Results 1 to 6 of 6
    Aug 02 2010
    Calgary
    Rubber vs Plastic CV Boot.
    My 2001 A4 1.8T Quatro came with rubber cv boots. I just got a part from the dealer (4A0-498-203-C front outer boot) and it is made of plastic. Does anyone have an opinion on rubber vs plastic?
    Thanks.
    Jan 25 2016
    Must be a soft plastic that changes shape easily.
    I would have thought rubber was better but generally from the dealer is best, right?
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    its fine i run them. you can get them for $16 under the REIN brand from rock auto. They just have the audi logos grinded off.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 30 2009
    Miami, FL
    Pretty much every manufacturer switched to plastic boots. They last longer but are more of a pain to install. Just get a quality pair of crimping pliers because they use steel crimp rings instead of aluminum, and they require a whoole lot more force.
    2018 S5 Coupe - stock for now
    Apr 02 2013
    above top secret
    Quote Originally Posted by Mad Cow View Post
    Those clamps are b**tch to crimp. No breaker bar is enough for the crimp plier. I ended up using the help of a spring compressor.
    Oct 09 2012
    Stupid hard to clamp those ******s. Ruined my cv cause it wasn’t tight enough. Lol. If it’s clicking best to not continue running it and drifting for a week. Running a hose clamp since I refilled it. Clicks pretty good in turns now.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
