Results 1 to 22 of 22
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Headliner repair
    Hey guys,
    For those of you who replaced their headliner. I am looking to replace the lining all together. I am also going to re wrap the A and C pillars as well. Is this the correct material to use? https://www.ebay.com/itm/Black-Alcan...53.m1438.l2649
    What kind of glue are you guys using. I tried to use some 3M headliner glue but it didn't work so well. But i think thats because my original headliner foam was shot and it wouldn't stick.
    How hard was the headliner to cover and glue? Or did you get someone professional to do it?
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    That should work. Remove all of the old glue from the previous headliner. Make sure you let the glue sit for a bit and tack up, maybe like 1 minute. Use something stronger for the edges.
    Sent from my Firefly phone.
    Feb 08 2006
    99 1.8T Passat, B6 S4 Noggy, RS6 01E Stg II Tune
    Columbia, Md; WPB, Fl
    That looks nice, I just might redo my sofa.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    I've used Performance Products Hi-Temp Spray adhesive, which is designed for headliners:
    https://www.rushinupholsterysupply.c...temp-adhesive/
    Last time I bought it, they had the lowest cost.
    For a sedan it's ~2.5 cans for the headliner depending on how heavy you spray. I'd get 4 cans to do headliner+pillars, maybe have a 5th can on hand if you plan to redo the rear deck shelf (assuming sedan).
    2001 Corvette (C5) Z06
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Definitely have to clean the old foam/glue off, it creates a huge mess. 1/8" foam backed material is what I used doing my A4 a few months ago. I redone the headliner, A pillars, large sections of the C pillars, rear deck and sunroof shade. I used flocking material for the B pillars, and small sections of the C pillars because the shapes were too awkward to wrap. The 3M 90 spray adhesive has held up well so far. Last page of my project thread shows the results http://www.audizine.com/forum/showth...4-Build/page11
    1998.5 A4 1.8TQM My Build
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Quote Originally Posted by chaos2984 View Post
    Hey guys,
    1st of you have to know if the material you are going to use is padded to not? can it stretch or not? total thickness of the fabric.
    the one that you posted looks like it doesn't stretch , and for the headliner you kinda need to fabric to stretch a bit in order to make a nice tight fit. only professional shops and tools can get away with non stretching material.
    I used this https://www.ebay.com/itm/Foam-Black-...3AMEBIDX%3AIT&
    _trksid=p2055119.m1438.l2649
    they also offer in oem style fabric
    GIAC-X, STASIS TS,VAST,034 MS
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by MetalMan View Post
    Jesus two and a half cans?for the rear deck and a pillars i used just 1/4 of 3m 80 that you get at home depo
    Jan 14 2009
    pasadena md
    what you use to clean the headliner. Just a scrapper or did you use a chemical as well?
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    I used a brass bristle brush and a rag. The foam just rolls up.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by Tiluleshpingen View Post
    I don't know how you applied that stuff, but with this stuff you spray both the fabric and the part you're wrapping. Also foam-backed fabric generally requires a little more adhesive than regular fabric.
    BTW this has been a pretty consistent quantity of adhesive I've used on the 2 B5's and B6 I've done this work on.
    Jan 20 2009
    B5 S4 Avant
    My friend scraped it all off with a snow shovel lol
    Nov 14 2006
    Land of the Eagles
    yes i applied both side ..but not too much as i tested on a small piece so the glue would seep thru the other side. remember the heavier the material the more glue you need or stronger, but if the material is too heavy and too much glue you either going to get a seeping finish or over time due to gravity the material will come apart again
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    With the stuff I used, it doesn't come out as liquid as 3M spray adhesive, it's a bit stringy. It will of course seep through if put on too heavy but is pretty forgiving in that department. Just gotta give it a few minutes to dry a bit and become tacky.
    Established Member Two Rings darren p.'s Avatar
    Nov 30 2015
    Mk2 GTI VR6 B5 S4 Avant E90 M3s
    Bumping this up to see how the various adhesives have held up over time? I don't have a compressor or spray gun but would be willing to get one if the DAP stuff is so much better than the Performance Hight Temp Trim Adhesive posted above. I REALLY don't want to have to take this headliner out again. Thanks!
    Veteran Member Three Rings harryn's Avatar
    Dec 03 2016
    2021 Audi A4, 2000 Audi S4, 1995 BMW M3
    Is it that big of a pain to remove the headliner and pillars? I can't find anything on YouTube on how to do this. But I read that you have to remove the windshield to get the headliner out????
    As far as headliner glue, I used 3M Super 90 on my BMWs to repair the headliner and pillars, and after 6 years, still holding strong!
    Veteran Member Three Rings S4tranquility's Avatar
    Dec 29 2005
    Baltimore
    Quote Originally Posted by harryn View Post
    You can get it out the trunk. There is a tech article on AW detailing how to do it.
    19 S4 Prestige & 17 Q7 Prestige.
    Former: Tesla P3D; 6MT 13 S4 (dual pulley); multiple B5 S4s
    B5 S4 120+ club; Sleeper, Stages, and more B5 S4 vids
    Dec 03 2016
    Quote Originally Posted by S4tranquility View Post
    Do you have a link? I haven't been on AudiWorld in ages!
    Dec 29 2005
    Baltimore
    Here as well... googled B5 headliner removal and found a few...
    https://www.audizine.com/forum/showt...ts-of-Pictures!
    Mar 19 2013
    Correct me if I'm wrong but I think it was mentioned somewhere that the way the service bulletin says to remove drivers seat out of car and r +r headliner via side doors?
    Dec 03 2016
    Well that was my problem, I was scouring YouTube instead of jumping on Google. LOL! Go ahead, flame away, I deserve it! :) Thanks!!
    By the way, I need to replace the fabric on my sunroof shuttle as well. Is that a big pain to remove? I know the top glass needs to come off, and from what I have felt at the junkyard, it can be a little heavy.
    2021 Audi A4 S-Line Premium Plus
    2000 Audi S4 6MT
    1995 BMW M3 5MT
    Dec 29 2005
    Baltimore
    The thread I linked includes the steps to remove the sunroof panel. It’s answered later in the thread.
    This thread has pics and discusses it as well:
    https://www.audizine.com/forum/showt...headliner-swap
    Dec 03 2016
    Oh wow, he removed the b pillars too? I heard they break just by looking at them. I haven't experienced this myself, but I have been tempted to go to the junkyard and test this out and see how brittle the b pillar is. On another DIY I saw, it says the b pillar removal is optional. What is a common method folks like to do? Break the b pillar or just try and finagle the headliner out of the b pillar?
    2000 Audi S4 6MT
    1995 BMW M3 5MT
