Here is my winter project! After being tired of my K03, I have decided to go all out and install either a Precision 5558 ball bearing turbo or a Garrett GTX3582r. I will be installing the following parts to complete the setup
For the engine internals:
○ IE Rifle Drilled Rods
○ Wiseco 9.6:1 pistons
○ Clevite stock tolerance rod bearings
○ ARP main studs, head studs, and camshaft girdle (valve cover) bolts.
For everything else:
○ Cast log-style T3 manifold
• Depending on fitment, the turbine housing may come in contact with the motor mount bracket since the manifold places the turbo further back than the stock location. With that being
said, I can shave away at the motor mount bracket, or create or J pipe from the manifold so the turbo will be mounted on top.
○ While I have the engine disassembled, I am replacing all the gaskets, timing chains and guides, etc.
○ I am currently running ECS' Lufteknic Intercooler
○ Custom intake manifold with an integrated secondary fuel rail for port injection.
Fueling!
○ As we all know with our B8's, when it comes to high horsepower, the injectors we have will not cut it.
○ For the in tank pump; I have a walbro 450 E85 compatible pump.
○ upgraded HPFP
○ the injectors I plan to run will either be Opel or Bosch injectors, but these will only get me to +- 400whp (from what I have researched).
• with the port injection; I plan to run bosch style injectors, controlled by AEM's FIC. I will need to figure out what size injectors I will need.
○ I have the option to run W+M, but I have not decided on it.
Tuning!
○ Many people have recommended all sorts of tunes, and tuners. I will have to do my research, I would typically go to Mirza in NJ, but he seems to be AFK....
Turbo!
○ I am in between the two turbos
• both will be t3 in/4 bolt out, with a .64 turbine housing.
○ For the water and oil feed/return
• IE oil feed adapter (-4 AN)
• IE oil return (-10 AN)
• ATP banjo bolt and crush washers for the coolant return, 3/8 hose from coolant feed into the return on side of block. (Not needed on the PTE or Garret)
• AN lines and fittings
I will update the thread as parts come in!
