Results 1 to 16 of 16
    Mar 09 2015
    What are the common torx sizes?
    Just bought a second B7 A4 for my wife and was going to put a small tool kit together to keep at the house. I work alot on bikes and really only use 8, 10, 12, 14, 17, 22mm tools. So no need to for me to keep buying complete sets. What are the common torx sizes for these cars? Thx.
    Jan 26 2017
    2008 Audi A4 Quattro
    St. Louis, Missouri
    There's a couple 8's and 10's. Triple squares are really what you need. They are very useful. I got a set of 6, 8, 10, 12 triple squares and use the 8, 10, and 12 a lot.
    Sent from my Pixel XL using Audizine mobile app
    Active Member Two Rings BeasTT315's Avatar
    Jun 07 2017
    12 TTRS, 02 TT 225, 15 GSXR 1000
    X2 on the triple squares...nothing worse than breaking an axle and either waiting for the tools to come in or paying someone to do something you can easily do yourself. Small socket set, do not lose your 10mm! Mine are mostly 8 and 10's for torques. Congrats on the new car.
    Veteran Member Four Rings rhfosu's Avatar
    Jan 01 2015
    Alexandria, VA
    Triple squares x3, but that is for things not often messed with. You need T15, T20, T25, and T30 for most superficial things.
    Aug 09 2012
    Sylvania OH
    HPFP is secured with torx and PCV is also torx. Off hand I don't recall the sizes, but somewhere in the T20-T40 range. I've only come across the triple square during my steering wheel swap to this point.
    Oct 24 2015
    Perth, WA
    Triple squares on turbo lines too. I would suggest making a list of the common jobs and researching the tools required.
    My respray thread
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    For $26.00 on Amazon this set is handy to have
    https://www.amazon.com/Titan-Tools-E.../dp/B000OEFTJ4
    Oct 23 2015
    Australia
    I've found this set perfect-many on Ebay the same:
    https://www.ebay.com.au/itm/Torx-Hex...item1a386732b2
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Sylvania A4 View Post
    Be carefull here this is trouble waiting to happen ... the fuel line to the HPFP on early cars is a triple square ( 2005.5 and 2006 ) , the HPFP is fastened down with torx yes, but the fuel line requires a stubby 17 open ended wrench and triple square for the other fuel line , it is blind and you wont see it , putting a torx in there without knowing and you are in a world of hurt.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    oh by the way nac nac , if you have read up at all you know to check the cam follower for the HPFP before sending her on her merry way.
    1976 Yamaha XS 360
    Dec 05 2016
    miami FL
    this is a great thread, i dont have any tools acutally i couple torx screwdrivers for my yamaha
    Established Member Two Rings zzzz05725's Avatar
    Dec 28 2017
    Maine
    +1
    2006 Quartz Grey A4 6MT (Formerly Owned by DannyDeez) (Sold)
    2010 Imola Yellow S4 6MT (Formerly Owned by Despise)
    AWE Touring Catback, ECS KLT Intake, A4 Avant ST X Coilovers, ECS RS4 Grill, ECS Short Shifter, ECS Stainless Clutch Line, 034 X-Brace, 034 RSB,
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Could there be a variance in vehicles world wide with bolt types? When I changed my HPFP I used common torx tips not "triple square" tips, same for my oil filter housing, torx were all I found. Did Audi use different bolts for different countries?
    Dec 05 2016
    miami FL
    Nice coulor
    Quote Originally Posted by canadianA4B7 View Post
    Mar 09 2015
    I have a pair of them sitting in front of me on my desk, one for hers and I did mine about 30k miles ago.
    Thanks for the replies, not as specific as I was looking for so I'll just get a 1/4 drive set. I have a shop at my office (lift, tire machine, etc) just wanted a small kit specifically for the Audi's to keep at home for quick weekend jobs.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by mgfranz View Post
    Yes. All fastening bolts are torx but 2005.5 and 2006 use banjo bolt for fuel line on the pump and requires a triple square
    1976 Yamaha XS 360
