Results 1 to 40 of 41
    Veteran Member Three Rings JWERNER24's Avatar
    Nov 08 2005
    1983 Porsche 944 (Track Toy), 1997 Toyota 4Runner (Offroad Toy)
    Central Oregon
    Exclamation Secondary Air Injection Pump Help...
    I have a B6 3.0 and I've thrown 2 secondary air injection codes (17819 & 17831). I went to the dealer (before I had a vagcom) and they informed me that the previous owner must have had problems with the pump and just unplugged it. They plugged it in and found that the pump blew the relay... but now I need to figure out where the relay is because they left it unplugged. If anyone has a picture of this pump and/or relay, or would just like to explain where it is... I would really appreciate it. Ive also been reading that people have had problems with hoses tearing or cracking coming from this pump... I'd like to check those out too and see if they are causing a problem as well. Thanks in advance!
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    This pump is also called the smog pump.. It adds air into the intake while the car is warming up..
    The pump can be found on the underside of the car on the passenger side near the front of the car.
    You can try and search for the Dual intercooler mod for pictures, since you have to move the smog pump for installation..
    Nov 08 2005
    Central Oregon
    I'll search for that, thanks for the help.
    Sold: 2002 Ming Blue A4 3.0 MT6Q
    Current: 2001 Brilliant Black allroad 2.7tQ
    FOR SALE: 1983 Porsche 944 - PM for details!
    Nov 08 2005
    Central Oregon
    So I have the car in the air as I type this... looking under there, I see the pump and the wires/hoses coming off it. I traced the 2 hoses coming off it (plastic hoses) and they seem to be fine. I traced the wires through the engine bay and they run through the firewall (from what I can tell). I've searched and searched and keep finding people with broken or torn hoses... which hoses are these? Im kinda wondering if the CEL keeps coming on because maybe I just have the hose missing all together?! If anyone with a 3.0 would be so kind as to take a pic of the setup for me... I'd REALLY appreciate it. Thanks
    Nov 08 2005
    Central Oregon
    can anobody show me a picure of the Combination valve? I've been searching and searching... no luck. I couldnt find any broken hoses coming off the air injection pump, so my next task is checking out the combo valve, and possibly replacing it (as I've read, stops working occasionally). Thanks in advance........
    Nov 08 2005
    Central Oregon
    bump!
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    I have a 1.8T, and the valve I think you're looking for is at the back of the head. there a couple of small fabric covered lines attached to a small metallic canister. Check the hoses that attach to it, I found one of mine cracked at the nipple that comes off the valve. I was throwing secondary air codes until I replaced the hose. Fairly easy to do. I think this may be your problem give the codes you describe.
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
    Nov 08 2005
    Central Oregon
    would the best way to find this valve be through the underside of the motor, or just looking down through the top? on the 3.0, would it be to one side or the other... or somewhere in the middle of the back? Any help would be awesome - I've searched and searched and cant find any broken hoses anywhere in the engine bay, Im just hoping I missed it. Thanks
    Jun 26 2005
    Ft. Lauderdale
    no, top of the engine. follow the coilpacks to the back of the block between the firewall and the block. silver in color. mine had a small hose that broke in my hand. just cut ioff the bad part and put it back on. no cel so far. can't really see jack. just feel around if you can.
    Nov 08 2005
    Central Oregon
    is it under the plastic intake hose on the back of the block? Im searching but not finding any cracked hoses and wanna make sure Im looking in the right spot.
    Registered Member Four Rings
    Sep 26 2004
    i have a problem with you knowing codes. star trek is over, my friend.
    get a girlfriend.
    Nov 08 2005
    Central Oregon
    What the hell are you talking about? I'd rather you just PM me with your crap rather than being an idiot and messing with my thread.
    Nov 08 2005
    Central Oregon
    StageIII4Me, thanks for the pics. No luck... no torn toses or anything.
    Anyone have any other ideas??
    Nov 08 2005
    Central Oregon
    BUMP!
    sorry to revive an old thread - i just threw this code again after clearing it and it being gone for months! Im wondering if the cold weather has something to do with it...
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I will post up pictures tonight from ETKA...
    Nov 08 2005
    Central Oregon
    PERFECT! thanks Greg!
    Veteran Member Three Rings darkstar's Avatar
    Dec 24 2004
    1998 silverado, 1986 c10
    Folsom, CA
    here you go
    Nov 08 2005
    Central Oregon
    PERFECT!! You're the man bro!
    Nov 08 2005
    Central Oregon
    Can you post the part numbers for #23 & #24? Thanks.
    Also, I found a hose that was frayed... didnt seem to be leaking air, but the mesh stuff that its wrapped in was fraying off. I swapped out the hose with a crappy new one I had laying around but would like to get a better hose... Hopefully that was the problem. I'll keep this thread posted incase others have the same issue.
    Oct 29 2005
    10speed
    San Francisco, CA
    Hey I dont know where your pump is but I replaced the vac line from my combi to my N112 valve and the CEL went out/boost came back... I think youd still have that vac line in your car but i may be wrong
    - Clint
    Dec 24 2004
    Folsom, CA
    23) 078 145 718 AE PRESSURE CONTROLLINE (1)
    24) +N 103 100 01 CLAMP (2)
    lemme know if you need anything else.. i know how it is when you got problems and poeple dont want to help out!
    Nov 08 2005
    Central Oregon
    darkstar, do you know which valve is the N112 that AudiA4_18T was talking about?
    Feb 17 2007
    NC
    Re: Secondary Air Injection Pump Help...
    What did you ever find out about this...I think I'm having the same problem with my SA pump and would like to know if your problem was from the hoses, valves, or pump? I have an '02 3.0.
    Aug 26 2005
    The Secondary Air Injection Pump Relay, is under the drivers side dash, located in the horizontal row of relays, third relay from the right, with "373" labeled on top. If the fuse blows or the relay fails when the pump is connected, the pump rotor is likely seized up, and not free to rotate.
    Also check the N112 solenoid valve on top of the engine on the back of the manifold. That valve controls the vacuum signal that opens and closes the secondary air combination valves on the back ends of the cylinder heads.
    Feb 17 2007
    NC
    If there were a problem with the SAI relay, would I hear a ticking noise coming from the left of the steering column? I threw the P0491 and P0492 SAI codes a couple of days ago, and I am trying to track down the cause. It sounds like the SAI pump is running at cold start (sounds like a jet for about 30 seconds). The CEL hasn't come back, but I'm not holding my breath....
    Nov 08 2005
    Central Oregon
    I never did get this resolved. Im thinking the relay is the problem though... anyone had a part number for a new one? :)
    Aug 26 2005
    Quote Originally Posted by JonQ View Post
    A malfunctioning relay may or may not click, it depends on the specific failure mode occurring. (electrical/mechanical) If the relay primary coil winding is open or shorted, then the relay cannot respond, thus no click. If the failure is mechanical, the contacts actuated by the relay coil are burned, or contaminated, then the relay will "switch state", (can be felt by touching the case, if not audible,) but the connected electrical load/device will not be energized, etc.
    Your DTCs, are for Low Secondary Air Flow, right and left cylinder banks. Check the N112 solenoid valve for proper operation, (de-energized, no air flow through N112,) and the N112 vacuum supply hose from the vac reservoir, and the control vacuum hoses from N112 connected to each Combination Valve located on the back ends of the heads. Also check the SA hose/s from the SAP to the Combination Valves.
    Aug 26 2005
    Quote Originally Posted by JWERNER24 View Post
    The PN is moulded or printed on the relay, it is relay location number "373" , but that is not the PN. If I find that PN, I will post it.
    Feb 17 2007
    NC
    Thanks diagnosticator, that's the most concise info on this I've seen yet! There is definitely a ticking so I'll check the relay and the other things you've mentioned.
    Nov 08 2005
    Central Oregon
    Im going to check it out tomorrow... thanks!
    Feb 17 2007
    NC
    I think I fixed my problem...one of the hoses to the air pump was disconnected! My big head barely fit under the car to see it, but the jet engine sound is definitely more subdued with the hose connected. Now on to the next issue....
    Aug 26 2005
    The "next issue" is?
    Feb 17 2007
    NC
    Where do I start...? Let's see, pulled these codes when I cleared the CEL on Friday (in addition to the SAI codes that should not come back now):
    17887 - Brake Boost Vacuum System: Mechanical Failure P1479 - 008 - Implausible Signal
    16805 - Catalyst System, Bank1 Efficiency Below Threshold
    P0421 - 001 -
    The second code might be related to the loose hose I'm hoping. I do have a rough idle, so I'm wondering if I have MAF, O2 sensor, or cat issues. As for the brake booster code, I do notice that my brakes are weak right after I start the car. I also hear weird groaning noises coming from behind the dash after I start the car and after I turn it off that might be related to this. I've tried to find pics or diagrams of where the offending brake booster hose might be on a 3.0 but no luck yet.
    Then, my stock xenons are pointing at the ground practically. I tried adjusting them using the screws (with the ignition off and with the key in the on position but the car off) but nothing seems to change. I only have the shareware version of vag-com, so not sure how much I can do about this...
    Then there is the problem with the tiptronic that I knew about when I bought the car. Has something to do with the shift cover (already removed) or the circuit board, dealership quoted 300-450 to fix.
    I bought this car so that my Mustang could be my project car and this could be my daily driver, but that didn't turn out so well!
    Feb 17 2007
    NC
    Oh, and I forgot about an ETC sensor I think is going bad..still trying to find out where that one is in a 3.0 also. If anybody has any comments about any of these issues I could use all the help I can get!
    My car: 2002 3.0Q, tip, 61k
    Aug 26 2005
    Check your PM
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    So I dont think my SAI pump is working. I threw a CEL months ago when i had water in my ECU and casued cooling fan issues. I replaced the relay in the middle and the issue went away however I left the other 2 assuming that there was no problem. Anyway, i jacked up the passengerside and started the car and then climbed under the car to see if the pump was working and it wasnt. Anyway, I came accross this thread and I have a 373 relay under my ECU. Is that the same one or are there 2? I have a 1.8T
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Aug 26 2005
    The "373" relay under the dash, I assume is the same spec relay as the one in the ECU box, but I will confirm and get back to you here. OK?
    May 12 2008
    Sounds good. Thanks
    - Mags
    Senior Member Two Rings MassVet's Avatar
    Feb 17 2006
    boston
    I'm looking for the relay "under the dash" and am having trouble right now, Same problems above, Diagnosticator or anyone, can you help me out with this? Got the car on the jack as we speak.
    Found it, the replacement relay that the dealership sold me was #643, was told it was compatible, hopefully this will help. I replaced the relay, checked all tubes, wires, doohickeys and ringdings and disconnected the negative from the battery. I'm going for a leisurely drive now to see if it has worked.
    // '03 A4 3.0 // Cocaine White // RNS-E // 19'' Moda MD3 // AUX Video and Sound *in //
    Mar 01 2010
    Kaukauna, Wisconsin
    Im having this same problem....it idles really low and seems to almost vibrate a little bit at idle...it will smooth out if you give it just the slightest bit of gas....sounds like a jet engine during acceleration and at start up....and now i seem to notice a ticking sound that is really starting to sketch me out.....it threw the secondary air code once before and i had it reset...am i best off just replacing the secondary air pump and hoses or is it worth checking out the fuses....i think its shot....thanks!
    2002 a4 3.0 6 speed quattro....
