Results 1 to 17 of 17
    Established Member Two Rings alvintoro01's Avatar
    Mar 26 2016
    Georgia
    Oil Filter Housing Gasket Sealer?
    I'm changing out my oil filter housing gasket and oil cooler gasket. I am wondering what compound would be recommended or that you guys have used for this that works? I have looked around and some people have said Permatex Ultra Black... But it says it's a gasket maker. What difference would it be a to use a gasket maker vs sealer?
    Sent from my SM-G955U using Tapatalk
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Same thing I believe. I used Permatex Ultra black to seal up my sunroof delete panel.
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by alvintoro01 View Post
    You do not use any gasket maker or RTV when replacing these.. and to save yourself future headache just replace the whole housing. 90$ from ECS https://www.ecstuning.com/b-uro-part...6f115397h~uro/ and this has both gaskets pre installed. I’ve used it a few times in the past with no issues, and doing another replacement this weekend. Might even include a filter too, can’t remember.
    Mar 26 2016
    Georgia
    Quote Originally Posted by a4lownslow View Post
    Well damn, didn't think the whole housing would be that cheap. I spent the much on oem gaskets afraid the cheap after market gasket wouldn't be no good.
    So no sealant or gasket maker used? Just clean everything good and replace gasket?
    Veteran Member Four Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    I would stick to OEM when it come to the housing. I know it's expensive but it's not something you want to be doing twice.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Yeah price isn’t bad at all. Granted it’s not OEM, but Works just the same.. And a lot cheaper.
    No sealant. Just wipe down engine block and oil cooler surface with a clean rag, and a shot of brake clean
    Aug 20 2014
    Doylestown PA
    I wouldn't say it works the same. I just went through replacing a coolant flange and a window regulator most likely because they were aftermarket. Now I can't prove that is why they failed so soon, but most likely. The coolant flange lasted 2 years and the window regulator lasted a year. I went OEM this time and I would wager to say they last much longer this time around.
    Oct 23 2015
    Australia
    I re-installed my OEM ( wasn't leaking previously ) using NO sealant but new gasket.No leaks.That's the way to go but make sure mating surface on block is scotch brited and residue removed,no oils,no sealant and torqued evenly and to spec.
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Mar 01 2016
    San Diego/CA
    No compound needed. Gaskets are enough. Just stick with OEM housing.
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    Just OEM
    Sent from my iPhone using Tapatalk Pro
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by klrider44 View Post
    The part itself works the exact same.. and I am just sharing my experience. Maybe it won’t last quite as long as OEM, but only time will tell. Out of the 3 I’ve used over the years they’re holding up just fine, so to me there’s no reason to spend triple the price for OEM when it comes to this.
    Whichever brand OP decides, he’ll have no issues.
    Senior Member Two Rings 4Ring's Avatar
    Oct 08 2010
    Just bought the housing assembly as mine was disintegrated in one area and leaking oil. Cheapest I could find for OEM: https://www.ebay.com/itm/VW-VOLKSWAG...19.m1438.l2649
    Mar 26 2016
    Georgia
    Yeh I ended up buying the $90 housing off of Ecs. Old gasket was so hard trying to pry it out I ended up cracking the housing. So far no leaks.
    Looks exactly the same as oem, don't see no difference as why it would not last as long, I did use the oem gaskets that I had originally bought instead of the ones it comes with.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Glad it worked out for you! I replaced another housing last week, fixed my leak.
    Oct 08 2010
    Quote Originally Posted by 4Ring View Post
    turns out this housing assembly is missing the sensor - otherwise it's an identical part... nonetheless, incorrect and i apologize for posting this link. Somebody else posted it and I used it thinking it was good to go. Unfortunately that wasn't the case.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    The sensor is not missing, its a separate part that will never be included when purchasing the housing. Doesn’t matter if you buy it from eBay or Audi dealership.
    Oct 08 2010
    no shit? thanks for the clarification
