Results 1 to 11 of 11
    Aug 13 2015
    LA
    1.8T AMB Coil Pack Wiring Harness 1J0971658L DIY Install
    Hello all.
    I tackled this coil pack wiring harness problem using these posts:
    Help. 1.8t B6 Coil Pack Harness - OEM Replacement.
    OEM / Usp Motorsports Coil Harness - Installed [pictures]
    Volkswagen Technical Bulletin - 97-04-02 vw.tb.97-04-02.pdf
    A4 Mods: ECU Removal
    I read these posts and they were EXTREMELY helpful, but some things were lacking, mainly pictures. Hopefully, this will make it a whole lot easier.
    The full coil pack wiring harness from the ECU to the COIL PACKS is cheaper than the shorter coil pack connection made from the back of the engine.
    Inexpensive wiring harness (<$75) = 8 hours of work
    Expensive wiring harness (>$200) = 1-2 hours of work
    Oh, well, I got the wiring harness from Euro Parts for $65. So, I went with a reliable connection all the way back to the ECU.
    Be forewarned. You won't be able to remove the OLD coil pack wiring harness since it is integrated with the main wiring harness. You'll end up having to cap some wires like you would with a house electrical wiring. (See pictures at the end.)
    If you want something cleaner, use the shortened wiring harness.
    TOOLS:
    • 1J0971658L Coil Pack Wiring Harness ($65)
    • 16mm socket plus ratchet
    • Crescent wrench
    • Flathead screwdriver
    • T-30 Torx socket or bit
    • Dremel with disc (reinforced, better)
    • 90 degree angled pick
    • Box cutter
    • Lisle 56500 Terminal Tool ($10)
    • Electrical Tape
    • Electrical Butts
    • Wire Crimper
    • Wire Stripper
    • Electrical tape
    • Electrical caps
    • Zip ties
    • 18 gauge wire
    • Ring connector
    • Magnifying glass. (To read the wire numbers on the connector)
    • Multimeter (optional) to check the continuity of your old coil pack from PIN 3 of each coil pack to the ECU
    1) Remove rain tray and rubber gasket
    Disconnect NEGATIVE battery terminal
    Remove driver's side wiper.
    -Pry off black plastic cap with flathead screwdriver
    -Use 16mm socket to remove nut
    -Wiggle and pull on the wiper til it comes off
    2) Remove ECU plastic cover
    -Remove (5) T-30 Torx screws with socket or bit
    -One is directly below the driver's wiper, which is why you removed it.
    -There's a metal clip near the fender which needs to be removed or it will go flying off.
    -Once all the screws are removed
    -Pull up on the back off the cover first to clear the ECU and the wiring. It takes quite a bit of force and finagling to get it off.
    3) Remove ECU
    -Remove black metal bracket by using a flathead screwdriver and pushing down and tilting it to clear the lock
    -Repeat on the other side. Should just come off though.
    -Use a Dremel with a disc to cut slots into the security bolts
    -I used an impact driver with a flathead bit to remove the security bolts which are secured with LOCTITE. (It came out easily with the impact driver but you can use a large flathead screwdriver.)
    -Pull the ECU out from the metal sleeve
    4) Remove the left BLACK connector by pulling on the Pi-shaped prongs.
    -Pull off the connector from the back of the ECU
    Use the 90 degree angled pick to pull on the purple locks on either end of the female side of the BLACK connector.
    Once the purple locks are removed, you can pull the WHITE (TOP) and BLACK (BOTTOM) connectors from the back of the housing.
    5) Prepping the NEW coil pack harness: Refer to the Volkswagen Technical Bulletin above.
    -CUT OFF the SPEED SENSOR 40mm from the Y (POINT A). Cut wires, Pull insulation past wire strands, Fold wire back on itself, Tape it.
    -Save the Metallic Cover for later to use as a heat shield for the NEW COIL PACK WIRES at the Valve Cover (You don't have to, that's what I did.)
    -POINT B: Cut off the connectors from the 3 wires (#2 - Black/White; #3 - White/Blue; #7 - BROWN (GROUND). Pull insulation past wire strands on #2 and #3, Fold wire back on itself, Tape it.
    -Save the BROWN #7 wire to ground it later near the bottom of the battery.
    -CUT OFF the black plug from the Purple / Black wire. This will be connected to the THICK RED / GREEN wire you removed from the ECU with the Terminal Tool
    6) Route the NEW coil pack wiring harness starting from the COIL PACKS leading back to the ECU.
    7) Punch a hole through the rubber grommet where the original harness enters with a box cutter.
    -Push through the ends of the NEW wires through that opening.
    8) DEPIN the THICK RED/GREEN WIRE #121 from the LARGE BLACK CONNECTOR using the Lisle Terminal Tool. Push in from the female side and pull the wire out from the back.
    - My NEW #121 wire was BLACK w/PURPLE stripe. Plug it into the back.
    WHITE CONNECTOR - ORIGINAL WIRES:
    TOP ROW:
    106 - WHITE
    107 - YELLOW
    108 - BLACK
    109 - ***EMPTY***
    110 - ***EMPTY***
    111 - ***EMPTY***
    112 - ***EMPTY***
    113 - ***EMPTY***
    BOTTOM ROW:
    98 - WHITE w/BLACK stripe
    99 - BROWN w/GREEN stripe
    100 - ***EMPTY***
    101 - GRAY w/BLUE stripe
    **102 - GRAY NEW (PURPLE w/BLACK stripe)
    **103 - GRAY w/BLACK stripe NEW (BROWN w/BLACK stripe)
    104 - YELLOW w/WHITE stripe
    105 - BROWN w/BLACK stripe
    BLACK CONNECTOR - ORIGINAL WIRES:
    TOP ROW:
    90 - ***EMPTY***
    91 - ***EMPTY***
    92 - ***EMPTY***
    93 - ***EMPTY***
    **94 - BROWN w/BLACK stripe NEW (PURPLE w/BLACK stripe)
    **95 - GRAY w/BROWN stripe NEW (BLACK w/LIGHT GREEN stripe)
    96 - BLACK w/GREEN stripe
    97 - GRAY w/GREEN stripe
    BOTTOM ROW:
    82 - GRAY
    83 - GREEN w/PURPLE stripe
    84 - PURPLE w/YELLOW stripe
    85 - BLACK w/RED stripe
    86 - GREEN w/GRAY stripe
    87 - ***EMPTY***
    88 - GRAY w/PURPLE stripe
    89 - BROWN w/BLUE stripe
    I listed these as you would see them plugged into the ECU, which is upside down.
    It's REALLY difficult to see the numbers unless you have a magnifying glass. If the colors are the same on yours then it should be a lot easier.
    The NEW wires may be different on yours.
    9) DEPIN from the THIN WHITE CONNECTOR #102 (GRAY) and #103 (GRAY w/BLACK stripe) using the 90 degree angled pick (as shown) and pull out.
    -Insert the new wires into their respective slots
    10) DEPIN from the THIN BLACK CONNECTOR #94 (BROWN w/BLACK stripe) and #95 (GRAY w/BROWN stripe)
    11) Plug the WHITE CONNECTOR into the TOP SLOT.
    12) Plug the BLACK CONNECTOR into the BOTTOM SLOT.
    13) Make sure the CONNECTORS are fully seated and the pins are oriented correctly. PIN #121 was tilted as were the middle wires when I installed it. You have to press the wires from the back to push the PINS forward. Once you have the PURPLE LOCKS put in place it should be properly seated.
    13) Snap the back cover onto the LARGE BLACK CONNECTOR you just reassembled. ZIP TIE IT like you found it.
    14) Seat the connector. Lock it in. Slip the ECU back into the metal sleeve. Put the two screws back in.
    15) Cover with tape the ends of the OLD Coil Pack triggers. You could cut them. They're dead. I just taped them.
    16) Connect with electrical butts (2) and a piece of wire the OLD #121 THICK wire (RED w/GREEN stripe) to the THICK BLACK w/PURPLE stripe wire that you just cut off the fat plastic connector. The RED/GREEN wire had CONSTANT POSITIVE 12 VOLT POWER. (IT WAS NOT SWITCHED as other posts indicated.) This wire needed to be connected. Otherwise, the car would not start! Tuck the wires neatly so they don't stick out when you replace the plastic ECU cover.
    -REPLACE the metal bracket that goes over the ECU
    -REPLACE the black plastic ECU cover. Screw the (5) T-30 Torx screws back on.
    The red/green wire at the ECU and leading to the coilpacks are still constant +12V, not switchable.
    17) Connect an electrical butt and a piece of wire from the #7 BROWN wire and lead it to the GROUND connector located next to the NEGATIVE side of the battery. You can crimp a ring to the end of the wire and attach it to the GROUND Post.
    POINT OF NO RETURN
    18) Cut the OLD COIL PACK HARNESS at a point near the back of the engine. Don't cut it too much. You'll need to cap the (4) RED / GREEN wires because those are CONSTANT and still ON! I capped them with electrical caps. and taped it and secured it with Zip ties to the main wiring harness.
    19) Plug in the NEW COIL PACK harness into the COIL PACKS. Ground the harness to the valve cover.
    20) RECONNECT the NEGATIVE battery cable.
    After disconnecting the battery, your remote may not work properly, nor will your windows
    Key in door. Hold lock button for 5-10 seconds.
    Key in ignition. Turn to accessory position. Hold lock button for 5-10 seconds.
    Windows:
    Push down and hold. Pull up and hold. Repeat for each window. One touch should work now.
    21) START your car. Enjoy!
    Jan 24 2010
    Paramus,NJ USA
    Hate to bring a old thread back for no reason.But it just seems very confusing.I get that pins 94,95,102,103 and 121 got directly to the ecu.Brown wire is a chassis ground no big deal there.But where are you tapping for ignition on??On the big purple/black wire???
    Ziddy Autowerks
    Aug 13 2015
    LA
    Just saw your post. (Sorry for late reply.)
    Yes, see bullet 16) and the 4th to last photo. I connected the BLACK/PURPLE wire to the RED/GREEN wire.
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by cleoo View Post
    Yes I did get it sorted out.However I was able to run the harness through the black rubber boot without issues making for a neater install.
    Ziddy Autowerks
    May 29 2017
    Fort Collins, CO
    Has anyone here tried this on a B5? I have a 2001 A4 AWM Quattro Avant that I'm getting ready to attempt this on. Had the ignition wires repaired a few years back, now the car runs like shit, lot's of missing. I've narrowed it down to ignition wiring, I improved it a bit by rejoining some of the wire splices. So, I have one of these wiring harnesses now. The motronic connector should basically be the same (pin types) between the B5 and B6 right?
    I have wiring diagrams, so I should be fine with verifying the pin locations on the motronic connectors, etc...
    Any other gotcha's that I should be concerned about?
    What pin removal tools would be ideal?
    Is that Lisle 56500 tool capable of removing any type of pin in the motronic connectors or just the big pins?
    May 29 2017
    Fort Collins, CO
    Why doesn't the red/green need to be plugged into pin 121 on the ECM? Isn't that a power supply to the ECM and the coils?
    The red/green wire is switched by the ignition switch.
    I'm suspecting the red/green wire needs to be connected to the ECM so the ECM knows the ignition switch was turned on.....no?
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by mobildetroit View Post
    I'm in the middle of swapping in the USP harness and wondering the same. I have a black wire with a 121 label and also the wire w/ the connector on it which is black. Trying to read thru and figure out what to do with those two.
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Oct 12 2018
    B5 S4 Avant 2.7t 6MT
    I am in the process replacing the coil pack harness and this is what I am planning once all material arrives.
    I did not like the USP harness so I ordered TXL wire, Tesa cloth tape, Techflex PET wire tubing, and heat-resistance PVC tubing to rework the harness. Just keeping coil connectors at this point.
    To clean up the wiring-in-of-harness to be more OEM. These photos show the termination ends points of pin 1 and pin 2.
    Helpful because pin 121 (12v) from the ECM connector is not removed. You can connect the new pin 1 coil wires into the OEM power supply pin121 (red-green) terminal end and the same with pin 2 coil wire to ECM/ ground (brown).
    With work, the extra unused wire from the original harness can be removed. Maybe providing room in the OEM loom to push new wires through?
    I believe this wiring method of installation will keep OEM short-circuit safeguards vs. a separate power source used if a short occurs.
    I can confirm all this next week. Attachment 285083Attachment 285084Attachment 285085
    Sent from my motorola one zoom using Audizine Forum mobile app
    AKA: gjweyman
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Just wanted to necro bump this and say, if you don't properly connect the chassis ground, you will get engine knock, timing pull, rev hang, and codes from the ECU for open circuit on every coil, even though the motor will run and drive almost normally otherwise.
    I guess it's due to the ecu not able to correctly charge and release the coil's spark.
    Anyway, make sure to ground it properly, unlike me, but if you want to know what an engine knocking on boost sounds like, leave that ground off (definitely don't do this).
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Sep 10 2021
    Pennsylvania
    I am doing this job now. I am a bit confused about bullet 16. It looks like I should connect the wire I removed from pin 121 to the wire from the big black connector that I needed to cut off. OK, I got it so far. My confusion is that you state that wire 121 has 12 volts all the time (not switched). The instructions that came with the harness say to connect the black connector to a switched 12v source (circuit 15).
    I am reading this correctly that I should deviate from the harness instructions, right?
    By the way, thank you so much for putting this together. I had a lot of apprehension about doing this job, and finding this DIY has alleviated that. Once I connect the two wires here and ground the other one that needs modifying, I'll be done!
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by SideMirror View Post
    From what I remember when doing mine w/ the USP harness, the new black wire that replaces the red/green on the ECM is tied to it earlier in the harness somehow. I bought another harness and stripped it apart and found this to be the case so I left it like that.
    B6 USP Avant
    AMB + GSX28RS
