Results 1 to 14 of 14
    Veteran Member Three Rings Frenetic's Avatar
    Dec 13 2015
    '17 Audi S7
    CA
    What individual drive-mode settings do you save/use?
    Curious what other people set for their individual drive modes. Here’s mine:
    Engine/Transmission: AUTO
    Air Suspension: AUTO
    Dynamic Steering: DYNAMIC (Auto/Comfort is way too light for me)
    Sport Differential: AUTO
    Engine Sound: DYNAMIC (wish it was louder)
    Adaptive Cruise: AUTO
    I almost always leave it in this mode, occasionally flipping it dynamic and comfort. I guess mine is rather boring lol. It’s easier for me to just go full dynamic mode when needed and just get the things I like in day-to-day driving.
    2020 BMW X5 M50i | 2017 AUDI S7 (gone)
    Established Member Two Rings EuroDub's Avatar
    Dec 06 2008
    Laconia NH
    I always drive in Dynamic and almost never take it out of it but i am also new to 4 rings and still learning it.
    Mar 26 2010
    US
    Most of the time I pull back the gear shifter to engage sport mode, but default individual is set to auto in MMI.
    Engine/Transmission: auto
    Air Suspension: comfort
    Dynamic Steering: dynamic
    Sport Differential: dynamic
    Engine Sound: comfort
    Adaptive Cruise: auto
    BMW M3 Competition X-drive
    Deactivated Three Rings
    Jul 09 2016
    Quote Originally Posted by EuroDub View Post
    +1
    Established Member Four Rings limeypride's Avatar
    Mar 18 2017
    Snohomish
    Quote Originally Posted by Frenetic View Post
    I almost never use the Dynamic profile because I dislike the unnecessarily & artificially heavy steering but most especially Audi's (non-air) DRC or dampers--suffice it to say I call it "Princess Pea" mode. Note that it was a hard ride before the lowering springs, now it's a track tool only.
    I drive in Individual 99% of the time; setup as follows:
    Engine/transmission: Dynamic
    Damper control: Comfort
    Dynamic steering: Comfort
    Sport differential: Dynamic
    Engine sound: Dynamic
    Adaptive cruise: Dynamic
    2018 ////AMG E63S in Diamond White/Nut Brown, lowered 20mm front/back, spacers, tints, EuroCharged tune
    Gone but never forgotten
    2017//RS7 Performance in Mythos Black, Audi exclusive Titanium edition w/ Akrapovic exhaust
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Engine/Transmission: AUTO (Easy enough to pull back the shifter to make this Dynamic if desired)
    Air Suspension: COMFORT (Dislike throttle and ultralight steering in full Comfort mode but like the soft ride for my individual setting)
    Dynamic Steering: AUTO (for me is just all-around right)
    Sport Differential: DYNAMIC (because I can :))
    Engine Sound: AUTO or COMFORT
    Adaptive Cruise: DYNAMIC (it took me a while to finally try this setting but I find it better for the areas I use it.)
    Still cycle through all the modes the individual is sorta my comfort mode.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 02 2018
    Deleted
    I always drive in Dynamic and almost never take it out of it but i am also new to 4 rings and still learning it.[/url]
    +2. But have a question. Actually 2. On 'auto' suspension, when it lowers at speeds over 75 mph, does it revert to 'dynamic', or just lowers like dynamic but damps like auto? Curious about that. And with 'auto' steering, is it 'direct comfort' like the manual says, or variable (8:1 to 18:1) like comfort but with less assist, therefore indirect, like somebody posted? The 'dynamic' mode is labeled as 'direct sport'. I don't know what's the difference between direct and indirect, since all 3 modes take a full turn straight to lock (or 2 turns lock to lock). The variable ratio should take less, no? Finally, curious if lowering the suspension more with VCDS is only in dynamic, and how much the ride is affected. I like it there because of the stance. Also liked that if you don't want to feel anything, steering in 'comfort' takes care of that, like when slabbing on endless straights in imperfect asphalt. On the diff, guess it makes no difference which mode you use if it's not slipping, right? And on that subject, does anybody know what kind of rear differential we have? Is it a Torsen or clutch? And finally, on the engine sound, is it all artificial, or comfort natural and dynamic enhanced, and enhanced via the speakers, or some intake tube with a valve? Thanks.
    Senior Member Two Rings schaNYC's Avatar
    Jun 06 2016
    Does AUTO switch modes from comfort to dynamic and vice versa or is it simply like an in between setting?
    Apr 29 2016
    2021 Q7 Prestige
    Los Angeles, CA
    My drive mode are all set to dynamic EXCEPT for transmission. The S in transmission is too jerky for me around town.
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by parkstr8 View Post
    +1, not to mention the extra fuel usage from always being a gear above normal.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Dec 13 2015
    '17 Audi S7
    CA
    Quote Originally Posted by schaNYC View Post
    I wondered about this too and the instruction manual isn’t very clear, although from what I read, I think it’s a more in between setting than some fuzzy logic that switches between the two.
    Jan 02 2018
    Deleted
    I guess we need to try them and see what each of us feel. But at least on the steering it seems like the 'auto' mode reduces a bit of assist, but it's still unclear if it's the 'indirect' variable ratio or the 'direct' mode. I'm going to try again each mode and see what they do. Wish there was a detailed tech explanation of that, with a graph of each mode's ratio as the steering wheel turns, to visualize the differences. Couldn't find anything. Would also love a technical explanation of the 3 suspension settings as well. Guess we'll have to try them and see what we feel, and report here.
    Jun 06 2016
    Feb 15 2011
    Northern VA
    All dynamic with exception of suspension which is set to auto.. otherwise I would have just gotten an A6
