Page 1 of 3 123 LastLast
Results 1 to 40 of 109
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Anyone break the 300k mile mark in here?
    Hey Guys,
    As the post says, looking to see if any B6s (1.8T specifically) can last up to 300k? I see quite a few of you in the ~200k ranges, so that's good to know. And, I know good ol' Fletcher (CyberMPG) is way past 300K miles on his car...so I know it can be done.
    Who else here has broken the 300k mile mark?
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Apr 15 2014
    Ottawa/Gatineau Canada
    Im 300k +. KM
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Road salt pretty much destroys vehicles where I live. Generally starts around 100k and then by 200k your holding the hood, doors, and trunk down with bungy cords and praying the gas tank doesn't fall out.
    They're not scared of you. They're scared of what you represent to 'em.
    Senior Member Three Rings IndoReef's Avatar
    May 20 2015
    2018 VW GTI Autobahn
    Ontario/Canada
    We have road salt and brine like nuts here. The body holds up decent but you need to be on top of cleaning it and such. I'm at 302 000 km
    Sent from my SM-A520W using Audizine mobile app
    Winter: 02 B6 1.8T quattro 01A Brilliant Black, Gutted Stock Cat, 2.5" stainless custom exhaust to 4 inch tips,DSMIC's
    USP Front lower Valance, REVO Stage 1, Solo Werks S1 Coilovers,B6 S4 Front Brakes, Forge Hybrid Diverter Valve, SAI & AC Delete
    Summer:2018 MK7.5 GTI AutoBahn
    Mar 13 2009
    MK3 VR6
    Houston, TX
    I'm at 170k mi on my 05. 299K on my MK3 Gti VR6 though. I've been driving it lately while doing some work on the Audi so looking forward to hitting the 300k mile mark soon. They say the odometer turns back to 0 so we'll see :)
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Mar 05 2013
    CA
    May 20 2015
    Ontario/Canada
    Quote Originally Posted by Spike00513 View Post
    Enjoyed That!
    Dec 25 2004
    Earth
    289,000
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Active Member One Ring Muchwin's Avatar
    Jan 18 2018
    Washington
    192,000 miles so I'm close to 200,000
    Apr 01 2005
    one wagon one truck
    Michigan
    292,--- low compression in two cylinders so the show is basically done.
    2009 Audi A4 avant, ECS CAI, Malone stage 2 tune, etc.
    1995 Mazda Miata Montego blue with tan
    2003 A4 1.8tqms Mototec Cold air intake, USP door Blades, GIAC software and bigger injectors. - Gone
    Jan 24 2010
    Paramus,NJ USA
    460k miles and still going.Original motor and transmission.
    Ziddy Autowerks
    Jul 14 2009
    Pasadena
    Quote Originally Posted by EuroxS4 View Post
    Holy shit that is impressive
    IG: @matthewee
    Feb 12 2004
    Austin, Texas
    Agreed with Matt! Any major repairs or anything you've had to be on top of to keep it going that long?
    Nice work!
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by A4orce84 View Post
    Nice work!
    Mostly oil changes,timing belts,water pumps,coolant flushes,replacement of most rubber hoses on the engine and pcv system,coolant flanges,coils, plugs,oil feed line,turbo,valve cover and tensioner gaskets,fuel pump, clutches and some wiring repairs.Mostly common repairs on this particular car.Everything still works.However the goal is to hit 500k then swap out the engine for the one I have on the stand waiting patiently.
    Ziddy Autowerks
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by jaustin View Post
    Could you share what your compression numbers are?
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Veteran Member Four Rings frenchyofcp's Avatar
    Aug 19 2011
    Folsom, California
    260k and running like a champ. Original motor, trans and even the turbo.
    USP Club Member #138
    Daily: B7 Quartz Ti Avant 6MT
    S4 Project: B8 Glacier/ BO Prestige Avant
    Garage Queen: B5 Casa S4 6MT
    Ladies: B9 Moonlight / BO Q5
    Apr 07 2011
    224k miles on original motor(replaced head with AWM) and transmission.
    Jun 30 2008
    Erie, Pennsylvania
    Very impressive.
    Is that original piston rings and cylinder head? It would be very interesting to get compression/leakdown specs on it with all those miles.
    And how many times has the oil pickup screen been cleaned out?
    Jan 24 2010
    Paramus,NJ USA
    Very impressive.
    All original engine,turbo was replaced other than that.It has original pistons,rings you name it.Head as well.I dont think the compression and leak down specs will be anything impressive.I can tell the engine has a some blowby.If I get the chance I will do a compression and leak down test and post the results.Oil pick up was cleaned at 60k.However I do my oil changes religiously every 3k miles.Always used castol edge 5w40 never had any issues with oil pressure or lights.
    Ziddy Autowerks
    Established Member Two Rings ralleyquattro's Avatar
    Feb 02 2013
    Toronto/Canada
    386,000km on 1.8T which is about 240,000mi
    Martin Pajak
    http://www.quattro.ca
    2004 Audi A4 quattro avant 1.8T UPS 6-speed
    Jun 19 2012
    06’ A8L 4.2L, 04' 330CIC, 91’ Corrado 1.8T, 10' Q5 3.2L,
    Long Island, NY
    My car is an odometer fraud car with a minimum offset of 31k (bought at 144 on cluster, 175k was last service record on carfax). Just hit 170k so that puts me over the 200k mark now.
    I replaced the motor due to a bad head gasket. Gasket could have easily been changed, but I had a super low mile motor w/ IE rods in it sitting around.
    Other major service:
    Clutch kit
    turbo CHRA replacement - due to noise not burning oil.
    front suspension complete rebuild
    partial rear suspension rebuild
    coolant system refresh
    Exhaust Y pipe failed twice. Replaced with turboback.
    heater core- this job wasn't bad, but it was abnormal so I figured I'd mention it.
    Due to spending 1k to 1.5k recently on this thing I plan on keeping it another 2 years even though I'm very bored of it. Probably one of the best VAG cars I've owned to date as far as comfort, drivability and reliability go. I feel like half the repair work I've performed I did not have to, but I'm a preventative maintenance guy. I noticed my control arms had slop in them when I was doing something else so I replaced them all. The car drives the same as before. The original motor and clutch could have stayed in it just grabbed high which I hated.
    Small things are starting to get to me. My passenger S4 seat back is loose so the headrest shakes at idle (drives me insane). The drivers S4 seat adjustable thigh support moves ever so slightly and I notice it pretty much everyday. Passenger H&R Strut needs to be replaced (it rattles)- I just have to make the time to do it. The brand new Myle rotors I put on 3k ago have warped already, but FCP sent me free replacements, etc, etc - sorry for the rant!
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Hey Guys,
    Thanks,
    Asif
    Just rolled past 366k miles.
    Very impressed with the other high miles. My original motor gave out at 273k miles and replaced it with a factory refreshed engine while also having the transmission rebuilt and gears cryo treated. It's been a lot of leak hunts and fixes (oil and coolant) over the past two years. Oh... my miles are actually about 2k higher. Had the ABS controller out to be rebuilt. While it was out, I continued driving, but had no functional speedometer, odometer, trip odometer, cruise control, etc.
    USP CLUB MEMBER #34
    Senior Member Three Rings Cousinphil's Avatar
    Jan 29 2015
    1954 Ford Jubilee Tractor,1986 Ford Diesel Tractor, 2006 GMC One Ton Dump, 1986 Nissan Flatbed Truck
    East Blue Hill Maine
    300,000 miles is 482,803 kilometers. 460,000 miles is 740,298 km. The distance to the moon and back is 477,800 miles.
    2004 A4 Avant 1.8T 6 Speed 120,000 miles Summer
    2005 A4 Avant 3.0 Tiptronic 80,000 miles Spring and Fall
    2005 A4 Avant 1.8T Tiptronic 105,000 miles Winter Tires
    Feb 24 2015
    San Jose, CA
    260k, just finished intake and PCV rebuild myself with new silicone tubes (4x3mm reinforced, not easy to find) all the way to new BPV. Purrs like new :)
    Jan 24 2010
    Paramus,NJ USA
    504k on it now,original motor and transmission. I'm getting ready to swap engines soon. As mentioned previously I will do a compression and leak down test before I pull the engine. I will also say that the vehicle in question has been daily driven by me and me only for the last 14 years and alot of the miles are hard miles on the car. What are hard miles you say?? Well its a good mix or highway and town driving probably around 60-40 split mostly under heavy load at all times whenever possible. I drive this car hard like I stole it, I only use premium fuel nothing else and oil changes are done every 3k with synthetic oil. It is stock however I beat it to death every day. So I am curious what the results will be. I will be posting those hopefully in this thread. Stay tuned probably around late march to mid april I hope. As long as all my parts to complete the swap fit right and everything goes off without any issues.
    Ziddy Autowerks
    May 14 2018
    Bristol
    Mine is on 165,000 miles and apart from a front wing it’s really good condition, running fine also
    Which is around 265,000km
    Veteran Member Three Rings g huns's Avatar
    Aug 13 2012
    Lexus RX350
    Wakarusa, Indiana
    200K. Thanks to road salt and the newer 'brine' road treatments, the body will never make it to 300K.
    Rust bubbling under drivers front fender at top of wheel arch and getting bad on the rear passenger fender at the very bottom.
    2012 A6 3.0 Premium Plus w/Sport Package
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by g huns View Post
    Having recently removed front fenders from a parts car, I recently posted about the cause of front fender rusting. In short, get those splash shields out and power wash in there. Then take the fenders off and treat the rusted areas if they're still salvageable.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Mar 05 2013
    CA
    if it's not that, then sun damage will fade the paint and require a respray.
    FWIW, a used front fender can be had for $50.
    Jun 27 2011
    Quote Originally Posted by BumblebVR6 View Post
    Those 12V Vr6s are such awesome engines. I have such great memories of my wife's old Mk3 GLX 5-speed. At least until the rust started to make all the trim fall off.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    196k here, with 60k of those miles put on by me over the last 4ish years. I also drive my car hard, and it doesn't skip a beat (aside from a crank sensor and wastegate diaphragm). I chalk it up to maintenance by me and the previous owner, who as far as I know was an Audi enthusiast as well and did most of the mods when the car was only a few years old (APR 1+ tune, ECS RA4 clutch kit, stainless lines, etc).
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Mar 05 2013
    CA
    170k mi, it hasn't even broken in yet
    except for materials such as plastic and rubber. They are breaking.
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    205K mi on my '05 3.0, zero rust or corrosion (no snow, hardly any rain).
    Jan 29 2015
    My '05 has yet to crack 100,000 miles. Body is in great shape.
    Junior Member Two Rings fsteve's Avatar
    Mar 22 2018
    MA
    273k on mine.
    2004 Audi A4 1.8TQM, Audi Exclusive Imola Yellow 1 of 3
    268k and counting...
    Veteran Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Ellicott City, MD
    I'm at 147k.
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    I am nearly there, 297k on my 2003 3.0 6mt. original clutch!
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    170k on mine. 400whp and going strong!
    Veteran Member Three Rings PSI NRG's Avatar
    Feb 24 2008
    I'm at 249K+. Original motor lasted until 200K until I lost oil pressure from a clogged pickup tube. I got 180K+ out of the original clutch. 220K+ out of the original trans before the center diff blew. The original turbo lasted about 215K+ Still on the original fuel pump, prop shaft, and rear end.
    I've had my ups and downs with the vehicle but I've learned so much and I still get enjoyment out of it. I just wish the midwest climate was nicer on the body/chassis as it's starting to show some exterior rust and the underside is getting pretty rough.
    Mar 05 2013
    CA
    Quote Originally Posted by PSI NRG View Post
    This is scaring me
    I didn't know this could happen. Did it just clog on it's own?
    Is running a quality synthetic oil such as Rotella T6 not good enough to slowly clean the engine?
    The pickup tube is cheap and servicing that seems like a good idea, but I hear removing the upper oil pan or something is really difficult, possibly requiring a subframe drop and engine support from above
    Did not know center diffs can go bad. I hear running different wear amount tires can wear it out, such as front bald tires and rear new tires.
