G’day guys!
Now, I know this has been discussed - well, in part in other threads.
Now, the general consensus is that an RB8 cluster won’t work in a B6. When we say “won’t work”, what exactly are we referring to? Compatibility with the:
B6 audio?
B6 CCEM?
B6 ABS?
B6 climate control?
B6 ECU / IMMO 3*?
I ask this, because as part of project B6 420-TS, I purchased a cluster from a 2004 B6 S4 Convertible. What some may not know, is that the majority of B6 S4 Convertible clusters are RB8, not RB4 as one would expect. They have more in common with the B7, which is hardly surprising. B6 and B7 Convertibles have more in common, unlike B6 and B7 Sedan / Avant where the differences are more than meets the eye.
I know extracting the SKC code from the B7 is almost impossible, unless I’m mistaken? If a B6 is running an IMMO-defeated ECU, can a B7 cluster then be used?
Working on the assumption that the rest of the B6 sub-systems as I’ve listed above won’t be compatible with my B6, I will be buying a complete B7 Avant, and yanking out the entire car harnesses, ABS module, climate control panel, audio unit, CCEM etc. I have the opportunity to purchase a B7 RS4 instrument cluster, which is what I will be fitting to B6 420-TS.
Any input / contributions welcomed.
*Early B7 models were IMMO 3. This does not include RS4, Convertible, S4 or Seat Exeo models.
