Results 1 to 3 of 3
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Plastic vs Metal Intake Manifold
    Okay, maybe I'm a bit late to the game here, but what's the deal with some of the 2.0T engines having plastic intake manifolds and some having metal? Is one better than the other? Pros and cons of each? Why the switch in the first place?
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    I don't know about on the 2.0T's, but, they did something similar with the 4.2L V8 S5. With the 4.2L, I believe they made a change for a few reasons. The first being weight, it weights a fair bit less. Second, being a slightly better flow pattern, for probably a minute performance bump. Realistically, you'd never notice. Third, I believe the plastic intake manifold doesn't get heat-soaked as bad as the metal one, so, you don't feel as much power loss after consecutive hard pulls. And fourth, lastly, with the 4.2L V8's, they changed from an electrical valve actuator, with motors, to a vacuum fed system. I think this saved some weight and increased reliability of the intake tract runners a bit. I believe the solenoids on the metal intakes tend to burn out a fair bit. My guess is it's something similar for the 2.0's.
    Feb 15 2016
    Cambridge,Ontario
    And dont forget.... follow the money. Which do you think are cheaper to pump out
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
