Results 1 to 11 of 11
    Feb 10 2012
    Ventura CA
    Need image of 4.0L firing order
    Does anyone have an image of the 4.0 RS7 firing order? I have a misfire on cylinder 5, thinking of changing to colder plugs and new coil packs
    Sent from my iPhone using Tapatalk Pro
    Mar 26 2010
    US
    Quote Originally Posted by mariokart View Post
    Does anyone have an image of the 4.0 RS7 firing order? I have a misfire on cylinder 5, thinking of changing to colder plugs and new coil packs......
    Page 60,
    Audi 4.0L V8 TFSI Engine with Twin Turbochargers, Self-Study Program 920223
    Timing chain is the back of engine, near flywheel/clutch.
    BMW M3 Competition X-drive
    Feb 10 2012
    Ventura CA
    Than you so much
    Jan 02 2018
    Deleted
    You want the firing order, or the cylinder count? Cylinder count, when looking at the engine with the hood open, is 1,2,3,4 starting on the left (passenger side, front to back), then 5,6,7,8 on the right (driver's) side, front to back as well. So your cylinder #5 is the first (closest to the front grille) on the driver's side. I'm not sure about the firing order on our 4.0TT, but typical Audi V8 firing order has been 1-5-4-8-6-3-7-2, but let somebody more familiar with the 4.0TT confirm or correct me. Good luck.
    Feb 10 2012
    Ventura CA
    Checking cycle 5 should be easy since at the front
    Nov 06 2012
    Pennsylvania
    Until you see you need to unbolt the wiring harness for the coils and see the coolant res is in the way. Cyl 1-4 is easy to get to. The other side sucks for access.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Current daily- '13 S6 - EPL stage 2
    Backups '08 A4 2.0 and '10 A6 3.0t
    Past fleet
    '07 RS4 misano red on black
    '05 S4
    '06 Jetta 2.5
    '01 TT 225
    Feb 10 2012
    Ventura CA
    Quote Originally Posted by brian_216 View Post
    Good to know. Any suggestions of which plugs and gapping to use on my RS7 stage 2? Are the coil packs known to go bad in these cars?
    Established Member Two Rings tech30six's Avatar
    Sep 22 2016
    Kitchener-Waterloo, Ontario
    There is a specific TSB for cylinder #5 misfire. Pretty sure it's a software update. The Contact the dealer and get it dealt with asap.
    Sent from my LG-H915 using Audizine mobile app
    Sep 29 2023
    Michigan
    Old post here so I hope someone replies... I'm am having the same cyl 5 misfire code on some pulls. Anyone ever figure out the cause?
    Established Member Two Rings ilikecooltech's Avatar
    Jun 26 2016
    Q7
    Houston%2C%20Texas
    It’s a common issue with this platform. There is a bunch of info about resolutions/solutions stock or tuned setups to handle more boost/power. Checkout the 4.0 Performance and Tech FB group.
    Sep 29 2023
    Michigan
    Quote Originally Posted by ilikecooltech View Post
    Thank you, I'll try to find the group. I am tuned, stage 4 custom.
