Yes to the first part of your question. This was rigged up just to see if the cylinders would hold pressure ( a traditional compression check is out obviously as my timing chain snapped so i had to think of another way ) . The handle is just a socket on the crank bolt. As the cylinder is holding pressure it pushes down the piston .
It also bursts out air when i remove the air supply so is also a good sign.
The exhaust cam is still in time as its driven by the timing belt. Yeah actually i forgot the intake valves hitting the pistons when i turned it and wondered what the resistance was lol. But I’m pretty sure it just pushed the piston away as i have no plugs in.
Yeah i saw a you tube where a mechanic dropped in the tool set it all up. Buttoned it up and it ran.
He did have a code and was out of spec for cam timing. He took it all apart moved it a tooth. The tool still fit and the degree difference for cam timing was much tighter and no code.
So i was wondering if there were any secondary method i could use to check alignment.
I know that different coloured chain link is for something. Just not sure what.
It would be awesome to know where the line on the cam adjuster and the dot on the intake cam tooth are when timed properly at tdc.
Sent from my iPhone using
Audizine
