Results 1 to 8 of 8
    Apr 13 2014
    Puerto Banus
    Facelift instrument Cluster
    Hi there,
    I have a 2008 C6, pre ''facelift''. I wonder if the facelift instrument cluster with the needle sweep is plug and play? What is involved to get it working?
    08 RS6 Avant - Black / Black - 780 MTM
    Ferrari F430 F1 Spider
    Ferrari 360 Modena (manual)
    + 5 classic Porsches.
    (ex Audis: 95' RS2 - 93' S4 - 96' S6 - 99' S4 - 00' tt225q)
    Senior Member Three Rings Kriskrk's Avatar
    Oct 19 2017
    London
    Needle sweep can be activated with vcds or Carista on majority platforms.
    Not sure if you need FL cluster for it.
    If you want DIS upgrade, than yes, you need cluster upgrade.
    Might as well do the mmi 3G/3G+ upgrade with it
    Audi A6 C6 4F 170 Sline 2.0 Avant LeMans in Grey
    Stage 1 remap with EGR off and DPF gutted, partly dechromed with blacked out RS honeycomb grille, standard 19" LeMans RS4 type wheels (deu to change), full led interior, upgraded Osram CBI bulbs, fog's power led's with heat sinks.
    More to come
    Apr 13 2014
    Puerto Banus
    Needle sweep can not be done on my 08' pre' facelift.
    What is DIS upgrade?
    What is needed for the MMI 3G upgrade?
    Oct 19 2017
    London
    Sorry mate. Wasn’t sure exactly but thought it wouldn’t be a problem.
    DIS - Driver Information System.
    That small display between speedo and rev counter on instrument cluster.
    For sure screen and main mmi module is needed for the upgrade but I’m no expert here
    More to come
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by 993turbo View Post
    my old 2005 4.2 A6 was able to do needle sweep.
    '09 C6.5 A6
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    Interesting sin, from the research the pre-facelift models couldn't have that feature. I have Carista app, and it's not an option for me.
    Also, the little screen between mph and tach, our prefacelifts have that. Surely it's not an option?
    Mine shows all sorts of info. From Vehicle, to Navigation when activated, MMI controls etc...
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Apr 13 2014
    Puerto Banus
    Yes, my MMI 2G High has the screen between the clocks. In fact it looks identical to the Facelift version. But when I check in my VCDS (Full version) Needle sweep is not an option. I have bought a facelift instrument cluster, with needle sweep. I wonder what it takes to make it work. Are the pin-outs the same? I know the plug is the same?
    Cheers
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by JPJ2007 View Post
    I went to the Ross-tech wiki page for the pre-facelift cars and there is no coding listed. Unless I have had Stormy for so long or my advanced age is hindering my memory, I could have sworn my 05 swept.
    '09 C6.5 A6
