Results 1 to 4 of 4
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    C7 - A6 Jack and Stand Placement for Wheel Swap
    Hey guys,
    I just got a 2018 A6 (Competition and PP packages) on Tuesday and my winter wheels and tires are being delivered shortly. Hence, I've got to do the wheel swap this weekend. I'm new to Audi and have only looked under the A6 one time. So, I've got a couple questions.
    Background:
    In order to swap wheels on one side of my old BMW, I'd normally use a floor jack, hockey puck (or jacking point adapter) and two jack stands. Essentially, I'd lift the whole side of the BMW using floor jack/adapter at the front jack-point which is similar (but rectangular) to Audi's cylindrical jack-point. Then, I'd slide a stand under the rear jack point AND another stand under the front central jacking point to support the whole front end. I don't see a central point for the front on the A6, but I want TWO support points while I'm working on the front in the highly unlikely event the floor jack fails while I'm under/near the car. I know it's silly, but when I was a kid, I actually had a car fall off one of those old scrappy jacks that connect to bumpers. I got a away from it as it was happening AND I had my spare wheel under the frame as a precaution. Since then, I absolutely will not be under or next to any portion of a car not supported by stands.
    Questions:
    (1) Is there a central jack-point/support under the A6 I can access without pulling off all the underside plastic panels? On the BMW, that central point protruded through a cut-out in the plastic, but I don't see anything similar on the A6.
    (2) I assume I should remove the plastic inserts near the jack-points on the A6 before I lift the car so that I don't damage the side skirts/ground effects; is that necessary?
    (3) Is there a good jack support point at the rear of the car I can use as a precaution while I'm working there? Again, with this newer car having more panels underneath and my general unfamiliarity, I'm just not certain how best to proceed.
    Thanks so much for the comments!!
    Dec 05 2016
    Chicagoland
    In the rear of the car you can place them on what i believe to be part of the frame (not sure but its black painted metal).
    The front is trickier, but i place the jack stands on the control arms. The control arms seem like they wouldnt work since they will be at an angle when you jack the car up, but they rotate to horizontal as you lower the weight onto the jack stands.
    There are no central jacking points I am aware of.
    As far as the plastic inserts, i leave them in. I have the audi cylindrical adapter piece and before that i used the jacking points without even a hockey puck and there was no damage. With just a hockey puck you should be fine but the audi adapter can be had for like $10 on amazon if i remember correctly.
    This is all assuming the C7 and C7.5 are the same underneath.
    2012 A6 Ice Silver on Black // Rohana RFX10 // Gloss Black vinyl wrapped roof and mirrors // RS Grille and Diffuser // 35% tint including windshield // Audison Bit One, Focal KRX2, JL 300/4 and 1200/1, JL 12W6 // EPL Stage II // Vag-Com // Injen // Chrome Delete
    Oct 27 2013
    A large impact socket works well if you don't have the jacking "cylinder" from Audi.
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    thanks guys!!
