I went to start my allroad the other evening and when I went to turn the key I moved the steering wheel a bit and it locked. The key would not turn as well. I jiggled the wheel and still, the key could not turn. I've tried the valet key along with the fob key. I've seen where C6 A6s have an issue of locked up steering wheels and VAGCOM was used to unlock the mechanism. Does anyone know of this method works on C5s? My research has not turned up much at all on C5s sharing my problem. My Key fob has a new battery and does lock and unlock the car.
