Hi,
I'm hearing an annoying rattle coming from my rear passenger door while driving over bumps. It's not like something has broken off and is rattling around on the bottom. I know these cars are notorious for rattles, but this one just started recently. The other day I had my daughter drive the car while I sat in the back seat so I could isolate where it's coming from. I found that if I open the door while in motion, the rattle stops. I thought that maybe the locking mechanism isn't tight so I put some duct tape on the three sides of the metal piece that is screwed to the door jamb so the locking mechanism would have something wider to hold on to. While it might've helped a little bit, I don't think that's the solution, as the metal piece isn't worn at all. Maybe the mechanism inside the door needs to be replaced? I have it on my service order for when I bring the car in on Friday to have new tires put on, but I am wondering if anyone else has experienced something similar.
Thank you.
