Page 1 of 3 123 LastLast
Results 1 to 40 of 88
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Becker Test Pipe Review
    A few people have asked about these test pipes from ebay. They're the lowest priced test pipes so far. The price fluctuates for some reason, but i got my set for $268 before Xmas.
    Construction is very similar to the others, however, one section is mandrel bent, so there is one less weld than the others. The flange also has a complete weld instead of just a tack weld like other's.
    I used the same O2 spacers from Amazon that everyone else seems to use. I also installed new O2 sensors just for good measure.
    My mechanic was able to get it done it 3 hours and only had to drop to tranny a bit.
    Here are a few shots:
    So my passenger side cat was in very good condition, but the driver side was a different story. Most likely due to an intercooler leak on that side a few months ago.
    Driver side:
    Passenger side:
    Installed:
    FAQs:
    - Yes it's louder at WOT. Cruising is The same stock. Of course this will differ depending on your current exhaust. I'm running oem S7 mufflers.
    - Yes you can now smell fuel, but only from the rear. I don't smell like fuel. With the windows up you can't smell it.
    - No rattles at any RPM
    - I've only put 20 miles on them, but no CEL so far
    - Yes they're worth it
    - Did I mention they're louder at WOT?
    - My car is a C7 A7, so they do fit even though the ebay ad doesn't list it
    Big thanks to Danny at HTL Motorsports for the install!
    Established Member Two Rings Tidi0x's Avatar
    Nov 21 2017
    Ashburn, Va
    Quote Originally Posted by ntsantos View Post
    FAQs:
    This is awesome, to see. So just lowering the trans a bit was all that was necessary to get them out? I have been looking to see someone install these. What stage are you? Some people have been wanting someone to Dyno to compare test pipes to headers.
    Sent from my PH-1 using Tapatalk
    13' B8.5 | APR DP | Bilstein PSS10 | 034 Engine Mounts | ECS Exhaust | ECS Carbon kit | MercRacing cooler | BBS CI-R | Avanti Hybris
    Dec 06 2015
    San Ramon, CA
    Stage 2ish, maybe 3. Running a 3.4 PR with race file.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Thanks for your review
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Nov 21 2017
    Ashburn, Va
    whos the tuner?
    Dec 06 2015
    San Ramon, CA
    EPL
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Is there a way to tell if cats are going bad other than grey smoke out the back?
    Jul 02 2017
    2012 VW GTI, 2015 Nissan GT-R Premium
    Smyrna, DE
    Driver side:
    Passenger side:
    Installed:
    FAQs:
    Thank you, this is great! Couple questions:
    Just to be certain, what spacers are you referring to?
    What’s your thought on the exhaust note on the otherwise-stock exhaust? Raspy at WOT?
    Lastly, is the stock exhaust sufficient in flow once cats are eliminated? (at dual pulley boost levels?) I don’t recall seeing this being specifically discussed anywhere, though it probably has.
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by SGR View Post
    90 Degree Angled O2 Check Engine Light CEL Fix Oxygen Spacer Exhaust Extension - 4 Piece Kit https://www.amazon.com/dp/B00B1U6I54..._bVsBAbJJS782E
    Those are the spacers above.
    Slight rasp with stock exhaust. There have been various discussions on exhaust, and the consensus is aftermarket exhaust is pretty much for sound only, no matter how modified your car is. There are a few low 11 second 3.0t cars are running stock exhaust.
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by 4Rings3Liters View Post
    You'll start getting a "low cat efficiency" CEL as wells as the gray dust ring around the exhaust tip.
    Jul 04 2008
    York, PA
    Would EGTs be higher or anything I can check in VAG com?
    Dec 06 2015
    San Ramon, CA
    There was a very minor EGT difference between the good cat and the bad cat.
    Veteran Member Four Rings scmtkings4's Avatar
    Oct 06 2016
    Brooklyn, NY
    Any plans on running cats elsewhere along your exhaust?
    2014 S5
    AWE Touring Exhaust l ECS Intake l EPL Dual Pulley 93 l AMS Alpha Cooler
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by scmtkings4 View Post
    Eventually, after race season. I'll either weld GESI cats right on the AWE dps, or use JHMs solution if they're competitively priced.
    Oct 06 2016
    Brooklyn, NY
    Cool, post up pics if you decide to go the weld route. Would be interested to see where you have them placed
    2014 S5
    Jan 06 2018
    Aprilia RSV4, Triumph Thunderbird
    Ohio
    Thanks for sharing this. Subscribed as the puff of smoke out my pipes tonight was an ominous sign of things to come.
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    can you drop a link where you got them
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by maty360414 View Post
    I'm not a computer right now, just type in "Becker 3.0T" in ebay.
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    Nice review. Interested to see how these will effect your 1/4 mile times. Have you done anything else with the car since going 11.7?
    2013 S4 S-tronic - 3.47 PR // EPL DP ECU/TCU tune // PLM hx // APR intake // Jokerz Blower // Headers // Ice box // iABED TB // Autotech HPFP // RS7 LPFP
    11.186 @ 123.35
    1993 URS4 - GT3071R - EFI Express Tuned - Gutted
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    I've removed cats from a smaller and a larger displacement engine (both stand alone EMS). Neither had much of a gas smell. It makes me wonder if these cars are way rich at idle and low RPM. If that is the case, we should be able have a tuner lean it out, a bit.
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by kelseysautobody View Post
    I sent my blower back to Jokerz for a re-port, still waiting on it before I hit the track again. I was going to Install the 203mm crank pulley but i stripped the damn hex head screws. I've also been testing with Nitrous with some positive results. Hoping for mid to low 11s without NOS.
    Mar 03 2009
    Cape Cod, MA
    Nice. Looking forward to seeing what it runs.
    So you had one of the early ported blowers and you’re sending it back for additional porting? If this is the case I’m interested in how much you gain from it. I have one of the first blowers and now that the Chaos port is out I feel like I’m missing out.
    11.186 @ 123.35
    Jan 03 2018
    South Carolina
    Any results yet?
    2014 S7
    2012 Oolong Grey A7 | DP 91-104 tune| Merc Hx| 57/187mm| Cat delete| Magnaflow x-pipe| ported SC TOTALED
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by jazzyjay18 View Post
    Any results yet?
    Haven't had time to hot the track lately. I will update that I still haven't had a CEL yet! I do get a few readiness values that are out of spec, so it may or may not pass emissions. I'm due for a smog, so I'm going to try it anyway. But not having a CEL with no cats is pretty awesome.
    Jan 03 2018
    South Carolina
    Did your butt dyno feel a difference after the install?
    2014 S7
    Dec 06 2015
    San Ramon, CA
    Yes, for sure, especially since I had the bad Cat.
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Do you smell the fumes from the test pipes instead of the cat? Curious if they have the same effect as headers. I know the noise level will increase. I have AWE track with factory DPs.
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by A.C. View Post
    You can smell the fumes a lot more from outside the car.
    Veteran Member Three Rings toastsauce's Avatar
    Apr 08 2014
    Jersey City, NJ
    Do you think these can be installed onto test pipes after the pipes are already installed?
    Sent from my SM-G950U using Tapatalk
    2014 Audi S5
    034 Stage 2+ ECU & TCU | 75mm TB | Ported SC | Roc Euro CAI | Merc Hx | B12 Pro Kit | 034 Rear Sway + Links | 034 Motor Mounts
    JHM Test Pipes | EC Alu Kruez | CR-15 | EC T&B Diff & Trans Mounts | USP SS Brake Lines | EBC Yellow Stuff Pad | BP Slotted & Drilled Rotors
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    I smell exhaust fumes with my windows down even with my HFC. I've got a strong nose for that kind of thing though.
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Ntsantos great review ,
    I’ve noticed that you’re here locally (bay Area ) . When you say drop the tranny do you mean they actually remove it or just unbolt it enough to give them room.? Also do you mind PM me the average installation cost that you went through? And lastly I’m running AWE touring exhaust I would want get down pipes as well , do you see any conflict I might run it too if with match test pipes on to different downpipes ?
    Thanks
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by Rodizzle View Post
    Thanks
    The bolts at the bottom of the tranny were just loosened to give a couple inches to remove the cats. I'm running AWE dp, so they fit.
    Jun 17 2015
    Bayarea
    Thanks bud , i think I’m just gonna have to visit that shop and cop me them test pipes after all .
    Jan 03 2018
    South Carolina
    Did you do a retune after install?
    2014 S7
    Dec 06 2015
    San Ramon, CA
    No. There's no need for one performance wise. Some tuners may offer a catless tune just to keep the CELs away.
    Jun 17 2015
    Bayarea
    How are those o2 spacers working for u ? I got my test pipes in but The spaces you link on Amazon or unfortunately not available. I end up picking up different kind. Just waiting for some other parts to have installed the same day.
    Dec 06 2015
    San Ramon, CA
    They work well. I'm only using the 90deg part, none of the straight extensions. I honestly think you can get away with just a shallow straight spacer, and not get the CEL. I may play around with it later. They're easy to access from the engine bay.
    Oct 13 2015
    SoFlo
    Did you try the other ways?
    Is the best way still the 90 degree angle without the extensions?
    Oct 06 2012
    Minnie Snowda
    I just had these installed also. I noticed a power increase especially during highway driving. I have stock exhaust. I do have exhaust rattle so I’ll have the shop take a look at it when I have them install o2 spacers. I tried using the vibrant straight spacers but it would not fit. I had to get some 90 degree spacers.
    Jun 17 2015
    Bayarea
    I couldn’t find the same spacers of the OP , but I bought these
    Dewhel O2 oxygen sensor angled extender spacer 90 degree 02 bung extension M18 X 1.5 Stainless Steel https://www.amazon.com/dp/B07875QF9V?ref=yo_pop_ma_swf
    Iv had them for 500 miles and on the track with no codes !
