Results 1 to 13 of 13
    Established Member Two Rings mikeman101433's Avatar
    Mar 01 2017
    Buffalo NY
    Windshield Washer Fluid Not Squirting in Cold Weather!!
    Hey Guys,
    When I first got my 2015 b8.5 S4 the little squirter holes for the washer fluid were rusted and only one of the three holes were working. I bought replacements from ebay same part number as OEM. Installed them easy.
    My problem is when the weather is under 35 degrees they do not squirt at all. After taking my car through the warm car wash they work for about 4 minutes then become inop again.
    Do I buy audi OEM ones and replace mine?
    Are the b 8.5 fluid squirters heated?
    They shouldn't be freezing they are made for this type of weather to clean the salt.
    Any help would be appreciated very frustrated, I live in Buffalo NY so the weather and salt is insane.
    Thanks Mike!
    Veteran Member Three Rings WarmFuzzies's Avatar
    May 24 2017
    b8.5 S5 cab, 200-series L/C
    Montana
    is your fluid freezing? I was having my fluid freeze w/in the reservoir itself -- apparently had a weird ratio where it froze when the temperatures dropped.
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Just get the purple fluid if you haven’t already.
    Apr 05 2016
    Portland, OR
    They can clog. Take a toothpick to them :)
    Geoff
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I keep a sewing needle in my ashtray to adjust mine when they are misaligned, but rarely, if ever, has my fluid frozen in my B8. My issue always seems to be that ice builds up over the nozzles, being that they are underneath the hood and above the rain train. With the amount of snow we get around here, that area gets pretty packed with snow, at least mine does if I don't clear it.
    I also only use the blue -20° fluid, as I have read some bad things about the rainx -40° fluid and your sensor.
    The levels of salt used on our roads is absurd, but hey...we made the playoffs this year, so we've got that going for us.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Established Member Two Rings Estoril4's Avatar
    Aug 20 2017
    North Carolina
    Mine work regardless of temperature so far. They do however exclusively clean the windshield of the person behind me.
    Sent from my SM-G955U using Audizine mobile app
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    Rain-X for 3 years and no problems whatsoever!
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by Arn560 View Post
    We used the orange/pink colored RainX fluid in my wife's car years ago and found that stray drops of it would permanently discolor the paint (the clear coat anyway). Now, that was a black Honda Civic so maybe the paint is not as good as on an Audi, but I have not used it since and would proceed with caution.
    SOLD 2015 Daytona Gray S4
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    My vote is for the your fluid being frozen too. I use the blue -20 from whichever parts store and have never had any problems.
    I had previously used the orange Rain-X exclusively, but saw and heard one too many stories of it gunking up the sensors on VAG cars. Better safe than sorry.
    Current: 16 VW Tiguan R-Line 4MO, 15 VW GTI PP, 14 Audi S4
    Retired: 12 VW GTI, 10 Audi S4, 08 VWJetta Wolfsburg, 04 Audi allroad 4.2, 04 VW Jetta, 03 Audi A4 3.0
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by SteveYem View Post
    Rain x has also been shown to discolor and spot the black vertical trim on the sides of the windshield
    Mar 01 2017
    Buffalo NY
    Thanks for all the suggestions and help guys! Will check out the fluid to see if it’s frozen then maybe look for another type of fluid!
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    I personally do a half and half mix of regular blue fluid and the Orange Rain-X, never had any issues with clogged sensors or anything over the period of a couple of years. I know at one point they changed their "recipe" and the fluid looked a bit more red than orange and that stuff got recalled but never had issues with the orange Rain-X. I have had fluid come out in slush form on other cars in super cold temps even the Rain-X stuff. Make sure you use something that is rated for cold temps though.
    2013 S4 DSG | VX3 LED Fogs | LED interior conversion | LED reverse lights and plate lights | CR-15 Strut Tower Brace | 35% Window Tint |
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Did you try R3? https://www.amazon.com/Mothers-09224.../dp/B005R5WGCS
    I bought it to use after the racetrack, but found that it safely removes pretty much anything.
