Thought I'd add this as a DIY since some folks seem to be going through this now.
Tools:
Torx screwdriver or bits for your wrench- primarily T25.
Small flat head screwdriver (for undoing some clips on the coolant reservoir)
Coil pack puller (Amazon has one made by Koch tools, KT20458, for $45)
Spark plugs- either OEM, or for those tuning their cars, you can also get 8 Denso (5346) IKH24 Iridium Power Spark plugs on Amazon for $70. These are one heat range colder than the OEM plugs.
Finally, it is handy to have a longer magnetic spark plug wrench adapter (I like the Ares 70045) that can go right onto your torque wrench. Amazon has it for $17.
Driver's side:
First, remove the torx bolts holding the coolant reservoir into place.
While you don't HAVE to completely remove the coolant reservoir, (there is enough 'play' in the hose that it is connected to that will allow for it to be simply pushed out of the way), if you want to remove it, there is a metal clip at the neck of the hose adapter that it is sitting in. Use a small screwdriver to pop off that clip (being careful not to lose it in the bowels of the engine), then you can take the coolant tank off of the hose and give you plenty of room to work. You don't need to drain all of the coolant from the system- you can siphon out the coolant from the reservoir, and you can also stop up the 2 lines going to the reservoir with some saran wrap and rubber bands. They pull out of the reservoir easily once you use a small screwdriver to gently lift up on the clips that are holding them in place.
There are 2 T-25 torx bolts holding the long plastic wire guide in place on either end. The small electrical connectors along the top with the gray tabs are easy- just pull the gray tabs to the 'out' position, and then press them towards their connector/cable, and they pull right out. The larger electrical connectors for the coil packs themselves have tabs that you can push in with a small screwdriver while pulling down on the connectors, and they come right out.
You don't need to completely remove the wire guide rail that covers the coil packs, you just need to be able to push it out of the way. There are also T-25 bolts holding each of the coil packs in place. Once you remove these, you can either gently pull on the coil packs to remove them, or you can use the coil pack pulling tool to do so.
While you CAN pull out the coils by hand, you need to be careful to provide steady and even pressure. It is not too hard to rip the top of the coil packs off of the rubber insulation tubes that go down to the spark plugs. The coil pack puller tool allows you to apply even pressure to the center of the coil packs to minimize the chance of damaging the packs. Some of them can actually be quite difficult to pull out without damaging, as Audi uses a silicone based sealant at the bottom of the rubber tubes to help ensure complete insulation of the spark plugs.
Once the coil packs are removed, go ahead and remove the spark plugs. When you place your new plugs, the torque specification from Audi is for 30nm.
Be sure to use either a diaelectric grease or silicone paste at the tips of your coil pack tubes to provide the best insulation you can for your spark plugs. When you replace, them, apply gentle but firm pressure by HAND to reseat them. The torque specifications for replacing the torx bolts is 9 nm.
Make sure you get all the electrical connections back into place. For the smaller ones with the gray clips, once you attach them, make sure you push the gray clips back down to the 'in' position.
The passenger side is a bit easier, as you can simply undo the hoses between your airbox and turbo inlets and remove the entire airbox by hand without any other tools.
The long plastic wire guide rail is also held in by 2 bolts on this side. The exact same electrical connections need to be removed as they were on the driver's side. All the other procedures from the driver's side apply.
Good luck! I'll try to add some pics to this post soon as well.
