Page 45 of 50 FirstFirst ... 354344454647 ... LastLast
Results 1,761 to 1,800 of 1979
  1. #1761
    Mar 21 2021
    Ventura County, CA
    Quote Originally Posted by Paul@SupremePower View Post
    Below is at stock height. It’s not a good angle to show how it sits but I can 100 percent confirm 8.5 +43 does not poke. It sits slightly inbound. 8.5 +38 doesn’t clear the brakes in these.
    I have a set of the 8.5 +43 available if you like
    Hey Paul, FYI for the future.
    I have the TC105X in the 8.5 +38 and it clears the stock RS3 brakes by a lot actually. The +38 offset is perfect for the RS3/TTRS, it sits great where as the +43 version kinda sinks in a bit and would require a nice 5MM spacer to look good.
  2. #1762
    Jan 24 2013
    Quote Originally Posted by DanMPower View Post
    Well dang!
    Weds seems to think they do not.
    Awesome thanks for the post!!
    Email: [email protected]
    Call or Text: 914-243-1993
  3. #1763
    Nov 27 2020
    Florida
    Quote Originally Posted by PowerDemon View Post
    Great thread, and you guys have some beautiful rides. Thanks for taking the time to post your fitments and specs.
    Does anyone have any photos of the WedsSport TC105X in either 43 or 38mm at stock height? I’ve seen several photos of cars with the 43mm offset, but I’m not sure if they are stock height or not. I want to make sure that there is no poke whatsoever at stock height.
    Also if anyone has a photos of the TC105X on a Daytona grey car that would be awesome. I’m afraid the colors will be a bit too similar, and that there isn’t enough contrast.
    Weds TC105x 18x8.5 +43 with MPS4S in 245/40/18 at stock height.
    20220102_094331.jpg 20220102_094324.jpg 20220102_084659.jpg 20220102_084655.jpg 20210716_170414.jpg
  4. #1764
    Junior Member One Ring
    Jan 25 2022
    2018 Audi Q7, 2016 Toyota 4Runner TRD Pro
    Colorado Springs
    Fabulous thread here! My wife is a bit upset with me reading all of this over the last two days!
    I picked up a 2018 RS3 a week ago to replace my 2019 S3 that had the Black Optics Option which includes the nice 19" Rotor wheels which I assume are 8" width. I have always loved these wheels and I'm very tempted to use these and replace the staggered wheels on the RS3. My assumption is they will fit on the front. If I did this, I would run 245/35 tires.
    But after reading here that the Audi Sport wheels are often 27 to 29 lbs and that there are many wheels discussed here in the 19 lb range, my question is how much of a difference will that make in the driving experience? Assumption here is I would pick wheels that are 19x8.5 and go with 245/35 x 19 tires for a square setup. Thanks to all for all that I have learned!
  5. #1765
    Jan 24 2013
    Quote Originally Posted by BENDOU View Post
    Congrats!
    Those S3 rotors do not clear the Rs3 brakes unfortunately. Losing weight on all the corners is always a plus but the biggest improvement will be to dump the Oem pirellis. They are hot garbage. Whatever wheel you choose my advice is go square and get good tires that meet you need and goals. That alone will increase performance exponentially.
    Shoot me an email I’d be glad to help 👊
  6. #1766
    Jan 25 2022
    Colorado Springs
    Thanks so much for the reply, Paul!
    I'm happy to know the S3 rotor wheels won't fit on the front as I'm now not tempted to do that. I had suspicions they wouldn't fit. My RS3 came with the Michelin PS S4 tires in the stock staggered sizes. Last week I put on 245/35 19 Michelin winter tires and the car is much more compliant to big cracks in the roads around here. But not enough for my liking. If our roads get any worse, local daily trips will best be done in my 4Runner!
    I've been reading and learning more and I'm now leaning to 18x9 - 45 using 255/30 tires to get a bit more sidewall. Still have some reading to do to narrow in on what styles and finishes I'd like. Saw the Weds along with the RSe 102 and an FC that strike my fancy so far. Loving the brushed black finish too.
    Will email you as I get closer to defining my wants (although reading what I just wrote I may be there already). lol
  7. #1767
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    If you want more sidewall than a 245/35/19 dont mount up 255/30/18's, those have ~3.01 inch sidewall vs ~3.38 for the 245/35/19. If you want a noticeable difference, you want 245/40/18's mounted on 18X8.5's (3.86" sidewall)
    https://www.tacomaworld.com/tirecalc...5r19-245-40r18
    Stage 1 more than you RS3
  8. #1768
    Jan 25 2022
    Colorado Springs
    Quote Originally Posted by o1turbo30v View Post
    You are right! I did get confused on all this. Tks
  9. #1769
    Jul 24 2021
    Adelaide/South Australia
    Congrats!
    Hey Paul,
    What is generally the best tyre size to go for on a car running the staggered setup? 245/35R19 ok to run on staggered OEM wheels front & rear? I am not really a fan of staggered if I am honest, so trying to work out what best size of tyres i should go for next...
  10. #1770
    Jan 24 2013
    Quote Originally Posted by DarkSammy View Post
    Hey Paul,
    While not ideal, 245/35-19 is really the only size you can pull off on the staggered Oem. Much better for handling to go square rims and tires though.
  11. #1771
    Jul 24 2021
    Thanks Paul!
  12. #1772
    Established Member Two Rings strzin's Avatar
    Dec 04 2017
    Los Angeles, CA
    BC Forged HCA381S / Brushed clear center / polished lip / Titanium hardware
    Fronts 19x9.5 +42
    Rears 19x9.5 +45
  13. #1773
    Feb 11 2019
    california
    Specs:
    Titan7 TS-5 18x8.5 et 44 with PS4s 255/35/18
    APR 2mm Spacers up front. I have a 3-4mm clearance between spacer and caliper at the tightest spot.
    Lowered on Neuspeed Springs
    They also clear the Neuspeed 350mm Rear Brake Kit.
    https://photos.app.goo.gl/Kv3Jfg4v6ntHUWhL6
  14. #1774
    Jul 13 2018
    Winnipeg, MB, Canada
    A couple days ago I placed an order for OZ wheels (ultraleggera) and heard back from the retailer that the wait is 85-90 business days (18 weeks), so I cancelled. How long are you folks waiting for fulfillment?
  15. #1775
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by TheContrarian View Post
    Did you check tirerack.com?
  16. #1776
    Jul 25 2020
    New York
    Hi Paul, I'm close to settling on wheels and tires but wanted to verify fit before pulling the trigger. My car has the carbon ceramic brakes and is at stock ride height. Planning to go with RSe11R's 18x9 +45 with PS4S 245/40/18. Should that be kosher?
  17. #1777
    Feb 20 2022
    St.Augustine FL
    Paul;
    Just wanted to give you a shout out for the help for my 2019 rs3, I think we have the wheel and tire situation squared away. Just wanted to thank you so much for your time and efforts!
    R/
  18. #1778
    Jan 24 2013
    Quote Originally Posted by Bojangles47 View Post
    Yup that’s solid. Shoot me an email if you’d like to discuss further or would like pricing
    Quote Originally Posted by Jtrump View Post
    Paul;
    R/
    You’re welcome! I’ll get everything quoted and sent for Monday processing 👊
  19. #1779
    May 08 2020
    2015 Golf R DSG, 2015 Golf TDI 6-speed.
    Purcellville VA
    Yes this will serve you well. I am running PS4S 245/40/18 which replaced A/S3+ on RSe10 18x8.5 and they've proven to be a very satisfactory configuration. I am currently at 32,270 total miles with 23,234 miles being fast country back road runs and am very pleased with the performance of this configuration. Soon to be 82 years old and have making these kinds of back road runs since 1958, starting in southern California, now in northern VA in BMW, Porsche and now our 2019 Audi RS 3.
    https://www.audizine.com/gallery/sho...?ppuser=547441
    Rod RS-3
  20. #1780
    Established Member Two Rings RS3_993's Avatar
    Feb 16 2019
    1997 blk/blk 993 C2
    Superspeed RF06RR 18x8.5”et42 (+7mm spacer)
    P245/40R18 Conti’s.
    2018 RS3 Mythos w/Blk_Optics
    Custom build at Redline Motorworks
    Iroz 850s
  21. #1781
    Jan 24 2013
    RS3 fitments added:
    RSe05
    19x8.5 +45
    19x9 +45
    19x9 +40
    19x9.5 +45
  22. #1782
    Junior Member Two Rings
    Jan 08 2022
    Northeast
    Longtime lurker finally joined! Read this thread numerous times. Thanks to everyone for the info especially Paul@SupremePower. Just curious if anyone is aware of a two-tone aftermarket rim like the oem? Looking to go 18x8.5 square in the near future and think the silver/black wheel looks great with the Nardo grey. Thanks.
  23. #1783
    Jan 24 2013
    Quote Originally Posted by Plake View Post
    You’re welcome! Glad it was helpful.
    BC Forged has bunch of styles that can be done diamond cut face with black or Gunmetal relief
    This is RZ21 diamond cut face and gloss black relief :
  24. #1784
    Jan 08 2022
    Northeast
    Thank you for the info.
  25. #1785
    Jul 25 2020
    New York
    RS3 8V Sedan Manufacturer (and member) Confirmed Wheel Fitments
    Neuspeed RSe11R in 18x9 +45 with PS4S 245/40x18. Just enough space between the barrel and the CCB's. Thank you Paul for your help in figuring out the right combo of specs for my car!
  26. #1786
    Jan 24 2013
    Woot! You’re welcome!
  27. #1787
    Jan 08 2022
    Northeast
    Well, i've been browsing and pretty sure this the best thread to ask this. If I bought another set of oem 19x8.5 for the rear would 245/35 square work with CCB? Thanks all.
  28. #1788
    Jan 24 2013
    It would. But whyyyyyyyyyy? You’re adding more weight. 🙃
  29. #1789
    Jan 08 2022
    Northeast
    The horror! Lol. I need more tire for these fine Long Island roads and really like the oem wheels. But again, going with 18's and 245/40 is a close 2nd.
  30. #1790
    Jan 24 2013
    HAHAHAA! I hear ya. I’m from Westchester so I know your pain.
    I’d recommend dropping to 18”. You can get the same sidewall meat with 245/40 and can drop 8-10 lbs per corner with the right ones.
  31. #1791
    Jul 24 2021
    Hey all,
    100% noob question I apologise, i am very new to Euro and come from a JDM background. When ordering aftermarket wheels for our RS3 Sedans (Saloon) do we need to specify hub centric details say if I were to order a set of Vossen HF3, or will they know hat to give me when i say it is for the RS3 platform? Also what premium brand of lug nuts do most of us use/recommend? I am guessing I will need lugs too so may as well order that at the same time...
    Thanks from Australia Down Under ;)
  32. #1792
    Junior Member Two Rings extrememike's Avatar
    Dec 28 2016
    Sooner State
    Hey @Paul. Talked to you in the past. Thinking on pulling the trigger this time around on some new wheels and a summer set. 2019 RS3 sedan. I’ll pm you via email to check on prices and availability.
    S3 Prestige
    Sold but not forgotten:
    Camaro 2SS
    Focus ST3
  33. #1793
    Jan 24 2013
    Quote Originally Posted by extrememike View Post
    Spends good I’ll look out for the email 👊
    Hey all,
    Depends on the manufacturer. Anything custom you can get true 57.1. Some off the shelf wheels have bore choice but many are going to be larger bore and require the use of rings to 57.1. Most places will know what to include if they know the platform it’s going on but it won’t hurt to ask.
    Bolts will depend on the specific wheel. Some need ball seat and some cone. For most wheels without spacers on this car you’re looking at 14x1.5x27 to 30mm
  34. #1794
    Established Member Two Rings kynovs4's Avatar
    Mar 08 2016
    2005 S4 Avant 6spd
    Marlborough, MA
    Quote Originally Posted by RS3_993 View Post
    P245/40R18 Conti’s.
    Had my eye on these for a set of drag wheels. I am assuming these didn't clear the calipers without the spacer?
    2018 Daytona Gray RS3
    2005 Brilliant Black S4 Avant 6-spd
  35. #1795
    May 08 2020
    Purcellville VA
    Neuspeed wheels such as these shown here at <https://neuspeedrswheels.com/collect...31935762890865> are designed to clear Audi RS 3 brake calipers, such as I am using on our 2019 Audi RS 3. Been using their wheels 40+ years and they've performed perfectly on the many different vehicles I've used their wheels on.
    Here's a pic of them on our Nardo Gray 2019 RS 3 fitted with Michelin A/S3+ 245/40/18 tires, capabile of surviving our pot-hole rittled back roads, which killed two of the original factory 235/35/19 tires in 3 days!...
    https://www.audizine.com/gallery/sho...hp?photo=97718
    Rod RS-3
  36. #1796
    Feb 16 2019
    1997 blk/blk 993 C2
    Quote Originally Posted by kynovs4 View Post
    Yup, running a 7mm spacer up front.
    Iroz 850s
  37. #1797
    May 13 2015
    Calgary AB
    Finally got my BC Forged wheels courtesy of Paul@Supremepower.
    19x9.5 +43/+45 BC Forged KL01's in Brushed Black finish on Firestone Firehawk Indy 265's, lowered on APR anti roll for now. Really happy with how it came out :D
    2020 Audi RS3
    Unitronics: Stage 1+ ECU E60-E85 / Stage 2 TCU | NGK RACING Plugs KIT | WG Line | P3 Gauge kit
    CTS: FMIC | 4" Intake | 4" turbo inlet | Catless Mid pipes
    APR: Penduluim | Anti Roll lowering springs
    BC Forged 19x9.5 KL01's in Brushed Black w/265/30 Firestone Firehawks
    Others: 034 upper & lower inserts | Race3 charge pipe
  38. #1798
    Jan 24 2013
    Quote Originally Posted by secondchance View Post
    Woot! You’re welcome. This deserves the full shot:
  39. #1799
    May 10 2022
    Castle Rock Colorado
    RS3 fitment added:
    Supreme Forged SP-1
    19x9.5 +45
    Brushed single dark tint glossy
    Fully customizable in 18” to 20”
    Pictured in
    265/30-19 PS4S
    KW V3 DDC ECU
    can you pm me the price of this setup? are these stock springs?
  40. #1800
    Jan 24 2013
    Quote Originally Posted by captainrs3 View Post
    You have pm
