there are stock turbo'd just tunes and exhaust rs7's that are quicker. Regardless of what that or another rs7 can do we look forward in seeing more from your RS3. Go kick some but at the roll races.
    Oct 24 2008
    Quote Originally Posted by Flsupraguy View Post
    Thanks a lot......
    Be there in a few months, will definitely look you up, would be great to feature your car on our channel.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Oct 24 2008
    Quote Originally Posted by brad65ford View Post
    Thanks man, we knew the RS7 video would cause controversy, with both cars being built up and developed believe me it’s not going to be the last time you see that RS7. Big plans from SRM with that car.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    APR is putting the exact same turbos from Sean at SRM on my RS7 right now and tuning. There are some limiting factors beyond cooling impacting my car’s ability to use all those turbos have to give. The inlets between the intake and the turbos are a big one. There will be incremental progress before those hybrid turbos show us all they can deliver.
    Veteran Member Three Rings javbomb's Avatar
    May 11 2013
    Sydney
    Sooooo.... how did the roll racing go?
    C7.5 S6 | Black | Stage II IE ECU/TCU
