Results 1 to 8 of 8
    Jul 23 2009
    Northern Virginia
    Exhaust sounds through interior speakers?
    Hi all,
    I've searched here on the forum and on Google... I can't find anything that says one way or the other if the S5 Sportback has that little 'feature' where they pump some exhaust sounds in through the interior speakers? I know Audi has done it on some models in the past, but I don't know if it's even still a thing... Thanks for the input, and sorry if it's already been gone over somewhere else...
    - j
    Jan 29 2018
    Manalapan, NJ
    I thought I read somewhere that it does it through the front glass actually. It can be turned off with something like obdeleven afaik I've read.
    Sent from my SM-N950U using Tapatalk
    May 26 2007
    UK
    So to clear this up for future members asking the same question:
    The system on the S5 uses both the valves exhausts which generates some of the sound, and something called a 'Structure Borne Sound Actuator' which is a resonator that is fitted on the engine bulkhead. It does NOT rely on any part of the MMI/Audio system.
    The bulkhead based unit generates the engine vibration type noise and the exhaust the exhaust noise.
    You can easily switch off the soundaktor via OBD11 and, to my ears, it sounds an awful lot better.
    Also seems to get rid of the 2k rpm drone when cruising.
    Sent from my ONEPLUS A5010 using Audizine mobile app
    Dec 27 2009
    Orland Park, IL, USA
    It seems like you can control the engine sound in the 'Drive Select' option. In 'Dynamic' Driving mode, it seems like you can reduce the engine 'sound', when i drive with the window down and rev the engine , i definitely do not hear anything outside, the sound seems to be coming from the front speakers...
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Sound is not coming through speakers. On b9 S cars no artificial sounds. On b 8' there is a device on fire wall that sends sound via vibration. Is can be regulated a bit through Midi. Or coded out wi h coding unit. Or you can pull fuse 5 in first bank of fuses on drivers side panel. In either series no sound through audio system.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    May 26 2007
    UK
    Same device on firewall in B9 cars. Can be coded out using OBD11.
    Referred to as SoundAktor I believe.
    Veteran Member Three Rings socialpro's Avatar
    Sep 26 2013
    2023 RS6 || 2022 XC60
    scottsdale, az
    Quote Originally Posted by gjd000 View Post
    How exactly do you go about turning of this sound actuator through the OBD11? The 2K drone @ cruising is very apparent in our B9 S4!
    Thanks for the help and clearing this up. Seems to be a lot of confusion on the subject --
    May 26 2007
    UK
    Obd11 shows it as a separate module.....
    A9 Actuator for Structure Borne Sound
    Then go into adaptation and select Volume of structure borne noise actuator.
    Set to zero then press and hold green tick.
