Results 1 to 27 of 27
    Jan 18 2010
    13 S5 QM, 02 1.8T QM (killed by diesel 4x4), 03 1.8T QM, 84 AE 300ZX Turbo, 65 Ford Galaxie Conv
    Fort Worth, TX
    Dipped Headlight; no HID
    At a loss. I have an 03 with normal halogen lights. Both my headlights went out in quick succession, i.e. within 2 days. The symptoms are the dipped headlight fault on the dash and the obvious no lights. I have not done any maintenance in that area in 6 months, i.e. I have only pulled the the connectors and assemblies to get the front clip into the maintenance position to deal with my FCM last August. All the rest of my lights work; fogs, blinkers, etc. I have read about a "BCM" but little to no details on it. Any pointers?
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Do you just need to replace both bulbs? If you have halogens, and all other lights are working, I'd start by checking & replacing the bulbs.
    Sent from my Pixel 2 XL
    Jan 18 2010
    Fort Worth, TX
    I tried replacing one before I posted with no results.
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Quote Originally Posted by lyleswk View Post
    Did you pull the fuse for the adjustable headlights?
    That will at least make that fault not show on the dash.
    I fouled mine up by messing with the lights while lights were on.
    Test the pinouts for power on the connectors going to the headlights first...pins 5 and 10 for low beam..1 and 8 high beam
    http://www.audizine.com/forum/showth...Wiring-Diagram
    Aug 12 2009
    Dirty Jerz
    Quote Originally Posted by shurur9 View Post
    Halogens don't have the range motors, controller, or fuse for the level function.
    Have you checked the wiring? If it isn't the bulbs, them it's time to start tracing wires. You could scan with VCDS, but I'm not sure what fault(s) may be stored, if any.
    Jun 12 2014
    Tampa FL
    Quote Originally Posted by imnuts View Post
    I thought a dipped headlight fault is part of the level function.
    and that is what he said he is getting....anyway..yes check from the headlight plugs and follow back.
    VCDS will report each light that is not working.
    stuff like this:
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul USA 0305
    Coding: 00013
    Shop #: WSC 63351
    VCID: 3431E266B726FFE78F2-4B1E
    6 Faults Found:
    01494 - Bulb for Parking Lamps; Left (M1)
    57-00 - Electric Circuit Failure
    01498 - Bulb for Parking Lamps; Right (M3)
    01495 - Bulb for High-Beams; Left (M30)
    01499 - Bulb for High-Beams; Right (M32)
    01493 - Bulb for Blinkers; Front Left (M5)
    01497 - Bulb for Blinkers; Front Right (M7)
    I actually had all my lights fail and thought it must be the BCM.
    It was my lights..and months in the FL rain.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Dipped headlight is just Germanspeak for low beam. It has nothing to do with levelers.
    Jun 12 2014
    Tampa FL
    thanks.
    Jan 18 2010
    Fort Worth, TX
    Ah, that makes sense. Guess I'll start running wires. Any where that there would be common wiring since both went out nearly at the same time?
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    ya...your lowbeam light is having an issue.
    Sep 08 2016
    Grover Beach, CA
    @ shurur Yikes, i would have assumed the BCM too. All in one go!?!?!
    @old_guy yup, i have done extensive research on the dipped headlight and that was one of the first things i wish i would have learned. Just kept assuming that dipped meant movement on the autolevelers.
    @OP, So lights went out and you replaced with new bulbs and they are still out correct? Maybe its a relay?
    Jan 18 2010
    Fort Worth, TX
    Yes, bulbs didn't work. Don't know on electrical; haven't had time to run any electrical yet. I was able to find a wiring diagram that I think is for the A4 and will start work this weekend. Oh, I and I am very electrically challenged, so wish me luck. Can't drive the car to work since it's dark when I go and dark when i come home. The S5 is fun to drive though
    Jun 12 2014
    Tampa FL
    Use the pinout to the headlights and start checking back from there.
    The thread above has a connector diagram..Make sure to turn the light switch on...
    Jan 18 2010
    Fort Worth, TX
    Thanks for the diagram. Got the same thing on my FCM and was able to pinpoint fairly quickly. Will let you know how things go. My guess is no voltage a the connector since my hi beams don't work either.
    Jan 18 2010
    Fort Worth, TX
    Finally had time to do some troubleshooting and am looking for any pointers. Again, my low beams do not work and I have the dipped headlight fault on both, but all the rest of the my lights work including high beams (not this is a bit different than what I have said above).
    1) I started with the connector at the headlight unit and confirmed I do not have voltage at the connector on either side. Since the harness disappears into the firewall, I opted to go to 2)
    2) Using the wiring diagram I found here: http://www.vaglinks.com/Docs/Audi/B5...ingDiagram.pdf, I removed the headlight switch and measured the voltage for each position on the appropriate wire. The next stop was the CECM. When I disconnected the harness that goes to the lights, I measured the voltage from the pins on the CECM and measured 8 volts. Not sure if that is expected, but I get voltage. That along with 3) makes me think that I don't have a CECM issue. The harness then disappears into a 2 inch bundle of wires.
    3) I have run VAGCOM on the CECM and found no faults. Will also note that the green light symbol on my dash comes on, but it is unclear whether that light is in line with the actual headlight or a separate signal from the CECM.
    So i think it's obvious I am shorting out somewhere in the harness. Any hints on troubleshooting other than start digging? Does the harness just run through the firewall with no connectors?
    Jun 12 2014
    Tampa FL
    OK..First I would make doubly sure that the BCM module is coded for the low beam lights that you have.
    Halogen or HID.
    Then I might consider swapping in a used BCM ($)...maybe borrow a friends for troubleshooting..
    rev E... rev F works with the newer auto lights option and would probably need to be adapted.
    That 8v reading is a bit troubling...what signal or pin?
    Jun 12 2014
    Tampa FL
    Also..maybe put up a pic for us of that green light on the dash please...
    Jun 12 2014
    Tampa FL
    Green light may just be the hi beam...the turn signal and beam switch are also involved.
    Jan 18 2010
    Fort Worth, TX
    At work, so don't have access to the car, but the green light is the one between "EPC" and the blue high beam. Manual says it just indicates the headlights and side marker lights are on, so that is normal.
    Actually, 4 pins: numbers 16 (right low beam), 18 (left low beam), 22 (right high beam), and 23 (left high beam). All had 8 volts with it disconnected. So you are saying the module may be bad even though all the other lights work fine?
    Jan 24 2010
    Paramus,NJ USA
    Check for water in the comfort module.Also make sure the ebox isnt cracked.thats whwere they always leak water into the car.
    Ziddy Autowerks
    Jan 18 2010
    Fort Worth, TX
    Quote Originally Posted by EuroxS4 View Post
    If you mean the electronics module, there is none there. I have no evidence of water intrusion anywhere in the pillar area that might get to the Electronics Module.
    Jan 24 2010
    Paramus,NJ USA
    There is no water or no module??
    Ziddy Autowerks
    Established Member Two Rings ak0913's Avatar
    Mar 08 2017
    2003 Audi A4 1.8t Quattro, 2005 Mercedes C320 4Matic, 2006 Mitsubishi Raider V8.
    Sacramento, CA, USA
    Can it be the headlight switch?
    Jun 12 2014
    Tampa FL
    I don't recall my light connector voltages being that low.
    All were 11V+
    Jan 18 2010
    Fort Worth, TX
    I checked the switch and got 12 volts when in the on position.
    shurur9, you are talking at the Electronics module?
    Jun 12 2014
    Tampa FL
    Yup.
    I don't know the pin out of the BCM or what the 8V pin was.
    There are two connectors on that module.
    It seems like maybe your BCM is bad or the stalk switch.
    I don't have system schmatics in front of me.
    Jan 18 2010
    Fort Worth, TX
    Guess I will go check to see if I get 8 volts on the working circuits.
