The title is pretty much says it. While driving under partial throttle with slight acceleration, the car stumbled and the tpms and parking brake faults came on. I scanned the car and the P0101 is the only fault I saw with Torque. I'll scan it latter with VCDS when I get home. The car will start, but it will quickly die if light throttle is not applied. After start-up the car will idle on its own; however, it idles rough and a little low. The MAF still provides a reading on Torque, but it looks a little low at idle. Roughly 2 g/s at idle. Right now, I'm trying to figure out if I should go ahead and order a new MAF so I can get it ASAP or if there's something else it could possibly be.
