I admit. I've long been a skeptic of this product and others like it. I mean, what's the difference between using this product and just pushing your foot down a little more on the accelerator?
I can tell you that there is indeed a difference.
Installation was honestly a little painful. Reaching underneath to un-clip the harness to your gas pedal requires a lot of hand strength. I finally gave in and used pliers (and nearly damaged the wiring in the process -- be careful!). But after it's out of the socket, you literally just plug in the Sprint Booster into the socket, and then plug the accelerator cable into the Sprint Booster. The unit basically sits in between.
I started out on Sport mode (green) level 5. Put the car into D, and I can immediately feel the difference. My first thought was, "ok, so this thing is just pushing the pedal down further for me". I drove around a bit longer, then switched the unit off to do a comparison. Car felt more sluggish again (particularly from a stop). So naturally, I just pushed the pedal down more to "simulate" the Sprint Booster.
Let me tell you: It's not the same. No matter how much or how fast I pressed the pedal (short of flooring it), there was this hesitation (that we're all familiar with I'm sure) with response. You can see it in your tach. The needle doesn't move up instantly. I would guess maybe a 50ms delay.
I turned the Sprint Booster back on. Tested again. The hesitation is gone. I turned it to the lowest setting (Sport mode level 1). Still no hesitation, but feels like less throttle (almost stock level). The tach needle moves up almost instantly. Maybe 10ms delay.
I tried Race mode level 1, and could not feel any difference in throttle response, but there was definitely more throttle input.
The car feels much more enjoyable to drive now. I drove to work this morning leaving it in D the whole time. Sprint Booster at Sport level 5. The car felt different, as if it had more low-end torque. I feel like I have confidence now pulling into traffic from a dead stop, not worrying about throttle delay.
So basically, the Sprint Booster seems to remove the input delay at all levels, and incrementally adjusts the throttle input level. I found that even at Sport level 6, the car downshifted too much, even with moderate throttle input. Sport level 5 seemed perfect. It didn't change tranny behavior (unwanted downshifting), gave just a moderate increase in throttle input, and nicely improved throttle response.
Later, I will test with the car in S.
