Results 1 to 29 of 29
    Established Member Two Rings 2000Stg3S4's Avatar
    Jun 03 2015
    canada
    Bkr7eix spark plugs
    Does anyone recommend these for a stage 3 car ?
    Sent from my Nexus 6P using Audizine mobile app
    Apr 07 2011
    Home of the mighty beaver
    i run these with over 500whp. so yup!
    Jun 03 2015
    canada
    Quote Originally Posted by S4James View Post
    Thanks that's what I needed to hear, I'm nowhere near those power levels so should be good then
    Jul 04 2012
    Woodbridge, VA
    You can run these so you don't have to replace them every 10k miles over the bkr7e. Or run the cheap bkr7e and replace them every other oil chance.
    Jun 03 2015
    canada
    Quote Originally Posted by vavJETTAw36 View Post
    I'd rather not be replacing plugs every 10k lol
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Yeah I just switched from bkr7e to the bkr7eix. I was changing them out pretty much every oil change, every about 5k miles I started getting misfires in boost. Been running the ixs for only about 2k miles so we’ll see how they do
    I’m running ~450whp and 22psi
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I also run these on my stage 3 to avoid having to replace frequently (as opposed to the "regular" BKR7Es). No issues!
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 03 2015
    canada
    Did you guys have to gap them or they can't be gapped ?
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by 2000Stg3S4 View Post
    Gapped mine to .024”
    IG: CJ_s4
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    out of curiosity, what are you guys paying per plug?
    2000 Achat S4
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Looks like a little less than $6/piece on Rock Auto. I would just add them to an order I'm already making if they come from the same warehouse
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    You can gap them, just don't put pressure on the thin iridium tip.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Aug 24 2014
    Newport Beach, CA
    I have been running these for well for over a year, gapped to 0.028 with R8 coils and ICM delete. Have had no issues at 550+whp and they last infinitely longer than the copper NGKs. FYI my local O'Reilly's typically has the BKR7EIXs in stock.
    2024 M3 Comp xDrive
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by slow ride View Post
    Exactly, do it like this
    Jun 03 2015
    canada
    So which gap should I gap them to, some people gap to 0.028 some 0.024 ?
    Oct 27 2014
    Flag/Phx, AZ
    Depends on your ignition system. Im on stock coils/ICMs and I gapped to .024. I probably need to gap down to like .022 cause I still get a misfire every once in a while.
    If you have 2.0t/R8/RS6 coils and ICM delete, you can run a wider gap i.e. .026-.028
    IG: CJ_s4
    Jun 03 2015
    canada
    Quote Originally Posted by CJ_ View Post
    I got the 2.0t coils, so I can safely set it to 0.028 then
    Apr 07 2011
    the cheaper ones are nickel tip, copper core. No such thing as copper tip plugs.
    the iridiums are iridium tip, also copper core.
    This "copper" horseshit started when manufacturers figured out how to build them with solid copper cores instead of steel springs to improve conductivity, its never had anything to do with tip design or composition.
    bugs the shit out of me. the 7e and the 7e-ix are both "copper" plugs.
    oh and .026 on mine... upgraded coils
    Jun 03 2015
    canada
    So maybe I'll try 0.026 and go from there, shouldn't be a problem I guess
    Apr 07 2011
    no should be utterly fine. Ive pissed away hundreds on different plug setups and have come back to/sticking with these.
    Jun 03 2015
    canada
    Yeah I was thinking they can't be that bad despite people preaching about regular coppers being superior plugs
    Feb 19 2011
    Earth
    Quote Originally Posted by redline380 View Post
    cant seem to find them on rockauto from searching just by 'Bkr7eix' or under NGK.
    2000 Achat S4
    Jun 03 2015
    canada
    Quote Originally Posted by jaychen View Post
    Try Amazon
    Jun 03 2015
    canada
    Got mine for 94 cdn shipped
    Aug 24 2014
    Newport Beach, CA
    I got mine from this Amazon seller for the past 2 years, very quick shipping and I just order 3 boxes at a time to have a new set waiting.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2024 M3 Comp xDrive
    Apr 07 2011
    Anyone that says this, (usually coupled with "because copper is a better conductor") is a either a putz who doesn't know shit about spark plugs and is just pulling nonsense out of his ass, or is a putz who is just parroting the first putz because he doesn't know any better.
    Feb 19 2011
    Earth
    Quote Originally Posted by christianb5s4 View Post
    Thanks man. Not often amazon sellers ship down here.
    2000 Achat S4
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You need to search under the "parts search" tab, not the box on top. They are NGK 2667 on rock auto
    http://www.rockauto.com/en/moreinfo....532817&jsn=253
    2000 S4- Working?
    Registered User Four Rings
    Sep 01 2013
    Sweden
    Really good plug for high boost applicatios is Bosch F3CS. It handels my 36psi and std coils. It is also silver so in case it fails it just melts and doesnt take the piston with it.
    I recommend and install them in all cars i work with.
    It is cheap as well.
