Results 1 to 20 of 20
    Established Member Two Rings martinhnilsson's Avatar
    Oct 14 2017
    Sweden
    Restoring Fat Five wheels
    I'm restoring the fat fives that was on the car when I bought it to their original glory. They were corroded and ugly but not badly scratched or damaged.
    They have been stripped and sanded and it is now time to polish.
    Does anyone know what they were originally painted on the inside? Mine were a light gray or possibly off-white.
    Anyone else restored their fat fives? Need some inspiration:)
    Sent from my Nexus 5X using Audizine mobile app
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    moar pix!
    Oct 14 2017
    Sweden
    Another before picture
    Oct 14 2017
    Sweden
    Stripped and wirebrushed
    Oct 14 2017
    Sweden
    After a first polish
    Veteran Member Three Rings Steelerhater37's Avatar
    May 29 2017
    BMW E36(98)M3 convertible//VW B6(07)Passat
    Bel Air Maryland USA
    Holy Toledo Batman!
    Established Member Two Rings JLCampbell's Avatar
    May 15 2017
    2005 Audi allroad 2.7t, 1997 Mercedes-Benz C230, 1999 Mercedes-Benz CL600
    Quote Originally Posted by Steelerhater37 View Post
    Holy Toledo Batman!
    I'll second that!
    Current Daily: 2012 Q7 S-Line 3.0T
    Project Car: 2000 V70R Laser Blue
    GT Car: 1999 Mercedes-Benz CL600
    Junior Member Two Rings
    Jan 04 2017
    How did you polish them up so well? I have fat fives that are in similar shape and I'd be interested in knowing your process to attempt it on my own.
    Sent from my SM-G950U1 using Audizine mobile app
    Oct 14 2017
    Sweden
    Quote Originally Posted by tropheusman View Post
    I did it like this:
    1. Wire brushed everything down to bare aluminium (paint stripper had no effect on the very hard clear coat)
    2. Sanded with power drill mounted flap wheel, grit 120, 240, 320, 400, 600. Used a 20 mm diameter flap wheel for the tight corners and holes.
    3. Polished with a large power drill mounted cotton polishing disc and Autosol Metal Polish. Have gone over with polish 2 times and will do a few more passes.
    Wire brushing and sanding has taken many days but is worth it.
    To do: Finish polishing, paint inside, apply clear coat.
    Jan 04 2017
    I am going to attempt this. Thank you for the info.
    Oct 14 2017
    Sweden
    Go for it:) and let us know how it turns out.
    Senior Member Two Rings Audiudo's Avatar
    Jun 05 2009
    2003 ZX6-R
    New York
    Nice work man!
    04.A6.S-Line.Team.A.C.E.
    Established Member Two Rings DreamInRotary's Avatar
    Sep 10 2017
    2001 Allroad / 1984 RXSE7EN
    Cambridge, Minnesota
    These will look so much better than the corroded/brake dust look they all get when they age. Nice job!
    Allroad "411R0AD" Stage 2 Build - No Bolt Left Un-turned! CLICKABLE BUILD THREAD - 6sp Manual 01e - B7 RS4 Clutch Conversion - TTV SMF - EPL Stage 2 Tune - Arnott Bags - Hotchkis Sway Bars - True 3" to 3" SSAC Downpipes - 2.5" Magnaflow Exhaust - & Tons More! - Check out the build thread!
    Senior Member Three Rings Grainreaper's Avatar
    Nov 19 2016
    Lake in the Hills, Illinois
    I have a question for the rabble, I love the look of these flat 5s and was wondering if anyone knows if they will clear the rediculous giant factory calipers on my 2000 A6 2.7t.
    I see them on Craigs list all the time but have no idea if they would fit.
    Oct 14 2017
    Sweden
    Are they hp2 calipers? That's what's on my 4.2 and they fit. I actually fitted 16 inch during winter...
    Nov 19 2016
    Yes, the jumbo HP2 calipers, such a PITA to fit rims to. I see a set of four 17” wide 5 wheels with 8/32”tread snow tires for $400, those would fit? Are there different versions of these or are they the same
    Oct 14 2017
    Sweden
    There are two different models: fat fives and flat fives. I'm not actually sure which ones mine are but perhaps someone could clarify?
    Mine are 17 inch and fit fine over the hp2.
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    Quote Originally Posted by martinhnilsson View Post
    Yours are 4.2 A6 Fat Fives, which were originally unpainted. The 18" Flat Fives were original equipment on some A8s and were painted.
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
    Oct 14 2017
    Sweden
    Nov 19 2016
    So the 17” A6 wheels and the 18” A8 wheels will clear my calipers ok? So the only ones that won’t fit are the MK1 TT wheels because they were 5x100 pattern correct?
