Results 1 to 19 of 19
    Nov 14 2014
    pnw
    battery replacement - coding needed?
    I think the OEM battery on our 2015 needs to be replaced (car will jumpstart and stay running but as soon as you turn it off it won't restart). Is any coding needed when changing out the battery?
    Nov 17 2014
    San Francisco, CA
    No, that is a dead battery. Is this the stock battery and is it 2-2.5 years old? If so, that's exactly when mine had to be replaced. Go get any aftermarket one as the dealership is a waste of money.
    Sent from my Pixel 2 XL using Tapatalk
    Nov 14 2014
    pnw
    Yes, stock battery. Any coding needed when changing it out?
    Nov 17 2014
    San Francisco, CA
    No, just change it out. The car will scream at you when you start it back up, but take it for a drive and it will clear the faults and fix itself.
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    I had asked the same question on another forum and was pointed to this helpful video => https://www.youtube.com/watch?time_c...&v=IJAScg6JrYI
    Yes - you DO need to code the car to the new battery. Unfortunately, it looks like we're pretty much stuck with an OE battery since the registration process expect to see certain batteries and characteristics.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Aug 24 2017
    CA
    If your car is still under warranty you can get it replaced at the dealer for free. (happened on my 2015)
    Nov 17 2014
    San Francisco, CA
    Quote Originally Posted by XMetal View Post
    That is for previous generations, the new 2015+ 8V mqbs do not need coding.
    Quote Originally Posted by Sushi View Post
    My dealership said they will only replace within 18 months of delivery as that is the battery warranty. I ended up being 2 months shy of the mark, which was maddening and $350 later.
    For reference, you can get a better aftermarket battery for less than 200. AutoZone, and the like, giving you lifetime warranties too.
    Established Member Two Rings Hard-Knocks's Avatar
    Jan 04 2017
    Raleigh, North Carolina
    Over the years, have found that Interstate Batteries
    make some of the best car batteries for the money and that Costco sell them for the best price. Often cheeper than AutoZone, WalMart, etc.
    Nov 02 2017
    CA
    Quote Originally Posted by mroberte View Post
    Care to share your source about 2015+ 8V MQB do not need coding?
    Do you drive with auto start/stop enabled? A new battery every 2 years or so is somewhat retarded, IMHO.
    Nov 17 2014
    San Francisco, CA
    My source is me, by changing the battery. Many others have also changed the battery to go smaller, which was my original intentions.
    The oem battery just sucks and seems to be a common problem (dealership also stated). I don't have start/stop on my model.
    Apr 11 2016
    US
    Only thing the service manual says when replacing the battery, other than the physical replacement of it:
    Procedure
    – Connect ⇒ Vehicle diagnostic tester.
    – Select Diagnosis mode and begin diagnosis.
    – Select Test plan tab.
    – Choose Select own test and select following options one after the other:
    ♦ Body
    ♦ Electrical system
    ♦ 01 - Self-diagnosis compatible systems
    ♦ 19 - Data bus diagnostic interface - J533
    ♦ 19 - Data bus diagnostic interface, functions
    ♦ 19 - Adaption
    ♦ 19 - Adapt battery
    The following measures are required after re-connecting the battery:
    ♦ Activate automatic open/close function of electric window regulators ⇒ Owner's Manual .
    ♦ Interrogate event memories of all control units and erase “Low voltage” entry ⇒ Vehicle diagnostic tester.
    Established Member Two Rings Z32drifter's Avatar
    Mar 04 2016
    94 300zx weekend/track toy
    Orlando. Fl
    Pre facelift cars do not have a battery monitor. 2017+ does require battery adaption.
    Established Member Two Rings Corners4kids's Avatar
    May 10 2016
    2019 Tiguan SEL Prem (wife)
    Centennial, CO
    No coding needed. Confirmed though installing a carbon battery cover and getting interrupted requiring me to leave battery off for hours. When you start the car again every single warning light comes on, every last one of them. Drive the car; all faults clear within 1 mile.
    Save the coin and swap it yourself. Dealership battery, wiper blade and tire costs are a joke.
    Aug 24 2017
    CA
    Huh, thats weird, I had mine replaced earlier this year without a problem (3 years+ after i bought the car new). Might depend on the dealer.
    Junior Member Two Rings
    Mar 13 2017
    CA
    I will do the coding after changing the battery (No matter FL or Pre FL). There is battery data stored somewhere in the car. Maybe 19 module on the A3's case. It can be done by using VCDS. I also has a dead battery 1 year ago. Mine was a 2015 that was built in early 2014. Dealer replaced FOC under warranty.
    Dec 25 2004
    Earth
    I just replaced my battery....used VCDS to clear all the codes produced by replacing the battery....
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by agpatel View Post
    Procedure
    ♦ Body
    ♦ Electrical system
    ♦ 19 - Adaption
    cool. ill try this. thanks for sharing.
    Dec 25 2004
    Earth
    Quote Originally Posted by Z32drifter View Post
    Good to know!
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
