Results 1 to 27 of 27
    Dec 29 2017
    Northern Illinois
    2016 A7 APR Stage 2 going 0-100 mph
    Hello Everyone,
    Here is a video of my 2016 A7 APR stage 2 going 0-100. Car really moves out nicely now! Can't wait to hit the track this spring and see if I can get into the 11's with this setup.
    Mar 11 2007
    Colorado Springs
    That looks pretty swift indeed. Any pulleys?
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Dec 29 2017
    Northern Illinois
    Yes, upper and lower pulley.
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    0-60 in 4.5 - 5 seconds, nice.
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
    Mar 20 2015
    McKinney,TX
    Quote Originally Posted by DocTJ View Post
    I don’t think that will get you into the 11s, but hopefully it’s quicker to 60
    I think you need to be near mid 3s to get there
    Established Member Four Rings limeypride's Avatar
    Mar 18 2017
    Snohomish
    Quote Originally Posted by Arab View Post
    Hello Everyone,
    That is seriously impressive. You've done nothing else other than APR stage 2 which I presume means the same as it does for the 4.0TT, stage 2 software + downpipes? You'll happily slay M5s and M6s with a launch like that.
    2018 ////AMG E63S in Diamond White/Nut Brown, lowered 20mm front/back, spacers, tints, EuroCharged tune
    Gone but never forgotten
    2017//RS7 Performance in Mythos Black, Audi exclusive Titanium edition w/ Akrapovic exhaust
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    Stage 2+ should be much quicker than that.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Dec 29 2017
    Northern Illinois
    Yes. I’ve clocked it in the mid low 3s several times. Stock it does 0-60 in 4.5 and I’ve added over 200hp.
    Dec 29 2017
    Northern Illinois
    No down pipes. Just pulleys and tune. I’ve left about 60hp on the table too if I do 104 octane which I will do on track day.
    Dec 29 2017
    Northern Illinois
    I got 4 flat in that video using slow motion.
    Established Member Two Rings ZChicagoS4's Avatar
    Nov 02 2013
    Chicago
    Hit the track! I’ll guess..... 12.3
    2015 Audi S7 Prestige. Bang & Olufsen, Black Optics, Night Vision, Driver Assistance, Adaptive, Alcantara Headliner, Pre Sense, Lane Assist, Cold Weather, etc.
    2017 Jeep SRT. Borla ATAK.
    2017 Wrangler Unlimited Hard Rock
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by limeypride View Post
    Stage II software + dual pulleys. No DPs
    2012 A8L 4.2
    Dec 29 2017
    Northern Illinois
    No. The stage 2 with pulleys has downpipes.
    Established Member Two Rings ehofmann's Avatar
    Dec 22 2014
    Colorado
    You have cooling upgrade?
    Dec 29 2017
    Northern Illinois
    No. Not needed until I go ultracharger. Plus being -20 here I don’t worry about cooling. Lol.
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    Hold on, why is your redline bumped up to 7400?
    Dec 29 2017
    Northern Illinois
    It’s bumped up but still shifts at factory redline. From my understanding additional transmission software is needed to get the car to actually shift that high.
    Dec 29 2017
    Northern Illinois
    For comparisons sake here is a stock s7 0-80. Looks like I beat him by 1.5-2 seconds.
    https://youtu.be/mM9kLxPFACk
    Dec 29 2017
    Northern Illinois
    And here is an rs7 0-100. Looks like he beats me by around a second.
    So I’m somewhere between the 2 for straighline speed with current mods.
    https://youtu.be/LJw-PrRUNSY
    Oct 02 2005
    The Moon
    That is incorrect. A stock S6/S7 is running ~9 second 0-100mph. He'll beat you, albeit not by much.
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    This is also incorrect.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    I’m not sure whats wrong with that car but mine went 0-100 in about 7.5 seconds bone stock -Stage 1 on 104 it did it as fast as 5.9 seconds.
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Oct 02 2005
    The Moon
    Quote Originally Posted by cobrario View Post
    RS7's are silly fast.
    Did you ever run the 1/4 tuned on pump (93)? I'm trying to better gauge everyday performance.
    Oct 28 2014
    Northern VA
    Quote Originally Posted by p3u View Post
    I haven’t but will soon- I’ve been experimenting with Ethanol blends and will make some passes that way before I switch to 104 in April- I think I can run 10.5X’s at low 130’s on E20ish but will report back the results either way
    2018 Ara Blue RS3
    Oct 02 2005
    The Moon
    I haven’t but will soon- I’ve been experimenting with Ethanol blends and will make some passes that way before I switch to 104 in April- will report back the results
    I look forward to hearing the results! I need convincing if you know what I mean :)
    Oct 28 2014
    Northern VA
    I’ll help any way I can 😉
    2018 Ara Blue RS3
