Results 1 to 7 of 7
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    Chinese Clone: BDM100 vs Kess V2 vs Galleto V54
    I'm looking to get into this. I got my spare ECU and rack set up.
    I'm trying to read ECUs and write. Basic stuff. Mostly trying to learn
    Which one would be the most reliable Chinese knockoff you think?
    *Edit: Misspelled Galletto. It's actually Galletto V54*
    Sent from my ONEPLUS A5000 using Audizine mobile app
    Last edited by StatusQuo; 02-15-2018 at 03:27 PM. Reason: Misspelled Galletto. It's actually Galletto V54
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Active Member One Ring quattroranger's Avatar
    Feb 17 2014
    Land Rover LR3, Fiat 500L
    Cameron, NC
    I'm looking into the same. It's hard finding reliable info. Hopefully someone has some experience to share...
    2007 Audi A4 Quattro, 6 Spd, Silver w/ Black Leather 220K+ and running strong
    Keep 'em Running
    RLTW!!
    SCTW!!
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I’ve been working w BDM100, but I’m having a computer built to continue. I’m going to use windows XP as most of the info I’ve found says it’s easier to work from the older software.
    I’d suggest building a bench flasher from an old Ecu harness. The most issues I’ve had is getting the 100% connection on the plastic frame most of the BDM kits provide.
    Dec 23 2011
    I could never get my bdm100 to connect successfully. Would be interested to see if anything has changed or if ppl are successful with it.
    Jun 15 2016
    Northern California
    I got the BDM100 in the mail today and I tried to set it up and I couldn't make it work. I consider myself to be computer literate.
    I tried running it on Windows XP VM install and the box does get recognized and even flips the power relay but it's still unable to read the ECM. It just freezes when I turn on the 12v power. And it eventually errors out saying it's an unrecognised ECU. I tried to also update the firmware on it as well. No success.
    I've been reading online that the V54 is the best bet of you want to get a Chinese one and the Kess V2 and Dimsport are the best if you want to go legit.
    I'm shooting offers on eBay right now for a V54.
    Jun 15 2016
    Northern California
    Quote Originally Posted by canadianA4B7 View Post
    Have you started your computer build yet? Check out the new Ryzen APUs. Lots of performance for not alot of money for a CPU.
    Feb 10 2012
    parts
    Napanee, ON
    I’m going w a complete older setup w XP. Virtual box was a fail, as well as a few other virtual drive types of software. Something to do with the newer USB recognition types of data. From what I’ve read was that running off an older complete XP that does the software recognition when plugged in was the easiest way to get it to fully read and load the correct data for the bdm100 software. I used to do quite a bit of programming myself. But that was many moons ago. Mine was doing the same a few odd things you can try is to try and depress the board while it’s starting to see the bdm box, I had quite a lot of reads done doing this, other things to try is to remove your virtual box and re load it, cycle the pc off after removing them restart after reloading the virtual ware. I’ve also noticed a shorter USB cable to work better then the one provided. That or take the cable and make a number of loops in it to shorten it tape it like that and see if it works. I’ve heard others adding a small bulb to the 12V on the bdm frame pin board which seems to help when it powers up to add a bit more resistance.
