You never actually specified whether or not you had heat prior to replacing the radiator or any certain time frame before that.
So did you?
As I’m sure you know at this point, it’s very common for the heater core to become clogged on the b6/b7. And based on everything else you’ve noted I’d be looking here.
Sure you can try flushing it, but you will never get it completely clean. The passageways are far to small, and all you’ll do is buy time if it works at all.
I’ve replaced over half a dozen cores and the best thing to do is just install a new one and not have to worry about it again.
As far as the bleeding goes I can guarantee you if the cooling system is working properly you will never have to touch the bleed hose or any other bleed screw (engine depending).
All you need to do is add coolant, drive the car, and heat should return within minutes. Air will get trapped in the reservoir, and once the car has cooled you remove the cap, air is released, and you top off fluid as necessary. It’s really quite simply, and no need for all the special bleeding bs.
That’s my experience servicing probably two dozen Audi’s from b6-b8. Where I have completely drained coolant for repairs similar to yours.
Whether I use a vacuum tool or simply pour in coolant result is the same.
Sent from my iPhone using
Audizine
