Results 1 to 9 of 9
    Dec 30 2014
    Severn, MD
    Front upper/lower control arms
    I have a 2012 A6 w/ 91K miles. Took it to the stealership (thought it was still under warranty, but ran out in Oct) because the front end was making noise. Was told the control arm bushings are starting to wear. Is this normal on these cars? Also, doesn't look like to big of a job to do it yourself, but wasn't sure. Has anyone done this before? Was going to use the 034 Motorsport kit. Was also planning on adding either lowering springs or coil overs since I was going to have it apart. Any recommendation on this? Was looking at either H&R springs or the KW Height Adjustable Lowering Spring Kit.
    Thanks in advance for any info/advice you can provide!
    Tim
    Severn, MD
    Nov 18 2014
    2001A6,2013A7 C5 allroad
    Hartford
    Every Audi needs control arms lol
    They eat them up at an insane rate.
    At least on the older ones
    Mar 06 2016
    Knoxville, TN
    I just installed the 034 Density Line Lower Control Arms on my car. My car called for the M12 kit per their fitment guide however after ordering and exchanging, the M14 kit is what fit my car. 034 is working to update their fitment guide for these kits. Mine is a 2012 A6 Quattro Prestige with Sport Pkg. with a build date of 3/12. I installed the EuroCode LYKT adjustable upper control arms so I could have more negative camber. I am extremely happy with the purchase and ease of install. If you hammer the ball joints out they pop apart pretty easy with a good hammer. Much easier than trying to use a ball joint separator. You want to make sure you snug down the bolts on the bushing end of the control arms with the weight of the car on the suspension. This means moving your jack stands under the spindle so the suspension is compressed before tightening those bolts. Otherwise the rubber bushings will bind and cause premature failure. With the rear of the car on ramps you can have the front suspension on jack stands and keep the car level. You can tighten the ball joint nuts with the suspension unloaded no problem. Also, if purchasing through FCP Euro you have a lifetime warranty on parts. You will need to first remove the undercarriage insulation trays, sub frame brace, fender liners, and heat shields. Another thing that causes front end noise in our cars is the upper strut brace bolts needing to be re-tourqued. Hope this helps.
    [IMG]20180122_224456 by LANE GORDON, on Flickr[/IMG]
    M12 vs M14 ball joint in curved lower arms.
    [IMG]20171127_215717 by LANE GORDON, on Flickr[/IMG]
    [IMG]20171127_215752(1) by LANE GORDON, on Flickr[/IMG]
    [IMG]20180122_232021 by LANE GORDON, on Flickr[/IMG]
    [IMG]20180122_232014 by LANE GORDON, on Flickr[/IMG]
    [IMG]20180122_231705 by LANE GORDON, on Flickr[/IMG]
    [IMG]20180123_201758 by LANE GORDON, on Flickr[/IMG]
    [IMG]20180123_183843 by LANE GORDON, on Flickr[/IMG]
    [IMG]20180123_222358 by LANE GORDON, on Flickr[/IMG]
    2018 Q7 Prestige, APR Stg2, Airmatic Links, Vossen HF-4T 22x10.5
    SOLD / '12 A6 3.0T Prestige / Uni DP 93/e30 tune / p3u tcu tune / Iabed Fluidampr 3.2 PR / Jokerz ported SC / Iabed Porsche TB / Merc HX / 034/AEM intake / JHM v2 test pipes / AWE Touring with modified AWE DPs, Vibrant/GESI cats & MF 11386 / 20 x 9 VMR v702s / Yokohama Advan Sport A/S 275/35/20 / EC sways & Alu Kreuz / 034 LCAs, motor mounts & inserts / LYKT UCAs / RS6 Grill / rear lip spoiler / Bose + Bazooka 10" Sub
    Active Member One Ring dorin_82's Avatar
    Apr 23 2015
    2014 VW Passat ( current) 2012 VW CC ( sold) 2001 Audi A6 2.7tt ( lost in fire )
    Hollywood, FL
    Just having the same issue.....2012 A7, by the 034 fitment guide, I need the M12. After receiving and installing, I need the M14 ball joints . They sent me a replacement , but wrong arms when received ( instead of the curved ones, they shipped the front lower ones ).
    Waiting for another shipment I guess...
    Sent from my SM-N950U using Audizine mobile app
    Mar 06 2016
    Knoxville, TN
    Quote Originally Posted by dorin_82 View Post
    I went through an extensive amount of contact including pictures to help them update their fitment guides so that other customers would not have the same headache I did. It is unfortunate they are still causing headaches for their customers. Our cars are left up on jack stands often times while they ship the right products.
    Mar 14 2019
    Miami, FL
    To the OP,
    How did you put those jack stands? I assume they are on the car's jack points right? If so from where did you lift the car in order to put the jack stands where they are?
    Thanks...
    Veteran Member Three Rings choy188's Avatar
    Jun 02 2019
    2019 S5 Sportback, 2022 Polestar 2; Sold: 2012 A6 3.0T, 2006 A6 4.2
    Danville, CA
    Quote Originally Posted by FastLane1000 View Post
    I know this is an old thread but what were your findings regarding the build dates?
    Sent from my SM-N986U1 using Tapatalk
    2019 S5 Sportback Prestige | Navarra Blue Metallic | Black | Options: Sport Package, Dynamic Steering, Cold/Warm Weather Package, Black Optics, Direct TPMS Retrofit
    Sold: 2012 A6 Prestige | Oolong Gray Metallic | Titanium Gray | Options: Innovation Pack, Cold Weather Pack | Mods: Lane Assist Retrofit, Injen Intake, 034 Stage 1 ECU+TCU
    Sold: 2006 A6 4.2 | Atlas Gray Metallic | Platinum | Options: Technology Pack, Cold Weather Pack
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    034 also told me I needed the M12 kit which i got , only to learn I needed the m14 kit. The time and money that cost me ended up costing them a customer.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Jun 02 2019
    Danville, CA
    Quote Originally Posted by RedS-line View Post
    I looked it up on other parts websites and the build date ended up being split at 8/15/2011 rather than the date in 2012 they gave. Kind of a headache for those of us with MY12 cars
