The following is a list of parts I replaced. All of the bolts I replaced were torque to yield. I did not originally plan on replacing the exhaust clamps because I figured I'd be able to reuse the old ones. WRONG. The bolts were severely rusted to the extent that I actually had to cut the ears off of the passenger side clamp since the nut fused to the stud. In order to support my timeframe, I paid the local Audi dealership $60 for new clamps (don't do this).
Code:
# Part Price* ($) Retailer
1 OEM flywheel 605.78 Rock Auto
2 Sachs Xtend 626.13 Sachs
3 alignment tool 17.01 Europa Parts
4 exhaust gasket (2) 15.90 ECS
5 cat to dp nuts (6) 5.94 ECS
6 ds to diff bolts (6) 12.00 ECS
7 front axle bolts (12) 26.40 ECS
8 ds boot clamp 3.50 ECS
9 x-brace bolts (6) 22.20 ECS
10 steering shaft bolt 1.40 ECS
11 exhaust clamps (2) 60.00 Audi
*Includes shipping (if applicable)
My Sachs Xtend came with the pressure plate to flywheel bolts, drive plate to flywheel bolts, throwout bearing, guide sleeve, clutch spline lube, and the little handle tool that attaches to the clutch module to assist in lifting it into the trans. If you're ordering directly from Sachs, choose the PayPal option. I initially chose the wire transfer to save the 3% fee ($20) added for PayPal payments... turns out my bank charges $45 for international wires.
The following is a list of tools I purchased.
Code:
# Part Price($) Retailer
1 Gearwrench 85481 23.10 Amazon
2 Gearwrench 85483 24.82 Amazon
3 CDI 2502MRMH 123.99 Amazon
4 KTI62116 120.00 Amazon
5 trans jack 104.00 Amazon
6 6mm ball end socket 13.27 Amazon
7 Oetinker clamp pliers ---- ------
The 12mm indexable ratcheting wrench made getting the downpipe to cat bolts off a breeze. I used the 16mm one on the drive plate to flywheel bolts since the length provides good leverage and fits in the tight space allowed by the access panel. The "CDI 2502MRMH" is an inch-lbs torque wrench. The M10 bell housing bolts have an 11 ft-lb + 90 degree torque spec, which won't be within the range of many ft-lb torque wrenches. The 6mm ball end allen socket made taking off the axle heat shields much easier. The one I purchased was 6" in length, which I would recommend over any of the shorter options.
The bell housing bolts are 2 time use, so I did not replace mine. However, for those who need to replace theirs, here are the part numbers I came up with. The steel lower starter bolt can be reused any number of times.
Code:
Bolt Qty. Part No.
M12x100 5 N91129601
M12x125 1 N91129801
M10x60 2 N91150701
M10x95 2 N91153201
Code:
Bolt Size Qty. Part No.
pp to fw M8x14 6 N91136102
fw to driveplate M10-1.0x15.5 6 N91143203
driveplate to crank M10-1.0x27 10 N90929401
