Originally Posted by
RogerSteadman
Hi all, I wish my first post was under better circumstances, but I bought my first S4 3 months ago, and I went to change the oil today, bought all the tools got under car and the drain plug Allen wrench hole is stripped so bad its just a smooth circle, any ideas on what to do, thanks in advance i'm freaking out Audi dealer wont touch it because they did not strip it and dont want to be liable for someone elses mistake.
model is a 2012 S4
Nothing to worry about at all. Buy a new OEM replacement drain plug. Then get yourself an EZ out
(Amazon link). The tool is like a bit for a screwdriver/drill, but they come in different sizes and are threaded backwards, so the more you twist it counter-clockwise (to remove the stripped screw), the more it bites into the stripped screw. If you don't have them, they're a tool everyone should have, so consider this a good excuse to buy them.
Shouldn't take more than a few minutes and you'll be all set. And that's what the dealer or a mechanic would do if you brought it to them. Not a big deal for them either.
Good luck!
