Results 1 to 36 of 36
    Veteran Member Three Rings Corradobrit's Avatar
    Oct 27 2007
    TX
    Akebono vs TRW carbon brake pads
    Any performance differences for street use? OK to use them on stock rotors?
    Senior Member Two Rings ixez's Avatar
    Jun 02 2017
    2014 Audi S4 (B8.5)
    Indianapolis, IN
    Do not buy Akebono. Piece of $h1t and worse than OEM pads.
    I've got mine with new upgraded rotors and even with that my car doesn't bite as well as before.
    Also, I've seen many complaints about EBC Red lately. Hawk HPS squeak (good overall but not for daily driving per my taste).
    Get Carbotech Pads xp20/xp24 or Endless MX72 pads that are used by GT-R people (if you got money). It's ok to use with stock rotors if they're in a good shape.
    2014 Audi S4 B8.5 Moonlight Blue | Sport Diff | EPL Stage 2+ DP 93 (445 whp/420 wtq) | AMS Alpha Cooling System | Dual Pulley (57mm + 183mm Fluidampr) | Injen Intake | Alu Kreuz | CR-15 | RS Grille | AWE Touring Exhaust + Resonated Downpipes + 102mm Chrome Tips | 18" O.Z. Ultraleggera Gunmetal + Michelin Pilot Sport A/S 3+ | ECS Stage 1 Brake Kit with Cross-Drilled & Slotted Lightweight 2-piece Rotors + Akebono Pads
    Senior Member Two Rings steampunkjunker's Avatar
    Jun 21 2017
    NorCal
    You can get MX-72 for about half price (~$400 F&R) from Nengun. It’s like adding a BBK with good pads plus no squeal, low dust, long life, and easy on rotors.
    Junker’s 2013 B8.5 S4
    • Suspension: H&R ARBs, CR-15, H&R 10/12mm wheel spacers
    • Braking: Endless MX-72 & RF-650 fluid, StopTech cryo slotted rotors, Tyrolsport brake lines & caliper bushings
    • Motor: GIAC - Stage 2, Redline oil
    • Coming soon: GIAC - TCU, Bilstein B12 Pro-Kit
    Veteran Member Four Rings isles1's Avatar
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Is there an Endless MX72 pad that is made for the stock B8 calipers? I do not see pads for a B8 on www.nengun.com
    2022 SQ5, P+, Daytona Grey, S Sport, B&O, Black Optic, Black Badges, Dynamic Steering, OEM Sport Exhaust, Black/Black Dinamica.
    2013 S4, P+, DSG, Ice Silver Metallic, Black/Silver Alcantara, Sport Diff, B&O, 19" Peelers, Pilot Sport 4, SC Badges, Alu Kreuz, Endless MX72 brake pads, StopTech slotted rotors (front), APR Carbonio Stage I & II CAI. Winter shoes: OEM B8 S4 18" Wheels w/ Nokian Hakkapeliitta 7 Studless. Original owner; custom ordered.
    Jun 06 2016
    Florida
    I replaced my stock pads and rotors with Akebono pads and Stop Tech slotted rotors. You need a tiny bit of extra push to get the same bite as stock but nothing that affects your confidence. There’s almost no dust and no squealing or other undesirable noises. I’d buy this setup again and would highly recommend it for street use. I haven’t tested them on a road course and don’t plan to.
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Oct 27 2007
    TX
    Quote Originally Posted by steampunkjunker View Post
    Whats the part number for the stock B8.5 calipers? Don't see ref to our platform on any of the sites that sell Endless.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Quote Originally Posted by isles1 View Post
    NM...found them EIP176 Front + EIP169 Rear. $320 plus ~80 shipping to New York.
    - - - Updated - - -
    Quote Originally Posted by Corradobrit View Post
    https://www.nengun.com/endless/brake...emium-compound
    Junior Member Two Rings speedycrw's Avatar
    Jan 05 2006
    2015 Hellcat 6M, 2010 Mustang GT Racecar (NASA Spec Iron), 2018 Ram 3500, 2019 Bullitt
    West Michigan
    Bought the Akenbo and stock rotors for my 2014. Great setup, slight difference in bite, but nothing noticeable for the street. Certainly not a track pad, but more than acceptable for street use, and almost zero dust. Would do it again in a heartbeat. Certainly not suitable for a racecar, but then again the S4 isn't a true track car anyway....
    2015 S4 6MT Daytona Gray, Black Optics, Carbon Fiber Inlays, Sport Diff, B&O, Rotor rims....because!
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I am happy with Akebono with stock discs...put on the front and back.
    Jan 09 2008
    Winnipeg
    If you want the initial bite of the OEM pad you might have to stick to the OEM pad but then you are stuck with lots of dust. Most people here seem to want low dust and most (all?) the options mean giving up on the initial bite. This isn't a bad thing depending on what sort of driving you do. I went with Stoptech's slotted rotors and street performance pads and I too wasn't all that happy with the bite initially. I thought I wanted the instant hard grab that the OE pad provided...until I autocrossed my car a little more. Then I realized how much that instant bite would tend to upset the car quite a bit. Sure you might have to press a little harder to get the same stopping power but I found the less abrupt grab and release of the Stoptech's to ultimately be a better feeling. It did take a while to get my head into the right frame of mind.
    Senior Member Three Rings Sukks2bu's Avatar
    Mar 12 2013
    Milton Ontario
    I recently had my front and backs done with OE replacement parts, Zimmerman rotors and TRW pads. I feel like my Aniitial bite has disappeared. I've had my fronts replaced with this setup in the past, and it felt completely like oem.
    Only difference is I had the fluids replaced. Is it possible the fluids or fluid level could cause the lack of bite, or more likely, they didn't use TRW pads??
    Oct 27 2007
    TX
    - - - Updated - - -
    "The Endless Premium Compound Brake Pads are designed specifically to keep those expensive wheels super clean." Seems like an expensive option just to reduce brake dust. No mention of being a carbon compound, just asbestos free.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    I do not know much about the Endless MX72 pads. I was just looking into them because of this post and because I am looking for something comparable to Ferodo DS2500 pads that are less expensive. Other websites refer to the Endless MX72 as a carbon ceramic compound or "CC-X". No idea. I have no experience with these.
    Jun 21 2017
    NorCal
    - - - Updated - - -
    Yeah exactly. I just checked my receipt and those are the same numbers.
    Jun 21 2017
    NorCal
    http://www.endless-sport.global/gb/products/pad_1a
    Those are both different pads than the MX-72. I have a pretty comprehensive review on this forum and on GolfMKV.
    The Mercedes Benz Petrobras F1 team likes Endless enough to go with them for 2018 season. And Ross Brawn used them as well with his last team before running F1.
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    Quote Originally Posted by ixez View Post
    Is the initial bite the complaint? I just installed EBC redstuff. Less bite but nice and smooth, and if you really have to step on it at high speed the bite hard as they heat up. Installing stainless brake lines this weekend, so maybe that will help with the initial bit feel. No dust. Overall, I am quite happy.
    ...Akebono was my runner up, but ECS sold me on Redstuff, as the salesman said it's what he runs...or was it that it costs more...
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    to each his own. i hated the overly aggressive non linier initial bite of the stock brakes. Akebono here as well, no issues even when i have had to do a panic stop. actually more control than the stock snatchy brakes
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    Sounds like OP is looking for oem level replacement.
    If you don't mind the dust, go with OEM suppliers like Textar, TRW, Pagid pads (Semi Metallic). If you want less dust.... well you'll lose braking power. Akebono, HPS, RedStuff, ceramic pads.
    Personally I run Stoptech Street Performance. Somewhat decent dust, but stops well for my need.
    Jul 08 2017
    Minneapolis MN
    Don't mean to hijack- if I've got 30k miles on my car and want to get aftermarket pads, should I get new rotors as well?
    2019 RS3 Daytona grey pearl- 30% tint, full front xpel, AWE track with audi OEM catless mids, H&R sport springs, Neuspeed RSE10 19x9 et 45, CTS intake, black badges, V1 radar IG mplsrs3
    Sold 2014 B8.5 S4 Phantom black pearl, DSG, AWE touring with awe non res DP, CTS intake, TSW Bathursts 19x9.5 et 39, 30% 3m tint, rs4 grill, led fogs, Bilstien B12 with H&R sport springs, epl, V1 radar.
    Mar 28 2013
    Orange County, CA
    Cost effective with zero dust and high performance:
    Akebono pads
    Slotted rotors
    SS lines
    Endless racing fluid***
    ***results in firm, consistent pedal with good/balanced initial bite. May need to flush every year, but well worth it.
    Dec 16 2009
    Some car
    MD
    Quote Originally Posted by catalyst686 View Post
    It's always good to get new rotors since there will be new pad material. However if your rotor is still within OEM thickness, it's OK to reuse. Go run your fingernail toward the outer edge of the rotor, if you feel 'lip', then get new rotors.
    Jul 10 2015
    Same as onlyaudis; prefer the lack of initial bite with Akebono, easier to brake smoothly. Using Stoptech rotors and ss lines.
    Sep 22 2015
    21 Q7, 21 X7
    Nashville, TN
    Getting groceries the Akebono are fine, but I won't buy another pair. Forget about the track, I can't even drive spirited for 5 mins without introducing a vibration due to heat.
    Sold: 2014 S4 | EPL Stage 2 + TCU | ECS Intake | CR15 | 034Motorsport RSB | ECS Trans/Diff Inserts | Mr. Spectacular's 10" Subwoofer Box w/10w6
    Oct 06 2014
    how about feedback on the stop tech sports?
    Jun 05 2007
    Nashville, TN
    Quote Originally Posted by minman26 View Post
    This is the first I've heard about vibration from ceramic brake pads. Is this a common issue? Has anyone else had this happen? I really hate all the brake dust from the stock pads, but don't want to deal with vibration from my brakes.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Sounds more like an issue specific to your rotors with heat build up rather than your selection of pads.
    Sep 22 2015
    21 Q7, 21 X7
    Nashville, TN
    You are probably right (Zimmerman blanks), however the added pedal force needed for same stopping power as OEM likely adds to the increased heat/distortion. The ceramics really are fine for 99% of daily driving, but for me, unless there is another explanation for my issue, I think it should be pointed out. It's not something I've read much on this forum, and everyone raves about the Zimmer/akebono combination... myself included in other posts.
    To your point, my issue might be primarily rotor choice and not the pads. Ceramic pads with a better quality rotor may not exeprience any issues for spirited street driving, or at least not so quickly.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Perhaps the pad type does add to the heat...I’m no expert. I’ll take stopping power over clean wheels all day long, so I don’t get the appeal of ceramics.
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    Quote Originally Posted by onlyaudis View Post
    I second this. took a few days to get used to the Akebonos but I prefer the linear nature. It takes more peddle pressure but doesn't upset the balance of the car as much. My aging OEM brakes would grab so hard it frequently overcame the grip of the tires too easily in rain/snow.
    2013 S4 DSG | VX3 LED Fogs | LED interior conversion | LED reverse lights and plate lights | CR-15 Strut Tower Brace | 35% Window Tint |
    Aug 17 2017
    2001 Audi TTQC 225, 2003 VW GTI 20thAE, 2016 SQ5
    Atlanta, GA
    Agreed with the dislike of overly aggressive initial bite of OEM pads. We have ABS. If you can induce lockup and engage ABS, you have enough brakes. All this talk of more stopping power is funny. Has anyone mentioned coefficient of friction specs or temp ranges?
    Veteran Member Three Rings hockeyman474's Avatar
    Aug 10 2017
    Chicago, IL
    Quote Originally Posted by speedycrw View Post
    Glad so many people like these. I bought a set for my S4. Waiting to have them put on until my 75k service in 3 weeks.
    2003 Audi S6 Goodwood Green w/ Alcantara
    2011 Audi S4 Ibis White (sold)
    Mar 01 2016
    NH
    Quote Originally Posted by CollecTTor View Post
    I think typically ceramic pads don't hold their heat as well which can effect performance in the cold from what I read. But I didn't feel any degradation in the negative temps we had the last few weeks. Hardly scientific, just my 2 cents.
    Aug 17 2017
    Atlanta, GA
    Quote Originally Posted by bberg22 View Post
    The "heat" is referring to peak operating temps, not ambient temps. Ceramics are not meant for heavy repeated braking, ie racing. Spirited driving they are fine. Full ABS engagement stopping repeatedly with no cool down will cause them to outgas and glaze.
    Senior Member Two Rings Pawan2013's Avatar
    May 28 2013
    how are the endless pads with brake dust and are they a good track pad or just a daily driver pad the the akebonos?
    B8 S4, DSG, Sport Diff, B&O + Nav
    Many Mods
    Jun 21 2017
    NorCal
    Quote Originally Posted by Pawan2013 View Post
    Jun 21 2017
    NorCal
    The Endless ME20 compound would be a more aggressive dual purpose pad probably better for something like Sport Cup 2 R compound tires. Retail is $390 instead of $370. The MA45B low friction endurance race pad goes for about 2x. SpeadFreaksUSA has them all. Not sure if Nengun can get the ME20 or MA45B.
