2012 A4 FrontTrak
95,119 miles
CAEB Engine
No major oil consumption issues, just a top off every 1,000 - 1,500 miles or so. PCV Valve was replaced by Audi a while back. Car ran beautifully until the CEL.
Car still starts runs and drives (roughly) around a parking lot, I haven’t started it in a while just to make sure not to make anything worse than it already is.
CEL + EPC Light flashing while driving
Started to shake, pulled off to the side had it towed to Audi.
While waiting for the truck, I decided to poke around and found that the Cylinder 1 spark plug was covered in oil. I thought it was a bad injector, which is covered under the extended warranty, but this is what the report read:
“Internal Mechanical Failure in Cylinder 1, No Compression
Scanned Vehicle Misfire: Static Cylinder 1. Intermittent Cylinder 3
Swapped Coils and Plugs, Misfires still in same location.
Disconnected and performed compression testing.
Cylinder 1 - 30 PSI
Cylinder 2 ~ 160 PSI
Cylinder 3 ~ 160 PSI
Cylinder 4 ~ 160 PSI
Recommendations: Engine Failed, Cyl #1 Piston/Cylinder Damaged
New Audi Engine/Used Engine”
Cylinder 1 - 30 PSI
The head wasn't taken off during the diagnosis as far as I know, they just used a borescope to come to the conclusions. I'm looking to find out what options are out there:
-Rebuild?
-If it can be rebuilt, what parts can be saved/needs to be bought?
-Hours of labor - engine replacement
-Hours of labor - engine rebuild
I get that a ton will have to be done no doubt, it’s just really hard for me to wrap my head around the fact that the car needs an ENTIRE new engine, given that it still can start up and move around. I understand it’s not practical, but I’m looking for the best way to go about this in the most cost effective way. I am still making payments so my only choice is to get it back on the road as soon as possible.
I know there’s a ton of “shoulda, woulda, coulda” but at this point that literally does nothing so please, save it for somewhere else. Any insight, links to other threads/personal experience is greatly appreciated.
