Results 1 to 7 of 7
    Aug 17 2015
    California
    Anyone use Liqui Moly Pro-Line Engine Flush?
    Tons of good reviews on ECS and Amazon. Does anyone have experience with it in the 2.0T?
    Basically you add it to your oil before doing an oil change. Let the car idle for 10 minutes, then do an oil change as usual.
    https://www.ecstuning.com/b-liqui_mo...00ml/lm2037kt/
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    I used my last oil change can’t say I noticed any difference but for the price I figure it’s worth it for the piece of mind. Also bought the ceratec but plan to use that next oil change since I use an extractor and my next oil change I plan on draining oil then using that while installing my skid plate.
    Active Member Four Rings kingofnyc's Avatar
    Jul 01 2007
    Queens, NY
    Use it every oil change.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Until they can provide some actual evidence that a 10 minute "gentle" flush can do anything meaningful to remove sludge and baked on laquer , etc, I think this falls into the same waste of money, snake oil category as all the other similar products out there. The reviews are all meaningless...just off the cuff remarks.
    These products have been around for many, many years and I have never seen a single one that can support the claims they make. A possible exception is AutoRx, which is a not a quick 10 minute miracle and has some actual test data and evidence to support it.
    2011 A4 Avant
    Aug 17 2015
    California
    Quote Originally Posted by jfo View Post
    Yea I have to agree with you there. All the reviews are just empty claims without much proof to back them up.
    At least there are no 1 star reviews like "my engine blew up after I used this!".
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    I use it every other oil change
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Nov 17 2010
    It's a placebo. If it makes you feel like it's doing something, then by all means buy it.
    2011 A4 Avant
