^^ Love when companies chime in with information like that. Thank you ECS, that's huge because you guys deal with thousands of customers vs just a few of us trying to chime in.
I think I bought most of my parts from ecs. Some may have been from Rock Auto just because it was cheaper, and im a poor man. lol
ECS, I've been pretty lucky with the car. I bought it just after it was returned from a lease program with 90k on it and 3yrs old. So, I assume most of what I have is original since I've had it for the remaining 150k miles between 90k and 240k ( Current mileage )
I can put some diy tips/info together but the biggest tip I have is have a coolant pressure tester and adapter. I did my thermostat, to proper trq specs and 20k miles later developed a big leak. Tightened down with loctite, with 20psi on the system and so far so good but that meant taking the IM off again and always runs the risk of stuff not being right. Which im now dealing with a cel and have parts on the way. Figures.
I never could figure out what our systems normal pressure is. I don't have a bentley or anything.
When I did my crossover pipe from braking it, I also did
Water Pump
Coolant Temp Sensors
Tensioner & Pulley
Idler Pulley
Serpentine belt
Upper/Lower Rad hoses(One broke so I had to)
ThermoStat
ECS Tuning Front Snub Poly Mount! Def do this!
Here's my oem snub mount vs the ECS one I put in!
Because thermostat requires Intake Manifold removal.... May as well do a carbon cleaning! I did it manually by hand but next time I would buy a media blaster from amazon.
So that also meant ordering some extra gaskets
Intake Manifold gaskets
Intake Runner Gaskets
And Honestly, If you're this deep into it you really may as well replace the Oil Filter Housing Gasket... It's all Apart and it's a cheap gasket I think $4 IIRC.
I know it sounds ridiculous but if you're this far into it... I would do Valve Cover gaskets and all 4 Solenoid O rings. ($3 Each)
This one may be debatable... I haven't even done it but wish I would have now. - I might even tell you the Rear Upper timing Chain Covers should be removed, Inspect the upper chain guards and put new rtv on the covers. Mine now leak.
My circumstance is a little different, I did all this at 212k miles so a lot of my parts and gaskets would have needed replacing within the next 50k anyway... So it was a no brainer.
