Results 1 to 19 of 19
Thread: Carpet Removal
    Sep 02 2008
    Boonies VA
    Carpet Removal
    Does anyone know if there is a DIY to removing the carpet? Seats obviously need to come out, as does the center console (how does that come out). Assuming with the seats and console removed, the only other thing to remove is the plastic kick panels and trim that run along the sides?
    Jan 26 2017
    2008 Audi A4 Quattro
    St. Louis, Missouri
    Quote Originally Posted by naiku View Post
    Correct. You will need triple squares for both the seats and I believe the console. I did a full swap on my car. The tools for the console are relatively basic. Couple hex bolts, torx, and some screwdrivers. I'll see if I can find the guide I used
    Sent from my Pixel XL using Audizine mobile app
    Sep 11 2009
    A4 B7 2.0T MT, A4 B5 1.8 MT
    South Africa
    Quote Originally Posted by aaronfield33 View Post
    How difficult was to do the swap? And where did you get new carpet?
    Jan 26 2017
    St. Louis, Missouri
    Quote Originally Posted by marlboro View Post
    For a kid (I was 19 at the time) with not mechanical experience, it did not take that long. There's lots of guides. The hardest parts were the dashboard, the rear seats, and surprisingly the rear deck. As far as I know, there is still no guide for the rear seats or dashboard.
    I bought an enormous amount of stuff in one kit from eBay that some dude pulled out of his B7. He essentially scammed me though because he didn't include a lot of the things that the ad said he did and I didn't get around to analyzing the kit until a few months later (I was in college, kit was at home). The rest of the parts I needed came from a local Audi shop that had a boneyard. The owner WAS a cool guy that let me go up and pull the parts I needed bring them down and pay whatever for them.
    I'm not sure what your interior color is but if it's Platinum Grey I have carpet in pretty good condition. Was pulled from my car at ~50k.
    Jan 26 2017
    St. Louis, Missouri
    Oh but in general, the carpet is not glued down anywhere. You will need to remove the rear seat bottom as well as the front seats, and the center console.
    EDIT:
    This is a guide for a B6 center console removal but interior wise B6≈B7. The consoles are slightly different but I believe they mount the same.
    Sep 02 2008
    Boonies VA
    Thanks, tan interior so no need for new carpet. I need to remove it because mice have been playing havoc somewhere. Wiring from the trunk through to where it drops under the carpet looks fine.
    How flexible is the carpet? Wondering whether I can get away with removing the plastic trim along the doors, remove the driver's seat and rear seat and then fold the carpet over to inspect the wires.
    Jan 26 2017
    St. Louis, Missouri
    Fairly flexible. Not like rug flexibility but not bad. Should be able check wiring unless the wiring is under the center console.
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Jan 26 2017
    St. Louis, Missouri
    Make sure to remove the dead pedal as well.
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Message me if you need any help. I'm fully gutted so I can help on any of the parts.
    Sep 02 2008
    Boonies VA
    I believe all the wiring I want to check runs down the drivers side, I might try just folding back half of it and see if I can get away with not removing the center console and passengers seat. Just removing the drivers seat and the plastic sounds a whole lot more appealing. Debating adding some sound deadening to the floor though, so might end up removing it all anyway.
    Quote Originally Posted by yxri View Post
    Thanks, will keep that in mind. How do the B-pillars come out? From what I understand the top piece pulls out at the bottom and then down, then the bottom piece just pulls up. But, you have to remove the top piece in order to get the bottom to come out.
    White Wagon
    Oct 24 2015
    Perth, WA
    And install power and signal wires while you can!
    My respray thread
    Dec 27 2016
    Ford Lighting
    Ohio
    Carpet Removal
    Yes it's just clips. You don't need to take the entire thing out to take out the carpet.
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by Okedokey View Post
    No need, already have power and optical signal going to the trunk.
    Can you leave the top piece in? And if so, how does the bottom piece come out? Everything I had seen said to remove the lower B-pillar trim you had to remove the upper piece. If I can leave the B-pillar alone and get the carpet out then it's one less thing to remove.
    White Wagon
    Dec 27 2016
    Ford Lighting
    Ohio
    First I think you want to take the trim by the weather stripping out. those are just clipped in with metal clips. Be sure to give quick pulls as if you slowly just pry on it, it will keep the clip inside the car. After removing the trim by the feet. it should just pop off from the bottom if you pull on the B pillar.
    Sep 02 2008
    Boonies VA
    Spent some time on this today, getting the center console out was a pain. I am ready to remove the carpet, but do those plastic square pieces that sit just behind where the seat bolts down need to come off? Or are they attached to the carpet? I tried pulling and one broke (yay 12 year old brittle plastics) so stopped there.
    I did find this though...
    Fucking mice. Not yet sure on the best way to repair it, but willing to bet that is the cause of all my electrical issues.
    Jan 04 2014
    US
    Quote Originally Posted by a4lownslow View Post
    just wondering is it necessary to remove the glovebox also ?
    B6 04' A4 1.8TQ 6MT
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by uzone02 View Post
    For the carpet removal? Maybe not. I was gutting that car for a Part Out, but the glovebox can be removed in about 5 minutes. Just a few 8mm screws
    Sep 02 2008
    Boonies VA
    No need to remove the glovebox at all, the carpet does not go up behind it.
    White Wagon
