Results 1 to 6 of 6
    Dec 04 2006
    Los Angeles, CA
    Rear trunk latch button not working- but remote & int. release work
    This is a bit odd, and can't figure it out.
    The trunk release (on the trunklid, above lic plate) does not open the trunk. No sound of actuator- just the click of the button but no release.
    Remote control release works.
    Interior trunk release works (front driv door)
    If I manually push the locking mechanism up, and then press the trunk release, i can hear the actuator firing.
    So, the actuator seems to be working
    any ideas?
    thanks
    B8 2.0T QTip
    Deactivated Two Rings
    Mar 25 2015
    '68 Nova, Subaru Forester
    United States
    Which model and year?
    Sent from my SM-G955U using Audizine mobile app
    Dec 04 2006
    Los Angeles, CA
    09 2.0T Q Tip
    B8 2.0T QTip
    Senior Member Two Rings helldriver's Avatar
    Oct 25 2014
    Cincinnati, Ohio
    Yeah me to, mine started doing this a few months ago?, one thing after another, sucks!
    Sent from my SM-N950U using Audizine mobile app
    2008 Audi RS4
    Senior Member Three Rings Quattro420's Avatar
    Apr 08 2015
    2003 Jetta tdi 5peed 2000 b5 a4 1.8t 5aq, 2005 Passat tdi wagon2.0l, 2000 sierra 5.3l
    Ontario Canada
    I disabled the trunk open on my car in the Mmi, now my trunk only opens from fob and door switch unless I enable it. Pervious owner could have done same or someone else, easy to diag tho remove cover in trunk undo the trunk release conector and check the resistance while pressing button should read open when not pressed and should show a reading while pressed
    Dec 04 2006
    Los Angeles, CA
    dude, you are a legend! Thanks so much!
    Quote Originally Posted by Quattro420 View Post
    B8 2.0T QTip
