Results 1 to 35 of 35
    Junior Member Two Rings fawaudi's Avatar
    Aug 05 2013
    Garden State
    Failed NJ Inspections with 034 downpipe + 02 spacer
    Hello All,
    Just wanted to share my NJ car inspection experiences, this is probably no news to some of you.
    My B7 is running APR stage I + 034 downpipe + 02 spacer + Milltek setup. Took my car in for inspection last week. The inspector A who helped and passed my car two years ago directed my car into the station, briefly greeted and said to me that he is going on a break but will have inspector B to take care of the inspection. The inspector B got in my car, passed through the camera thingy to see underneath the car, then popped the hood, got out with a flashlight, and looked right into the 034 downpipe. He then called over another inspector C over and kept saying to him that's a high flow, that's a high flow he repeats, but inspector C didn't really care or know what inspector B was talking about. But I was like WTF? That was the first time ever someone looks under the hood since I got the downpipe installed 4 years ago, passed two inspections without any issues. Anyway, inspector B somewhat knowledgeable with how the o2 spacer works and asked me if the spacer is used to eliminate the engine code, I replied, this is the first time ever someone would actually look under the hood and I said my mechanic installed the exhaust system for me and I don't know much about cars. He then pulled up to the counter where they print out the inspection report and LIED to me that he will see what the OBD2 diagnostic says, if it will pass the inspection or not, then few seconds later, he handed me the report and asked me to remove the spacer and come back for re inspection. I asked, so the OBD is giving you a code? He LIED again "yes". I was like F**K!! This is my lucky day running into an a$$hole! I looked at the report, all checked out "ready". He visually inspected my car and failed it manually and he also quoted "bung spacer installed on downstream sensor". None of that BS he was referring to being an engine code. He was just being a smart a$$ to whole entire inspection. I was so pissed!
    So what's next? I called up two shops asking what can I do about the downpipe and the spacer, since I don't have the OEM anymore. Well, basically both shops recommended me to get an OEM cat which shop 1 wants over $1000 installed (new). But shop 2 I spoke to recommended me to try and take the car to a different station and have it re inspected first, shop 2 said they can't fail me because I do have a catalytic converter. But again, worst case I would just have to find an OEM cat.
    Today, I just got back from a different station. I pulled in the car today the inspector D saw the rejected sticker and asked me why. Well, I played stupid and said I don't know, I had my mechanic looked at the car and he said it was fine. So then inspector proceeded the inspection, never opened up the hood. Next thing you noticed the car passed the inspection.
    Anyway, I wish all of you who is running similar setups get pass the inspector smoothly. Hope you all won't run into some a$$hole like in my case.
    Best of luck!
    Jun 17 2013
    jersey city nj
    I passed my NJDMV inspection twice already like you. Never once did they pop open the hood to . I have a APR test pipe and fail 1 of the readiness test all the time.
    Feb 09 2010
    Jersey
    I passed NJDMV twice with a JHM HFC that has the spacer already built in. Both times they scanned the bottom of the car and popped the hood to look at the cat when they noticed it was aftermarket exhaust. First time they didn't say anything. Second time they asked me if I had aftermarket cat, not HFC, but just aftermarket. I said yes. They did there thing and passed me.
    Past - 2008 Audi A4 2.0T Quattro 6MT S-Line Ti Ocean Blue Pearl
    Past - 2002 Audi A4 1.8T Quattro Tip Dolphin Grey
    Aug 05 2013
    Garden State
    Quote Originally Posted by djibouti99 View Post
    Is the built in spacer hidden on your JHM HFC? Mine is pretty obvious if you look.
    Aftermarket catalytic converter, that is what I was planning to say if the second inspection gone wrong.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Passed 3 times in NJ with a 034 cat and Revo tune. They popped my hood one time...
    Aug 05 2013
    Garden State
    Quote Originally Posted by Hugh@EuropaParts View Post
    Got my 034 cat and spacer from you guys. LOL. Good services, thank you!!
    Feb 09 2010
    Jersey
    Yeah, you can definitely see the spacer on the JHM HFC. I guess since all the readiness codes passed, they didn't care. Sounds like the inspector was going by the book. Some seem to not care as much.
    Senior Member Two Rings kp^'s Avatar
    Oct 01 2013
    PDX
    That some crazy DEQ process in NJ... I had a similar issue with my 034M HFC, short story I had to get it replaced.
    Here in Oregon they just plug in the ODB scanner, check for errors, and an CEL. Mine had a CEL with error code P0420 - Catalyst System Efficiency Below Threshold Bank 1. DEQ would not let me pass, so I had to get that taken care of.
    I had a local performance shop install a new cat (in sig) and error went away and I was able to pass DEQ. I still have the 034M HFC, so I'm not sure if there is a way to test if its bad or not. Shop basically said it was bad...
    Good luck!
    ______
    2008 Dolphin Gray Metallic A4 2.0T Quattro Ti S-Line 6MT | Magnaflow cat | Stasis catback exhaust | Stasis coil overs | ECS LED kit | deAutoLED D1S 5500k | Hoen yellow fogs | XTRONS: IB79AA4RP | TODO: Thor skidplate, 034M RSB, Recaro seats, stage 2,
    RIP Black 2007 B7 A4 3.2L 6MT Quattro S-Line @ ~99.997 miles
    Oct 08 2014
    Stow,Ohio
    In ohio we have a DIY station right outside of the BMV. You just pull up and plug in to your obd and it prints out your results. No inspection needed. I passed with JHM ko4. Always pulled in and got my car inspected prior to finding out there was such a thing when I needed inspection last year.
    Sent from my SM-G930P using Tapatalk
    Dec 05 2016
    miami FL
    visable inspection of the screen material?
    Quote Originally Posted by kp^ View Post
    Good luck!
    Established Member Two Rings bigheadb7's Avatar
    Jun 02 2017
    New Jersey
    I will never be able to pass inspection on my Mk5 gti. I’ve never had any problem with the Audi it always passes with no problem but my gti got sai delete and i have a catless downpipe. I even offer a shop to pay them 500 but they didn’t want it lol. The only time they opened my hood it was with my moms car because the guy didn’t see the cat under the car
    Jun 23 2008
    Yeah I've never had NJDMV pop my hood for inspection. Odd.
    Then again my Audi (Tune, 034 HFC, TT Downpipe) goes privately since the windshield is fully tinted and don't want the #&$*% at the DMV to scrape away and re-apply the sticker.
    Veteran Member Four Rings RoguesGambit's Avatar
    Dec 19 2012
    Eatontown, NJ
    Look at my sig, I passed with no issue
    Come down to the freehold DMV, you'll be fine
    JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
    More to come
    Also, my story: https://www.amazon.com/Sage-Mike-Fra...7646774&sr=1-1
    Dec 19 2012
    Eatontown, NJ
    Also, what part of Jersey are ya from, so us locals know to avoid that DMV
    More to come
    Aug 05 2013
    Garden State
    Quote Originally Posted by RoguesGambit View Post
    Paramus, but again this is the first time they ever looked under the hood, I have passed through two inspections with them before, just hit or miss I guess, and it was just not my day, if the inspector A wasn't going on his break, they would've never popped the hood.
    Anyway, I am glad to hear most of you haven't had any problem passing. Good Luck All!
    Senior Member Three Rings WewannaB7's Avatar
    Dec 07 2014
    07 Porsche Carrera S Cabriolet, 12 M-Benz ML350
    New Jersey
    Mine’s stage 1 and I’ve never had an issue at that Paramus inspection station. However, this last time I did run into an a-hole inspector who did pop my hood and also kept lecturing me on why I shouldn’t keep old expired insurance cards/registrations in my glove box. He kept insisting that I immediately throw away those expired cards and just in general was an ass. I feel like he just wanted to fail me, but couldn’t. I’m pretty sure if he saw a HFC in my car he’d fail me. Keeps me from wanting to go to stage 2.
    08 2.0T Quattro SE, APR Stage 1 - 93 Oct
    Aug 05 2013
    Garden State
    Quote Originally Posted by WewannaB7 View Post
    Damn, I wonder if we were dealing with the same inspector. Do you know why he popped your hood?
    Dec 07 2014
    New Jersey
    Quote Originally Posted by fawaudi View Post
    Not sure. He told me just to stay in the pass seat and wait. Maybe he wanted to check it cause he saw the APR Tuning license plate frame on my car. LOL
    Aug 05 2013
    Garden State
    How much more power do you get from Stage II? Passing the inspection is mainly why I haven't done Stage II, but according to APR website "Stage II Pricing: Customers who have purchased an APR ECU Upgrade before February 16th, 2015 are exempt from upgrade fees.". Does that mean you could upgrade and downgrade free of charge? If so, I would upgrade after each inspection then downgrade before each inspection.
    Jun 17 2013
    jersey city nj
    most shops will still charge flashing labor of minimum 1 hour for each
    Feb 09 2010
    Jersey
    For me, once they rolled my car over the camera to see the underside of my car and noticed an aftermarket exhaust, they popped the hood. This happened to me at two different DMV's. But they passed me...eventually.
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    Aaah New Jersey. The California of the East!
    Thankfully, CT only does an OBD test.
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Not really an asshole, just good at his job apparently. Did exactly what he is supposed to do.
    Sucks but sometimes that is what happens.
    Stage 2 doesn't do anything besides eliminate the CEL for the cat, I am 2+ and have a spacer so whenever I need to do emissions testing I just flash it back to stock and pass. If I got busted for this, yeah it would suck but not really anyone's fault besides my own. I am knowingly doing what you aren't supposed to and no way would I even think about doing it for 5 hp or whatever if it was a visual inspection in my state.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    No inspection of any sort in Florida. :)
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    passed an inspection before without them driving, lifting, or taking a single tire off the car (no emissions here). but you should still be able to fail one test and pass overall
    Dec 19 2012
    Eatontown, NJ
    Really? Like I said, Freehold, I come in, my exhaust is clearly aftermarket and they just carry on like it's nothing
    More to come
    Feb 09 2010
    Jersey
    Yeah. And funny enough, looking at your sig, my exhaust was the same setup. But was just Uni Stage 1+.
    Dec 19 2012
    Eatontown, NJ
    Question is, with Murphy in charge now, will it change or will they not care?
    Your exhaust loud as hell and drone around 3k as well?
    - - - Updated - - -
    Quote Originally Posted by 1killera4 View Post
    I'd move there, but can't stand humidity xD
    More to come
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    So you do have a high flow cat? Just take out the spacer and reinstall the O2 sensor where it should be. The HFC still works the same its just not as restrictive as stock, it has more flow area. You shouldn't need the spacer.
    I thought the spacer was just for those of us running a test pipe. I run a test pipe and spacer with no engine codes.
    2018 A5 S-Line Manual
    Aug 05 2013
    Garden State
    Quote Originally Posted by Der Konig View Post
    I agreed with you the inspector was just doing his job above and beyond.
    I got pissed off calling him an a$$hole because he was lying about the OBD was giving a code and failed the inspection, but the truth was that he failed the inspection manually. He could've done it more honestly and professionally instead of acting like a boss the whole time.
    Aug 05 2013
    Garden State
    Quote Originally Posted by konarider94 View Post
    Yes, it's a HFC. Taking out the o2 sensor will throw a code.
    Feb 09 2010
    Jersey
    I initially got non-resonated and it was unbearable. My whole car would rattle. I eventually had resonators installed, but yeah, still droned. Especially bad going up a hill or if the road was inclined. But when I'd bring it in to get serviced and they would start it up, it sounded real good.
    Veteran Member Three Rings APC123's Avatar
    Feb 05 2017
    Wilmington Delaware
    LOLOLOL
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    no i said take out the spacer and reinstall the 02 sensor. It sounds like the inspector only hand an issue with the spacer.
    Aug 05 2013
    Garden State
    My bad, I meant "taking out the spacer", LOL. Anyway, taking out the spacer and reinstall the o2 sensor will give me a code, just like your testpipe and will not pass the OBD. Trust me bro, if I didn't have to install the spacer, I would have saved myself a few bucks buying the spacer.
