Results 1 to 18 of 18
    Established Member Two Rings FaisalJ's Avatar
    May 19 2009
    London
    Wet Trackday in the TT (vid)
    Little vid from last Saturday at Donington
    https://youtu.be/YkrLXbNAtK4
    Bit more info on the car:
    - Mk1 TT 225
    - Interior mostly stripped, and half cage
    - Cobra Bucket seats and harnesses
    - ST XA coil overs
    - R32 rear ARB
    - Cookbot front arm bushes
    - Powertrak haldex insert
    - THS dogbone Mount
    - Project silver adjustable rear tie arms and front camber plates
    - S2000 K&N cone filter
    - Badger5 induction heat shield
    - Badger5 TIP
    - Custom remap to ~265bhp
    - mocal oil cooler
    - Forge FMIC
    - Milltek DP and full exhaust (decat)
    - Seat Leon cupra R front calipers (4pot)
    - Carbotech XP10 pads
    - Cookbot 300mm S4 rear disc conversion
    - j-hooked discs all round
    - Motul RBF600 brake fluid
    - Liquid TT gauge
    - 2 sets of lightweight 17" wheels with different tyres: Nankang NS2R semi slicks for the dry, and continental sportcontact 5's for the wet
    2007 RS4 B7 Avant
    Phantom Black | Black Optics | MRC Stage 2 | KW V3 coilovers | H&R ARBs | JC Weldfab Full Exhaust | GTechniq crystal serum coating | Alcantara/leather interior retrim | Privacy Glass all round | Pioneer Apple Carplay HU, JL amp and sub, Focal components | LEDs all round | Modified Xenons -Clear lens, 6000K bulbs, black internals |
    Jan 03 2017
    Delaware
    Quote Originally Posted by FaisalJ View Post
    - Mk1 TT 225
    - ST XA coil overs
    - R32 rear ARB
    - THS dogbone Mount
    - Badger5 TIP
    - mocal oil cooler
    - Forge FMIC
    - Liquid TT gauge
    Nice... Haldex ftw indeed.
    May 19 2009
    London
    I should point out - without the powertrak insert, the haldex is a complete liability on track. Completely unpredictable and will change its mind on the power split mid-corner. With the insert the haldex immediately goes to 50:50 F:R split as soon as it detects any slip.
    A step up from that would be a haldex controller - which gives full control over the split. I may look into that down the line.
    2007 RS4 B7 Avant
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Very nice!
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Active Member Two Rings Collie's Avatar
    Jun 24 2017
    Vanocuver
    That and Brands are my two favourite circuits!
    Sent from my LG-H815 using Audizine mobile app
    B7 A4 6M 2.0T Avant S-Line. Unitronic Stage 2 HPFP, CTS Turbo silicone hoses & turbo back. CTS Catch can. GFB DV.
    May 19 2009
    London
    Quote Originally Posted by Collie View Post
    I take it you mean the Brands GP layout? I’ve only done the Indy layout which is fun but so short!
    2007 RS4 B7 Avant
    Senior Member Two Rings tjasielski's Avatar
    Jan 17 2010
    I’ve always been curious about the powertrak insert. It seems like a economical upgrade over the hpa controller and even the UM Haldex flashes available currently.
    How long have you been running the insert and have you found any adverse effects of its use? Any binding in slow turns or premature Haldex wear?
    Also, do you notice more front tire wear with the increase camber ? I know many people run as much camber as possible in the front in exchange for grip as well as the removal of the front sway bar, have you done this as well?
    2000 Audi 2.8 Quattro, 18x8.5" Rs4 Reps, 235/40/18 Continental SportContact 2, K&N CAI, Magnaflow 14862, In.Pro Mirror Covers, Rs4 Grille, Chrome Lower Grill, M3 Lip, DDM 55w 6000k HID Lows, DDM 35w 8000k HID Fogs, LED Interior, LED License Plate, Chrome Gauge Rings [WTB: PES Supercharger
    May 19 2009
    London
    Quote Originally Posted by tjasielski View Post
    So I’ve had the insert less than a year, and the car only gets used for trackdays (including the journey to and from, usually 4-5hr roundtrip).
    I’ve noticed no ill effects (with the caveat noted above - the car doesn’t get used a lot), and haven’t read about others having issues with the powertrak either. The biggest issue was getting it fitted! My usual specialist tried to swap the insert with the controller in situ and couldn’t manage it - so I ended up buying a second hand controller, fitting the powertrak to that, and then swapping the whole controller.
    On the positive side - it makes a huge difference in the wet. You can feel it kick in when you apply power out of a corner, and help get the power down.
    I can imagine that the HPA would be even better and I may still look at other options apart from the powertrak in future.
    My front camber is only -2.5; not that extreme, and I would’ve liked it to be closer to -3.5! Probably need to lower the ride height. Again, given the limited use of the car - I’ve not noticed any adverse tyre wear.
    I still have the OEM front anti-roll bar, and a R32 rear (slightly thicker than OEM). My coilovers probably aren’t suitable for removing the front ARB (spring rates not high enough). The compromise I chose was to not go for a really hard suspension setup, as I have to drive the car to and from the track, and I have a few hours driving to do on those journeys. I’m too much of a wuss! I even kept the climate control!
    2007 RS4 B7 Avant
    Established Member Two Rings jpatterson's Avatar
    Mar 16 2009
    Trussville, AL
    Nice driving too! Love the rain. Makes you feel like Superman
    My old car is set up very similar to yours except my steering wheel is on the left. here’s a lap of Road Atlanta a few years ( and one engine) back.
    J. Patterson
    Alabama
    2015 S5 Prestige 6 spd manual
    2015 Q7 TDI Premium Plus (with the emissions fix)
    2001 TT 225 Quattro Coupe (some mods and track time :-) )
    2001 TT 225 Quattro Roadster ( pure stock)
    May 19 2009
    London
    Quote Originally Posted by jpatterson View Post
    That looks a very technical circuit! Good job
    2007 RS4 B7 Avant
    Jun 24 2017
    Vanocuver
    Oh, not sure of the difference. Whatever BTCC belts around on!
    Oct 06 2014
    Cleveland, OH
    That video was great! So polite, using turn indicators to communicate "pass me" !
    May 19 2009
    London
    Quote Originally Posted by SR7D1 View Post
    Standard track etiquette here in the UK. Not everyone does it, but they should - helps prevent any hairy situations. We’re not racing afterall - all just having fun at our own pace
    2007 RS4 B7 Avant
    Oct 06 2014
    Cleveland, OH
    I think that is awesome. Here in the States with HPDE, we usually run 3 levels of skill: Beginner, Intermediate and Advanced. The 1st two require the driver being overtaken, to hand signal what side they want to be passed on. So we always run with windows down, rain or shine, so we can give hand gestures. Advanced usually does NOT have to signal permission to pass/overtake. Seems a bit primitive compared to your method. LOL.
    Mar 11 2007
    Colorado Springs
    Nice driving.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    May 19 2009
    London
    That sounds, er, insane... ! So a beginner track driver, as well as learning the track, braking points, cornering technique etc, has to take a hand off the wheel and stick it out of the window???
    The way it works here is there’s generally mixed abilities on track, but everyone has to go to the track briefing (or you’re not allowed on track), and plays by the same rules. You are only allowed to pass on straights, and on either the left or right depending on the track (e.g. at Donington only allowed to overtake on the left). No overtaking in braking zones. If you’re blocking someone getting past, you’ll get a blue flag or lights at first, but then pulled off the track if you continue. Black flag for dangerous overtaking.
    This system seems to work well IMO.
    2007 RS4 B7 Avant
    Oct 06 2014
    Cleveland, OH
    Yes. Pretty much summed up well in your post. We too have mixed skill, even in each group. We also have track meeting at 8AM for everyone and review rules, passing zones and flags. Advanced can pass anywhere on the track, everyone else has passing areas, always on the straights, but not all straights. The car overtaking, in all situations, must come "off-line", so that means the car being overtaken, points them left or right, but off-line.
    Senior Member Two Rings Teeguzi's Avatar
    Nov 07 2009
    2000 TT 180Q
    Los Altos, CA
    I'll throw my wet TT track day vid in as well. Some clubs (Audi Club Golden Gate in this instance) on the Left Coast will allow windows up when the rain gets heavy enough. Turn signals are used to indicate "OK to Pass". All passes were made to left in pre-determined zones, the car doing the passing leaves line. Please disregard side ways action through T10; trail braking in rain will introduce ABS and create fun.
    Cheers!
    2000 TTQC: REVO Stage 1, Injen CAI, CTS Turbo FMIC, MM DV, MM Upper & Lower Rear Control Arms, MM Club Sport Coilovers, VFE Mounts, 15mm Spacers, Gruvenpart End Links, SPC Camber Kit, Haldex Comp Controller, StopTech 355mm Front Brakes, 225 Slotted Rear Rotors, 18" Ultraleggeras, 42DD 3" Turbo Back exhaust, Raxles.
