Page 1 of 50 12311 ... LastLast
Results 1 to 40 of 1979
    Jan 24 2013
    RS3 8V Sedan Manufacturer (and member) Confirmed Wheel Fitments
    Because the RS3 holds a special place in my heart, I wanted to try and take some of the frustration out of choosing wheels that fit due to the large caliper and small MQB architecture combo.
    What I've decided to do is use Post #1 and Post #2 for manufacturer confirmed wheel fitments without spacers and in what specs for the 8V RS3 Sedan. Meaning, I have contacted the manufacturer and we have confirmed by either test fitting or via craft expertise that those options will work.
    I'm going to use Post #3 to list manufacturer confirmed fitment with spacers with the suggested spacer width. I will also use Post #3 for Custom wheels. Additionally, I’d like to do a section with Audi OEM fitments but that may have to be member confirmed only because Audi tends to not go on the record for "off-label" use of anything (End of Post #3).
    This is not an all inclusive list of manufacturers but I will do my best to keep adding fits. I'm always waiting on other vendors to reply so I will be updating it as often as I can so check back for the most current info.
    If any one has any requests for confirmed fitment, post the manufacturer name, wheel line, diameter, width and offset.
    Ill do my best to confirm it and update it into the appropriate Post.
    If anyone wants quotes on anything please email me [email protected] instead of posting so we can keep the thread concise.
    Note: Post #1, #2 and #3 info is meant to be used as a guide for the wheels under lowering of about 1” at factory camber.
    This info shouldn’t change but anything is possible so please make sure you make a final confirmation with the manufacturer if you place an order elsewhere.
    *** Tire brand can effect the functional size and could effect the final mounted fit and look on the car. If a manufacturer supplied a recommended tire size I included it but other sizes may be possible depending on your willingness to do post mounting adjustments ***
    *** Ride height effects clearance/rub ***
    ***Most of the wheel pictures are stock photos and are only to show the wheel style. They may not represent the confirmed specs in profile concavity***
    ***Spec’s listed clear STEEL ONLY unless otherwise noted as also clearing CCB***
    Summary:
    Post #1 & #2
    -Confirmed fitment without spacers
    Post #3
    -Confirmed fitment with spacers
    -Custom fitments
    -Member confirmed OEM fitments
    Confirmed options so far without using spacers:
    SUPREME FORGED
    19x9.5 +45
    Forged
    Steel and CCB
    Fully customizable in 18” to 20”
    ALTI
    GT1
    19x9.5 +45
    Forged
    BBS
    RSGT
    RS 958
    19x8.5 +32 with 235/35-19
    Forged
    CC-R 2302
    19x9.5 +42 *slightly aggressive fitment for rear*
    Clears steel and CCB
    RF 527
    18x8.5 +38
    19.1 lbs
    Forged
    Clears steel brakes only
    LMR 322
    19x8.5 +38
    Forged
    Clears steel & CCB
    LM 273
    20x8.5 +38
    Forged
    CH-R
    19x9.5 +45
    And
    20x8.5 +40
    CH-R Nurburgring Edition
    19x9.5 +45
    FS
    19x9.5 +45
    And
    19x8.5 +42
    Forged
    CI-R 2201
    19x9 +42
    (Silver lip protector is removable)
    CI-R Nurburgring Edition
    19x9 +42 Square
    XA 0202
    18x8.5 +35
    RI-A 016
    18x9 +38
    18.2 lbs
    Forged
    RI-A 047
    18x8.5 +35
    18.0 lbs
    Forged
    Clears steel only
    VORSTEINER
    VFF 102
    20x9 +35 aggressive fitment
    VFF 103
    VFF 105
    19x9 +40
    245/35 max
    VFF 107
    245/30 max
    VFF 108
    19x9 +40
    VMR
    V801
    19x8.5 +35
    245/35 max
    Also good with CCB
    V804
    19x8.5 +35
    245/35 max
    V710
    19x8.5 +35
    245/35 max
    Also good with CCB
    NEUSPEED
    RSe05
    19x8.5 +45
    19x9 +45
    19x9 +40
    19x9.5 +45
    RSf72
    Forged
    19x9 +45
    19x9.5 +45
    Above clears with steel and CCB
    RSe06
    18X8.5 +45 with 235 or 245 tires (center mount outer balance weight)
    18X9 +40 with 245 or 255 (narrow)
    18x9 +45 with 255 or 265 tires
    18X9.5 +45 with 255 max. Rear DOT fender tab may need removal
    Above clears steel & CCB
    RSe11R
    RSe142
    19X8.5 +45
    19X9 +40
    19x9 +45
    19X9.5 +45 with 255 max. Rear DOT fender tab may need removal
    RSe122
    18X8 +45 REAR ONLY
    RSe 102
    19x9 +40
    19x9 +45
    19x8.5 +45
    19x8 +45 REAR ONLY
    20X9 +40 with 245/30 (BARELY CLEARS CALIPER - 3mm SPACER IS HIGHLY RECOMMENDED)
    RSe 10
    19x9 +40
    19x9 +45
    19x8.5 +45
    19x8 +45 REAR ONLY
    18x8.5 +45 with 235 or 245 tires (center mount outer balance weight)
    18x9 +40 with 245 or 255 tires (narrow)
    18x8 +45 REAR ONLY
    RSe 52
    18x9 +45
    18x9 +40
    245/40 square or
    265/35 Front & 245/40 Rear
    [/B]
    Ray’s
    G025
    19x8.5 +45 (face-1)
    19x8.5 +35 (face-2)
    G25
    19X8.5 +38 and +45 (+38 may need 3mm spacer in NA & ROW vehicle)
    18x9 +45 (member confirmed post #536)
    ZE40
    19X8.5 +44
    TE37 ULTRA
    19X8.5 +38
    TE37 Saga S Plus
    18x9.5 +45 redrill to 5x112
    G27 Progressive Model
    19x8.5 +38 Square
    19x9 +48 Square or use with above for front stagger
    Gram Lights 57CR
    19x8.5 +35
    Deep center
    245/35-19
    VERSUS VV21S
    18x8 +44 face 1
    18x9.5 +38 face 2 (aggressive fitment)
    19x8.5 +34 face 1
    WEDSPORT
    TC105X
    18x8.5 +43
    16.3 pounds
    245/40-18 or 255/35-18
    Also good with CCB
    HARTMANN
    FF-070-CG
    19X9 +40
    245/35-19
    FF-003-CG
    19x8.5 +38 w/ 235/35 or 245/35
    19x9 + 40 w/ 245/35
    HRS6-091-MA
    19X8.5 +38 W/ 235 OR 245 TIRES
    HRS6-204-GS
    HRS6-204-MA
    HRS4-252-GS
    20X9 +40 W/235 OR 245 TIRES
    HLP-410-GS
    Email: [email protected]
    Call or Text: 914-243-1993
    Jan 24 2013
    Manufacturer Confirmed Fitment Without Spacers CONTINUED
    HARTMANN Continued
    HR8-GA
    19X8 +35 W/ 235 OR 245 TIRES
    HR8-GS
    19X8.5 +47 W/ 235, 245 OR 255 TIRES
    ISWEEP
    Flat Racing Graphite:
    Gloss Racing Graphite w/ machined ring:
    18x8 +45 rear only
    18x8.5 +45 square or staggered
    18x9.0 +45 square or staggered
    -clears steel and CCB
    AVANT GARDE
    M510, M540, M580, M590, M610, M615, M621, M632
    19x8.5 +32
    235/35 Or narrow brand 245/35 max
    M652
    19x8.5 +32
    M520R
    19x8.5 +32
    ADVAN
    Advan RS-DF
    19x8.5 +45
    Advan RGIII
    19x8.5 +45
    Advan GT
    19x8.5 +42
    18x9 +45 - member confirmed
    Advan RZII
    19x8.5 +45
    Advan RSII
    19x8.5 +42
    AVS Model F50
    19x8.5 +42
    OZ RACING
    SUPER LM
    19X8.5 +44
    GOOD WITH CCB ALSO
    HYPER GT
    19X8 +35
    235/35 max
    GOOD WITH CCB ALSO
    ULTRA HLT
    19X8 +35
    235/35 max
    19X8.5 +32
    19X8.5 +38
    245/35
    19X8.5 +47
    SEBRING
    19x8.5 +32
    HRE
    FF10
    19x9.5 +45
    255/30
    Good steel and CCB
    FF11
    19x9.5 +45
    255/30
    Good steel and CCB
    FF01
    19x9.5 +45
    255/30
    FF04
    19X9.5 +45
    255/30
    FF15
    19x9.5 +45
    255/30
    ABT
    GR20
    20x8.5+45
    ER-C19
    19x8.5 +35
    245/35 max
    TARGA
    TG3
    19x8.5 +45
    20x9 +42
    TG2
    19x8.5 +45
    ROTIFORM:
    BUC
    19x8.5 +35
    245/35-19
    SIX
    19x8.5 +35
    245/35-19
    OZR
    20x9 +38
    245/30-20
    VOSSEN
    HF-1
    19x8.5 +38
    245/35 max
    Steel brakes only
    HF-2
    19x8.5 +38
    245/35 max
    Steel brakes only
    HF-3
    19x8.5 +38
    245/35 max
    Clears Steel & CCB
    CV10
    19x8.5 +38
    245/35 max
    Steel brakes only
    Jan 24 2013
    Manufacturer Confirmed Fitment With Spacers (Unless otherwise noted):
    VORSTEINER
    [B][SIZE=3]
    VFF 101
    19X8.5 +45
    8mm Spacers
    245/35 max
    VFF 103
    19x8.5 +45
    8mm Spacers
    245/35 max
    VFF 105
    19x8.5 +45
    8mm spacers
    245/35 max
    VOLK
    TE37 ULTRA
    19X8.5 +45
    3mm Spacer
    TE37 SAGA
    18x9 +50 5x112
    5mm spacer
    G025
    19x9 +50 (face-2)
    3mm-5mm spacer
    19x9.5 +44 (face-3)
    3mm-5mm spacer
    HARTMANN
    HRS7-163-MA
    3mm Spacer
    HTT-256-MA
    3mm Spacer
    20X9 +40 W/ 235 TIRES ONLY
    3mm Spacer
    HLP-410-GS
    3mm Spacer
    CUSTOM FITMENTS
    These are just some examples of custom style and specs that will work. Many others are possible so email me if you want a specific custom style and spec combo. In the interest of saving space in these posts I will link to custom fitment in lieu of pics below unless I have a specific RS3 custom wheels possibilities to show or that have been done.
    FORGELINE
    VX1
    Various diameters, widths and offsets
    BC FORGED
    HCS21
    BC FORGED MONOBLOCK RS3 CONFIRMED FIT LINES (offset varies)
    BC FORGED MODULAR RS3 CONFIRMED FIT LINES (offset varies)
    FJ SERIES RS3 STEEL BRAKES FITMENT AVAILABLE IN:
    19x9
    19x9.5
    +40 to +45
    30mm to 50mm lip
    Workable spec configuration depends on square or staggered offset
    VOSSEN
    VPS-315T
    19" Custom offsets
    ROTOFORM
    Forged lineup:
    http://www.rotiform.com/forged-c-4197.htm
    SIGNATURE WHEEL
    Full collection:
    https://www.signaturewheel.com/products
    MEMBER CONFIRMED FITMENTS
    R8
    19X8.5 +42
    No Spacers
    Thanks to Steve B. from the FB S3/RS3 Owners Group for pic
    S4 Peelers
    19x8.5 +43
    No spacers
    255/35/19 Blizzak LM-32
    Thanks to Edward L. From the FB S3/RS3 Owners Group for pic
    HRE
    FF01
    19x8.5 +47
    8mm Spacer
    (member confirmed)
    Enkei
    RS05RR
    18x8.5 +45
    10mm spacer
    (Member confirmed. Thanks to kevinlee709)
    PF01
    18x9 +35 (agressive fitment)
    265/35 F and 245/40 R
    (Member confirmed. Thanks to V8Bait post #1106)
    Jun 17 2017
    Delaware
    Thank You Sir!
    Love the Neuspeed RSe102 but not sure what offset to get. Planning on running 255/30/19 front and rear.
    Jan 09 2018
    Rancho Murieta, CA
    Quote Originally Posted by Paul@SupremePower View Post
    I'm running the Rse14 19x 9 +40 for winter. Just a little bit of poke, perfect IMO.
    The RSe 102 in 19" +40 should fit exactly the same.
    This is an awesome thread! What size tires are you running on your 19x9, +40? I’d prefer a flush fitment with zero poke. Any pics down the side?
    Thanks in advance.
    Jan 24 2013
    Quote Originally Posted by iceman302 View Post
    Thanks in advance.
    245/35 for me.
    No good pics yet. Unfortunately it’s been at the dealer since early December, right after I got them on.
    Jan 09 2018
    Rancho Murieta, CA
    245/35 for me.
    Ouch. I hope whatever the issue is, that it gets sorted out soon.
    Jan 24 2013
    Me too. It’s the widespread NA RS3 software/hpfp/idle limp mode thing.
    Jan 24 2013
    Post#1 updated with Volk.
    Jun 17 2017
    Delaware
    245/35 for me.
    I was going to run 255/30/19 front and rear, do you think they would stick out to far based on what you know from your set up?
    Jan 24 2013
    Quote Originally Posted by QShip18 View Post
    Well Neuspeed recommends 235/35 or 245/35 with RSe102 in 19x9 +40 and calls 245/35 an aggressive fitment for the car.
    Jan 09 2018
    ny
    Like the look of the Neuspeed RSe 52 for an 18" setup. Strangely, the Neuspeed website does not list this wheel as compatible with the 2018 rs3 sedan. How do you know it fits?
    Jan 24 2013
    Quote Originally Posted by PowerStroke View Post
    Directly from my guy @ Neuspeed:
    “RS3 fitments:
    - All designs in 19x8.5 and 19x9.0
    - 18x8.5 and 9.0 +40/45 RSe10
    - 18x9.0 +40 RSe52
    These will fit WITHOUT any spacers, straight bolt on. The 9.0” wheels will be supplied with 66.5-57.1 hub centric rings.”
    Maybe the application function on their site is not updated to reflect it?
    Jan 24 2013
    Neuspeed wheels usually have a ton of caliper clearance. Most are designed for aftermarket BBK.
    Jan 09 2018
    ny
    “RS3 fitments:
    - 18x9.0 +40 RSe52
    Very helpful, thanks!
    Jan 24 2013
    No prob.
    Here’s the RSe14 19x9 +40 over the brakes showing barrel clearance. I can’t find the pic showing the spoke clearance but it was a full inch at the closest caliper point.
    Jun 17 2017
    Delaware
    Well that does it then, 245/35/19 is what I’ll use. At least with this size I can run all season tires. I’m assuming this should be flush with the fender.
    Jan 24 2013
    RSe102 is also available in 19x8.5.
    Shoot me an email if your concerned about poke and we’ll help you hash it out.
    Jan 09 2018
    ny
    No prob.
    Thanks for that. super helpful! do i need different wheel width wheels for front and back if i’m gonna use these for a winter setup?
    Jan 24 2013
    You don’t need to. In fact I don’t see any reason to front stagger in a winter set up at all.
    Jan 24 2013
    Added
    BBS CIR 2103
    19x8.5 +45
    Veteran Member Four Rings crazytex21's Avatar
    Jan 31 2010
    Georgia
    I am running a square 255/30-19 on 19x9 et40 for my RS3. no issues.
    tex lee
    A lot of people think you want to race, when in reality, you just have to motor home because Chipotle.
    ~Shicky~
    Jun 17 2017
    Delaware
    Quote Originally Posted by crazytex21 View Post
    Any pictures? I’d love to see what this set up looks like.
    Jan 31 2010
    Georgia
    tex lee
    ~Shicky~
    Jun 17 2017
    Delaware
    That does look good but I want my set up tucked in the fender a tad more. Based on this I’m thinking the 19X8.5 +40 with a 245/35/19 might be the better choice for me. Thanks for posting the picture!!!
    Jan 09 2018
    ny
    http://www.neuspeed.com/374/0/0/3007...ght-wheel.html
    For this wheel, the color pictured on the white Audi is the gun metal?
    Jan 24 2013
    That looks like satin bronze. The rse14 above is gunmetal.
    Stage 2 Banner Advertiser Four Rings Eric@SupremePower's Avatar
    Sep 27 2004
    So Ca
    Glad you got this up Paul!
    Eric Nareshni
    [email protected]
    714-632-1951 x225
    | 034 | ADV.1 | AG | Advan | Akrapovič | AWE | BBS | BC Forged | Brembo | Capristo | Forgeline | H&R | Klassen | KW | Milltek | Modulare | Ohlins | OZ | Stoptech | TSW | Volk | Vorsteiner | Work | and many more
    What are lightest 18 & 19 wheel options that can run 255/30.
    Senior Member Three Rings keninblaine's Avatar
    Nov 06 2016
    Blaine, Wa
    Any reason you skipped the Hartmann wheels that fit?
    2018 RS3 Florett Silver
    Veteran Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    Quote Originally Posted by Hugonzalez01 View Post
    BBS FS at 19.8 lbs for a 19x8.5"....forged Alu.
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
    Jan 24 2013
    Quote Originally Posted by keninblaine View Post
    Didn’t skip just waiting on complete info from manufacturers.
    I’ll be adding different manufacturers lines as they are confirmed. Due to the tight tolerances involved here it seems several won’t confirm fitment until they get an RS3 in house to measure up. And I’m trying to be careful to post only sure bets per their recommendations.
    Jan 24 2013
    Quote Originally Posted by shivaswrath View Post
    Most Neuspeeds in 18” to 19” are in the 20lb range too iirc.
    FS are niiiiiice
    Aug 05 2017
    North Carolina
    Here is a link to my post regarding Neuspeed wheels in 19x9. I have been very pleased with these wheels even though they are a bit heavier than promised. Note since this post, I have checked my scale and it is accurate, so I believe that these wheels do in fact weigh 22 lbs.
    http://www.audizine.com/forum/showth...19x9-45-photos
    Cheers
    Jan 24 2013
    Added
    Hartmann fitments
    without spacers
    Jan 24 2013
    Added
    Hartmann fitments
    WITH spacers
    Nov 06 2016
    Blaine, Wa
    Added
    Hartmann fitments
    WITH spacers
    Thanks very much for putting this together in one thread. It should prove very useful for many folks, including me.
    It is curious that there are numerous wheels (incl Hartman) that specify 235 or 245 tires on their 8.5" and 9" rims, but not 255 tires. Since the wheels mostly have lower offsets (such as 38) it is difficult to understand why the 255 tires would be an issue, since the tires are further out from the car than the 255 tires are with the factory 46mm offsets. Can anyone explain why this is?
    Also, I'm considering the Neuspeed RSe 102 in Hyper Black but am not sure what it looks like. Appears to be like a black chrome finish. Curious if anyone has any Neuspeed wheels in that finish and if they could describe or provide photos of them.
    Veteran Member Three Rings Konrad's Avatar
    Nov 10 2014
    Vancouver
    Thanks for posting this.
    Jan 24 2013
    My pleasure.
    So those are manufacturer recommended tire sizes. Ideal configuration to use with the rim on this platform. Since that is kind of the theme here I chose to include the tire size if they provided it. Over time that may change on the manufacturer level and I’m sure it will on the functional level as people exercise trial and error.
    Neuspeeds hyper black is my favorite finish they have. I’ll see what pics I have and post them.
    - - - Updated - - -
    Quote Originally Posted by Konrad View Post
    Jan 24 2013
    I don't have anything handy mounted on audi's but heres Neuspeeds hyper black finish examples
