Results 1 to 10 of 10
    Junior Member One Ring
    Aug 12 2017
    Senoia, GA
    2014 Audi A4 HID Headlight, What is OEM Bulb?
    Which bulb is the OEM bulb on my 2014 A4 Premium Line A4? Google returns all sorts of crap trying to sell me this, that, or the other thing. Youtube will show me how to swap it out, I am sure, but I wanted to put OEM back in there.
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    D3s 4300k is OEM
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Jan 03 2013
    Baltimore
    Quote Originally Posted by Junkyard Dog View Post
    They are really easy to swap. Pull each headlight housing off (4 bolts ea), unplug the harness and remove the bulb. 15 minute job.
    Aug 12 2017
    Senoia, GA
    Ok, I ordered Wagner, which RockAuto states is the OEM.
    Oct 26 2017
    San Francisco
    You may want to check if it is the ballast or bulb. Usually the bulbs outlast the ballast.
    2014 Audi A4 Quattro - S Line, Sport package - GIAC Stage 1 v2 E85 tune, Endless MX-72
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by Tiggy View Post
    D3s 4300k is OEM
    Phillips bulbs.
    Aug 12 2017
    Senoia, GA
    on the 2014, driver's side, is it necessary to pull the headlight housing out? It looks like there is enough room to just reach in there and swap it out. This guy does it without removing the driver's side housing. https://www.youtube.com/watch?v=xLMN1pIpku8
    - - - Updated - - -
    Quote Originally Posted by z k View Post
    Ah! I will have to research how to do that. The passenger side went out in October, and it was the headlight. Now it is the driver side.
    Jun 07 2016
    Portland, Oregon
    I have a set of OEM phillips bulbs forsale. PM if interested
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    - - - Updated - - -
    I swapped bulbs about half a year ago. If I remember correctly, I did both without removing the housings.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Aug 12 2017
    Senoia, GA
    Thanks for all the input, guys. That has to be the easiest headlight bulb swap ever. I did not remove the housing. I just reached in there, pulled out the cover, twisted the old bulb slightly, and removed it. I then unplugged it and plugged the new on onto the socket. Then I inserted the new bulb and slightly twisted it to lock it in place.
    I was done in less than two minutes.
    Very easy.
    The bulb is Wagner, but I noticed the box said Osram on the bottom (Wagner on the side) and Made in Germany. Rock Auto says this is the OEM bulb, and RockAuto.com has been pretty accurate in the past about identifying OEM.
    Anyway, thanks for all of the help.
