Results 1 to 40 of 68
    Established Member Two Rings Blue S4's Avatar
    Apr 23 2014
    Northern IL
    Towing with the Q5 or SQ5
    I am looking for some real-world feedback from those of you who tow with your Q5. I've searched tirelessly and most of the information available is extremely outdated, incomplete, or simply conjecture. I would like some solid feedback from those who you have actually pulled something behind your Q.
    We're considering a 2014-15 Q5 and heavily leaning towards a TDI with the S-Line package and Sport Seats. I would also consider the 3.0T and the SQ5 would pair great with my B8.5 S4, but I think the diesel is going to be a better option if we can find the right one. It will primarily be a daily driver, split between city and highway miles, with towing capabilities on the weekends. Our towing trips vary from short city trips to 60 mile country backroad and highway pulls.
    We're looking to pull a 1999 Toyota Epic X22 wakeboard boat that weighs in at 4400 pounds fully loaded with the trailer. The trailer is dual axle with surge brakes. I know this is right at the US towing capacity limits of 4400 pounds, but well under the Euro limit. This is where I'm looking for feedback, good, bad, or otherwise. I've heard every opinion under the sun about towing at capacity, but am looking for some real examples of what works and what doesn't specifically for the Q.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    I can't speak for the diesel, but my 3.0T tows a Uhaul car-hauler with an R8, which is around 4500 lbs, combined.
    No breaking, transmission, or power issues. 80MPH no problem.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I've not tried to tow anything heavier than a 14 foot skiff with 25 hp outboard, but the Q5 trailer towing package for the Q5 (which I got OEM) is rated for 4,400 pounds trailer load, 440 pounds on the ball. The OEM package does have the proper plug and all the light connections for most trailers. The diesel or the 3.0T ought to handle that kind of weight. Not so sure about the 2.0T with your max or near max load.
    There is a plug up under the dash that is used for your electronic brake controller. You will probably have to source a different plug adapter for it. I don't recall which adapter, but I needed one for using the Tekonsha Podigy I already had and use with a larger vehicle to tow a 12,000 loaded equipment trailer. Wouldn't dare to hitch that to the Q5, though.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Senior Member Three Rings jsilas's Avatar
    Dec 29 2015
    2016 S6, 2021 SQ5, 2016 R1M, 2004 R1
    WA, PNW
    I can't unfortunately provide you feedback on that load specifically, but I towed regularly with both my 2016 SQ5 (before it was totaled) and with my 2018 SQ5 and they handle my trailer like a dream. My trailer is a 7' x 14' single-axle enclosed utility trailer, which weighs approximately 3,000lbs fully laden (motorcycles, fuel, tools, generator, etc). I'm really impressed at how well these rigs tow.
    2016 S6 | Mythos / Black | Prestige | Sport | Carbon | Black Optic | Bang & Olufsen | Driver Assistance | OEM RS7 Turbos | APR Stage III ECU/TCU | CoD delete | APR DPs | SRM Intakes | CETE AVC | CETE ASC V2 | H&R Sway Bars | VIM | CarPlay | Opti-Coat Pro+ | XPEL Ultimate PPF | XPEL ceramic tint
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    Quote Originally Posted by SQive View Post
    show off! i use mine to tow a uhaul full of gold bars, but that only weighed 1000 kilos.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Veteran Member Three Rings mkasperzak's Avatar
    Jan 16 2014
    Transition Patrol Carbon, Transition PBJ, Commencal Furious
    I bet you get zero looks on the highway. zero. none.
    I am considering eventually installing a tow hook, but it would just be for a snowmobile and trailer.. nowhere near the load.
    2014 SQ5, BBS CH-R, GIAC DP 183 Fluidampr/57 AWE SC(3.18 PR), AWE Touring, Roc-Euro, Bilstein PSS10, 034 HX/X-Brace/RSB/Inserts, Thule Edge/Flow, Kuat Trio
    Build Thread / IG @thebird_sq5
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Bumping for tow bar set ups and installs... looking to get one on one of our 2 Q5s... need it mainly for our northshore bike rack. But also awesome to see people have hauled some decent weight with the Q5... I shouldn't tell the fiancee she will want a trailer sooner haha.
    - - - Updated - - -
    I'm gonna need to see pictures of this man.
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
    Junior Member Two Rings
    Feb 10 2017
    Z06
    Bumping for interest as well. I might need to start towing my mountain sled around. Maybe my Z06 depending on future track plans/locations.
    Established Member Two Rings simplesez's Avatar
    Mar 29 2018
    Colorado
    Quote Originally Posted by Das Ponto View Post
    - - - Updated - - -
    video with northshore rack. Good stuff
    Mar 29 2018
    Colorado
    I installed the hitch to tow my Summit X 163 around. No problem no matter what the Q5 model for a single snowmobile.
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    [QUOTE=simplesez;13052956]video with northshore rack. Good stuff
    Oh RPI... always killing it. I think we are going to install it on our 2018 Q5, but it looks like you have to trim the bumper for it to fit... is that the same for the Gen 1 Q's??
    Ponto
    Apr 26 2014
    DFW
    I just looked, but I don't have one with everything hitched up and tied down.
    Now, I'm talking about the Q7 (see sig), which is also a 3.0T, and the only one with the tow package.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    I know I'm in the minority and at least one of youse (likely the Tejas guy, but me profile?) will bust my balls for this, but.... Man, I just wouldn't do it. At least not beyond a really light trailer with an even lighter tongue weight for a very short distance. Beyond that I want body-on-frame, a long wheelbase, a ridiculous transmission cooler, and a drivetrain that emphasizes low-end torque.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Well get one next time!!
    Quote Originally Posted by VroomVroom View Post
    Silly Muricans... people in Europe tow all the time with a lot smaller vehicles lol.
    My host family in Denmark pulled a small sailboat with their 1st Gen 2 door A3 even... My old 3.2 A3 had a towing capacity of close to 4,000lbs....
    Don't always need supersized truck to tow anything.
    But our old Ram 2500 cummins with the long box was a dream at pulling just because of the long wheel base and well 6 in a row ready to tow.
    Ponto
    Jan 03 2007
    SF Bay Area, CA
    And it's the Canadian guy first out of the gate busting chops...who knew?
    All good points. Especially the Muricans one. Sigh.
    But I digress. People in Europe also really know how to drive. Of course, they also tow ... what ... 750 pounds max? :) Being honest, can you imagine towing two tons in an A3...uphill, in traffic? White knuckles (even without crosswinds), red brakes, and a dead transmission.
    I'll go back to my cave now.
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Hahah I didn't disagree that your points weren't valid... of course a big truck is gonna tow nicer. But not necessary as our friends over the waters show... A lot of Caravans get hauled all over the place by cars and small suvs etc... or like an RS6 Avant....
    Some of the caravans (camper in freedom terms) get upwards of 4k lbs for sure.
    No need to go back to your cave, not your fault you were born american.
    Ponto
    Jan 03 2007
    SF Bay Area, CA
    What the hell is that chatter from my attic? Pipe down up there, I tell you.
    MmmmmmmmmmRS6Avantmmmmmmmmmmmmm.
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Back on topic... OEM Audi hitch $1800 Plus install...
    Anyone rocked the Stealth Hitches? 415 USD. Can likely install myself.
    Ponto
    Junior Member Two Rings Eur0fr3sh's Avatar
    Apr 26 2017
    DMV
    https://www.etrailer.com/Trailer-Hit...=2015201545178
    Just installed the Draw Tite last weekend. It was inexpensive-AF and IIRC, it seems to have a close resemblance to the OEM one (through google images).
    Cake to install.
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Quote Originally Posted by Eur0fr3sh View Post
    Cake to install.
    That indicates a 2015? Looking at the 2018's as they apparently have a ton of shit in the bumpers now with regards to all the sensors...
    Ponto
    Apr 28 2018
    Pensacola, FL
    I have a 2018 Q5 and had a Reese hitch (same as OEM I think) installed for $325. You must make a small cut in the lower bumper, but it's well beneath the hitch and unnoticeable. I had to wire it myself as the Audi dealer said they couldn't wire it because they didn't install it. I used the Tekonsha Zero Contact Interface connector, which took me about 1.5 hours to install. With this install, you don't cut or splice any wires and it doesn't interfere with the car's electrical system. You'll need trim tools to make this an easier job and lessen the risk of damaging the panels.
    I did not add a brake controller, which you may need for heavy loads. I towed two motorcycles in an enclosed trailer over 3,500 miles with no issues-smooth and steady ride.
    My only problem now is that I have to replace the lower brake light assembly due to a cracked lens and it appears the hitch covers up the screw holding the light modular in place. Anyone ever replaced the lower light with a hitch installed?
    Bob
    2018 Q5
    Mar 06 2008
    17 Allrroad, KTM 530 and K1300r
    Rhill
    I have a 2015 SQ5 and installed the Invisi/Execuhitch. It's great. Works flawlessly. I tow a jet ski and a small open trailer. No problems.
    2017 SQ5 Silver Teknic
    2017 Allroad Silver
    2008 A4 Avante 6 spd SOLD
    2009 STI Hatch SOLD
    Mar 21 2018
    Raleigh
    Quote Originally Posted by 04turbowagon View Post
    I havent done a hitch before. Can you provide a quick run down of whats needed?
    Does the hitch bolt into factory locations or do things need to be drilled?
    How is the wiring handled?
    Does the car need to be updated by audi or vcds or anything?
    Dec 13 2013
    2016 SQ5, 2016 Jeep Cherokee, 2018 S5
    Ladera Ranch, CA
    Any detailed instructions on how to connect the brake lights wires? I'm going to attempt to install one myself...crossing fingers. Thanks
    Apr 01 2015
    2017 SQ5
    Raleigh NC
    Dec 06 2008
    04 A4 Avant 1.8t quattro tiptronic
    Orangeville
    I chose the factory tow hitch because it doesnt sit below the rear valance like most aftermarket ones. I bought it on ecstuning for a couple hundred less than what dealer wanted for it. It comes with the wiring too.
    I know it's a lot more expensive than aftermarket ones, but I love how discrete it is.
    I dont get it. If the rating is 4400/440 why would you be worried?
    Are you worried when transporting 5 people since its rated for that? We damn well know that the ratings are done to be safe no matter how you drive it and what you do with that car.
    It's not rated 4400 lbs downhill.
    But, enough with my rant. I tow an enclosed snowmobile trailer 17' long with 3 sleds in it. Trailer is 1700lbs sleds about 1500 plus another 2-400 lbs of gear. And 4 dudes riding in the car with luggage for a week.
    Does it look pretty? NO. It drops the back quite a bit. But it works flawlessly. No brake controller either.
    Like with everything, you use it harder than normal, do the maintenance more often.
    Here is the best picture I have right now.
    Regarding the install, it's a breeze. 3 hours taking it easy.
    It replaces the aluminum crash bar.
    Sent from my SM-G950W using Tapatalk
    Quartz Grey '10 A4 Avant Quattro 2.0 Prestige - 267000 KM
    Red '04 A4 Avant Quattro 1.8T tiptronic - 264000 KM
    Ice Silver 2014 Q5 premium - 64000 KM
    Today is a gift, that's why it's called THE PRESENT!
    Life is not about the amount of breaths you take. It is the moments that take your breath away.
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Quote Originally Posted by justforfun View Post
    I'm going to assume you have a 2016.
    Go to the following page and at the bottom download the "Rack Installation Instructions", page 9 has the location and color coding. I installed their 2018 version on my SQ5 with similar instructions.
    Dec 13 2013
    Ladera Ranch, CA
    Quote Originally Posted by windyctyaudi View Post
    Outstanding, i'm going to attempt to do the install myself. Thank you!
    Mar 06 2008
    Rhill
    Quote Originally Posted by billm0066 View Post
    Installed into factory location and use their adapter for connecting the lights. I don't have the Audi adapter and the only issue I have is that the warning systems turn off when I'm towing. It depends on the load though. The jet ski causes this, but my foldable trailer with two KTM's on it doesn't. No VCDS update done.
    2017 Allroad Silver
    2009 STI Hatch SOLD
    Aug 13 2017
    Phoenix AZ
    +1
    I would not do it. That's one of the reasons I bought a Cayenne diesel.
    Wife has her SQ5 and we don't tow with it. My Cayenne tows either RS6 just fine on my Featherlight trailer.
    Apr 26 2014
    DFW
    Dammit! I just hauled it down to San Antonio and back for the ACLS state meet and although I took pictures, not a single one of them is the whole rig. Sorry.
    May 31 2016
    Mexico
    Quote Originally Posted by shannon11off View Post
    Nice! Was looking into the Yamaha AR195 myself.
    Towing 4,000 lbs in a boat will be easier then 4,000 lbs in a small RV or Box Trailer.
    2016 Q5 3.0T GIAC Stage 2, HP tuners TCU tune with help from P3U and BG SQ5, aFe 11-10121 Pro Dry S filter, 034 Throttle body hose, AWE Cold Front Heat Exchanger
    93 octane tune (0-60mph 3.90 seconds (1 ft rollout), 0-60mph 4.12 seconds, 1/4 12.31 secs @ 112.40, 0-60ft 1.90 seconds)
    Race 104 octane tune (0-60mph 3.70 seconds (1 ft rollout) , 0-60mph 3.89 seconds, 1/4 12.09 secs @ 115.34, 0-60ft 1.88 seconds)
    Feb 27 2011
    Winnipeg
    I know it's not much but I finally put some miles on towing to the lake this past weekend. I don't even notice the trailer at 115kmh. I love this thing, beats towing it with my B5S4.
    Once at the lake I used our utility trailer to haul water from the well, 250gallons and did 2 trips and it pulled that effortlessly as well.
    Sent from my Moto G (4) using Tapatalk
    Apr 01 2015
    2017 SQ5
    Raleigh NC
    May 31 2016
    Mexico
    Have you gone to a weight station to see the hitch weight?
    Also, do you have an anti-sway bar connected?
    Nov 05 2019
    Tampa
    Hoping someone will see this new post on this older thread. I bought an aftermarket hitch but nowhere am I seeing any need to have the dealership recalibrate they camera and s
    Nov 05 2019
    Tampa
    ...and sensors. Has anyone had to do that? I’ve been told that twice by local body shops. The folks I bought the Drawtight hitch from (etrailer.com) are awesome and very reputable, and they had no experience indicating that was necessary. Thanks for any experience with that anyone might have to share.
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Quote Originally Posted by Jaycofl View Post
    Coding changes that would control the rearview camera, sensors, also engine adjustments are done when you utilize the OEM trailer module which only comes with the OEM hitch kit. You can however buy it 3rd party, but it costs a bit. If you look at the thread I made, it shows what coding changes are done.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Nov 05 2019
    Tampa
    Quote Originally Posted by choppstixxx View Post
    Thank you for that quick reply. Would any of that be necessary if I’m just using the hitch for a bike rack? I’m never actually going to tow anything. I was thinking the recalibration was required because the sensors and camera may have moved a couple of millimeters in direction when the bumper was removed and subsequently reinstalled.
    Apr 24 2017
    Hilton, NY
    If that is all your "towing" with, I would not worry about adding the OEM module or even the eTrailer module. The installation process of the hitch would not affect your sensors or camera either. One thing to be aware of when using a bike carrier, do not try to open your hatch as it will come in contact with the carrier. With the OEM module, it codes things so you can't open the hatch unless the trailer wiring is disconnected. Or as with most newer bike carriers, they have "swing away" options.
