Results 1 to 29 of 29
Thread: 1st gear noise
    Established Member Two Rings modfan61's Avatar
    Feb 02 2017
    1988 Dakota 360Swap Project
    Connecticut
    1st gear noise
    Hey all, have had this noise for awhile and couldn't pin-point it. When I'm going from a stop in 1st I have a noise. Almost like a rattle. At first I thought it was power steering. It sounded just like it, but with some rattling. My power steering was making noise but that's been fixed and the noise is still there. It only happens in 1st, and seems to be louder under load (when I'm giving it some throttle). When I shift up to 2nd it goes away. There's no vibration, and I don't feel it through the shifter. It sounds almost like the cam chain would be loose but I would think that would cause the noise in every gear... any thoughts? I'm not TOO concerned by it, because I'm not in 1st very often, but it's just a bit annoying..
    Jan 05 2015
    Romania
    I also had a noise under full throttle, it sounded like a grinding noise, and it ended up to be a broken exhaust mount, which made the exhaust pipe touch the body of the car. I can't exactly imagine the noise you are describing, does it also do it when selecting the first gear, or only when running in the first gear? It might be the clutch going out, or it might be a bad gearbox mount. It's surprising how much the gearbox can move under high torque when the mount is bad.
    Feb 02 2017
    Connecticut
    It does it no matter how much throttle is applied. Even under very light throttle but still under load. I don't think it's the exhaust. That was replaced before the car was bought and there's no real clunks. Only happens when running first gear. Fortunately, isn't a long time until I shift up.
    Thinking of checking the fluid in the trans and putting in Redline MT-90. I haven't used that stuff myself, but it's what I've read is the best to use in these. I'm not sure what was put in before the car was bought
    Jan 05 2015
    Romania
    Is it a manual or auto?
    Feb 02 2017
    Connecticut
    Manual. 6spd
    Established Member Two Rings ralleyquattro's Avatar
    Feb 02 2013
    Toronto/Canada
    I have the same noise in 1st only. Like a ticking noise that increases with speed. Not present in any other gear but 1st.
    Martin Pajak
    http://www.quattro.ca
    2004 Audi A4 quattro avant 1.8T UPS 6-speed
    Feb 02 2017
    Connecticut
    Quote Originally Posted by ralleyquattro View Post
    YES. Ticking is probably a better word to use than rattling. Also has some "whining" as well that sounds like a dry power steering pump almost. Then once I go to second and it's GONE
    Nov 03 2011
    All Over!
    First gear set are scored, or teeth are chipped.
    My car is the same, on a 2003 model with an 02X 6-speed manual. It hasn’t gotten any worse, and I’m not too bothered, as I’ll be fitting a built 01E as part of my build.
    1986 Type 85 Audi 90 quattro
    Feb 02 2017
    Connecticut
    that's what I've read. That it's a chipped tooth possibly or scored or whatever. Seems fairly common.. how long has yours been noisy?
    Nov 03 2011
    All Over!
    Quote Originally Posted by modfan61 View Post
    No change since September 2016.
    Jan 05 2015
    Romania
    That's interesting, I have 2 B6s, one is a diesel, 190k miles, and the other is a 1.8t, 87000 miles, no problem with the gearbox on any of them...
    Feb 02 2017
    Connecticut
    Well that's a little re-assuring. As mentioned, it's not like I beat on 1st gear and I'm not in it very long so I'm not too worried about it where I think it'll blow the trans. It's just a little annoying with the windows down. When they're up it's not too bad
    Jun 30 2008
    Erie, Pennsylvania
    This was also a failure in the 5-speed 01A transmissions in the B5's. Usually the V6 cars (probably due to more torque). It wasn't hugely common, but it did happen. I never heard of it progressing into a full failure or anything. Just noise during first gear, some worse than others.
    An upgrade to a magnetic drain plug probably wouldn't be the worst idea - to catch the bits.
    Feb 02 2017
    Connecticut
    I'm going to order the service kit. Found it on UROTuning https://www.urotuning.com/Manual-Tra...-audi-6spd.htm. I'm not sure if ECS carries the 'kit' including the drain plug or a magnetic drain plug. My work has ECS blocked for some reason
    Feb 02 2013
    Toronto/Canada
    In my case the the 3.0 makes the noise while the 1.8T does not.
    Martin Pajak
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    From what I read, in the US the 3.0 didn't get the 02X until 2004. Did non North America countres get it earlier or was it swapped in?
    Nov 03 2011
    All Over!
    Quote Originally Posted by Kevin C View Post
    Mine was swapped in, but the donor car was also a 2003 3.0 Quattro.
    2003 was the change-over year for the 01E to 02X 6-speed manual in Europe and Australia. I’m not sure about North America and Canada, but I doubt they would be any different. North American cars were still built in Ingolstadt, Germany.
    Mar 28 2015
    Interesting, everything I have read on the vehicles imported into north america shows them as having the 01E for 2003. Looking at the option sheet on a 2003 I found on CAR-Part.com shows GBE, used unit on Ebay from a 2003 sure looks like an 01E.
    https://www.ebay.com/itm/03-Audi-A4-...p2047675.l25578847_3195_01_web.jpg
    Veteran Member Three Rings APC123's Avatar
    Feb 05 2017
    Wilmington Delaware
    If you were to put it on neutral, could you recreate the noise through whichever rpm is comes about?
    Nov 03 2011
    All Over!
    Correct.Which is why I said 2003 was the change-over year.
    Mar 28 2015
    To be clear... 2003 model year got the 01E. 2004 model year was the change over and got the 02X.
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    In the US/can, but it could have been mid year in Europe (maybe they made our cars first). If you look in ETKA it should show the VIN break
    Mar 28 2015
    Does it break by model year?
    Senior Member Two Rings Jakal's Avatar
    May 27 2016
    Michigan
    Quote Originally Posted by APC123 View Post
    THIS. I've had a grinding noise that occurs around 2k-3k, not all the time because if I give it gas and quickly rise past where it happens in the rpm it won't make a sound. I've had this noise since September 2015 and it does in fact happen even when in neutral at a stop.
    May 27 2016
    Michigan
    Mannn I mention something and everyone goes silent it seems.
    Jan 06 2009
    OP, it sounds like you are describing a chipped tooth in first gear. My 02X has sounded like that for nearly 10 years. 1 year and a bit of that has been bolted to a 2.7t with 500+ ftlbs (at the f/w) so I wouldn't worry about it. It just sounds like crap.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Feb 02 2017
    Connecticut
    Quote Originally Posted by Jakal View Post
    Mine isn't like that. Tried it over the weekend. Maybe yours is exhaust rattle?..
    Quote Originally Posted by ADCS View Post
    That's what it seems to be narrowed down to. Good to hear some assurance that I shouldn't worry about it. True though, it does just sound like crap
    May 27 2016
    Michigan
    Mine isn't like that. Tried it over the weekend. Maybe yours is exhaust rattle?...
    The notion before was that it’s a heat shield rattling but I have no idea. The whole exhaust has been changed besides the cat and it still happens.
    Feb 05 2017
    Wilmington Delaware
    Hmmm, well jakal it seems that yours isn’t gearing based. But OP, it seems that yours goes on when things are spinning. So it doesn’t make noise in neutral, only in gear. Go through the same RPM’s in each gear whilst driving and see if the noise begins then. If you are at 3.5k in 5th gear with no noise, but 3.5k in 1st with noise, then you are on to something. Try it with all the gears. Narrow it down as best you can in this fashion.
