Page 1 of 3 123 LastLast
Results 1 to 40 of 84
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Brake Review: Hawk HPS 5.0
    Had these for about 4 months now. Just saw another post on brake reviews and it reminded me to post my review.
    Overall: not thrilled. The loss in initial bite compared to stock is drastic and almost dramatic. After leaving the shop - I could have almost got in a wreck cause I started stopping too late (my fault, I knew this was coming).
    Dusting: better than OEM but not even close to zero. I still get a fair amount of dusting on my front wheels. I wash my car ~2x per week and I've also got noticable dust on front wheels.
    Performance: "fine" but not awesome. It's suitable but nothing remarkable.
    I purchased these based on some strong recommendations on Audizine and in heinsight, I wish I would have tried the Akebono's instead since I still lose a lot of the initial bite of the OEM pads but as I've read, almost zero dusting.
    Overall: fine, not great. Dusting is better, not perfect, performance is good not great and the initial bite (as with most of the similar pads) is noticeable for the first ~ week of driving after going away from OEM's.
    Grade: B-
    '18 S5 - BBS / EPL
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    I want a pad that bites hard and performs well but has no dust. Best of both don't seem quite possibly
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Sadly that's the trade off dust and bite go hand in hand. My stoptechs are along about the same description, no wear near the same bite as OEM (which i actually prefer). These pads were next on my list to try but might have to say screw it and go back to the OEM pads (for the front anyways)
    I had a new C300 Merc as a rental for a week, insanely grabby brakes as well. First drive back in the S4, nearly crashed a couple times adjusting to the brake differences.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Apr 04 2012
    MSP
    For what it's worth - I decided to try out Hawk Performance Ceramic pads on my S2000.
    Now - I also upgraded my lines to SS lines as well as my rotors to Stoptech disks. Plus I installed a master brake cylinder brace to eliminate deflection... The initial bite and overall stopping performance and pedal feel is remarkable now. I'm sure it's not all pad but given those pads are part of the equation I'm quite happy with them.
    They dust I'd say 25% compared to whatever pads were on the car before. I wish they dusted less.
    I used to run Akebono pads on my S4 - 0 dust but as mentioned very reduced initial bite until you got some good heat in them which is hard to do during the winter or in just regular driving. In the Cold wet winter they really were scary with 0 initial bite.
    I have since changed them out to EBC RedStuff pads. They are also virtually 0 on dust but have a much much better initial bite. I'm only running them on the front on my S4 and still have the Akebonos on the rear and will swap over to them when I need new pads on the rear. I'll keep running them on the front. You may want to try those...
    I may switch over to those pads on my S2000 as well when the time comes for new.
    May 07 2016
    Quote Originally Posted by MrFunk View Post
    Hoping the Red Stuff is a good trade off..
    One thing I failed to mention - I initially did brakes to get rid of the squealing from the OEMs at cold.. That is gone with the Hawk 5.0s
    '18 S5 - BBS / EPL
    Oct 30 2012
    Oxford, MS
    The problem I've found with the 5.0 pad is that they don't work very well cold. Luckily, that hasn't been that big of a deal where I live. But I've visited family further north and on a cold, wet morning I had some serious pucker coming into my first red stoplight. I like them better than Hawk HPS once they're warmed up a bit.
    Aug 08 2016
    Oshkosh, WI
    I am in Wisconsin and have had good results with the hawk pads and ecs rotors. I also did ecs stainless lines, so maybe that was the money in the upgrade. but overall happy and less dust
    2013 S4 monsoon gray. EPL DP (fluidampr 183). Milltek exhaust, rotiform wheels, KW variant 1 coilovers, PLM HE, 034 alu kruez, 034 motormounts, trans, diff mounts. solowerks rear swaybar, CR-15 brace, roc-euro intake, rs grille etc. And 2 Land Cruisers
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Thanks for this 3 days after I ordered these pads. Lol
    Feb 20 2014
    Rochester, New York
    I have the hawk 5.0’s as well. I hated them for the first 100 +/- miles, re-bed and loved them since. They do not have the initial bite as oem but have a very linear, and predictable, increase in bite. Better than most, and the dusting is lower.
    May 07 2016
    Quote Originally Posted by theweebabyseamus View Post
    Sorry homie! I thought you were selling the car after the nut blasting incident?
    They aren’t bad. Just not amazing. B- isn’t awful. Just no A+
    Sent from my
    '18 S5 - BBS / EPL
    May 07 2016
    Quote Originally Posted by lopott View Post
    I’m probably the same. A lot less dust than OEM. Brake performance is fine. Doesn’t put your face through the windshield but work well at high speeds.
    Sent from my
    '18 S5 - BBS / EPL
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    Quote Originally Posted by chilort View Post
    Quote Originally Posted by BKE View Post
    Guys , you would not need to find it . Just look at the specification http://www.hawkperformance.com/stree...nd-application : optimal temp range 100°- 550°.
    It's obvious that they will not work well when they cold.
    +100
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
    Jan 24 2017
    Quote Originally Posted by JD S4 View Post
    People recommend Hawk HPS 5.0 because they have really good performance for everyday driving and you can use them for autocross events, BUT !!!! if you really want to get max performance from them you need to have proper (I mean good) rotors with SS lines and brake fluid(example Motul RBF600). As well , you need to follow a bleeding process to make pads works with max performance.
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    I had the Hawks on my BMW...ditto on the dust and they eat rotors
    Akeebono's just installed on the S4. I will take the less dust all day every day. I don't drive like a madman so they seem perfectly suitable to me
    BMW M850i
    Nov 18 2014
    Quote Originally Posted by fmzip View Post
    I absolutely drive like a madman, so strong pads / good bite please! 😂😋
    Aug 21 2017
    Quote Originally Posted by s42014DSG View Post
    It's useful for people to know you're driving habits/age for decisions like this. I'd want the same as you posted in my 30's, different story in my early 50's. Dustless pads didn't exist back then for me though ;)
    BMW M850i
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Not sure but I didn’t see you mention bedding in pads? That’s a must with any new pads whether stock or aftermarket.
    My .02 cents
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by Strong Man View Post
    Lots of pads give 100 as the starting point for their temp range. I think the 5.0 is just a bit more serious about this specification.
    Senior Member Two Rings steampunkjunker's Avatar
    Jun 21 2017
    NorCal
    Cold bite is next to worthless. The stock pads have this and nothing else, plus dust, plus squeal, and lack a high frictional coefficient at any reasonable temperature.
    The magic unicorn pad is the a Endless MX-72. you get them for nearly half price from Nengun in Japan. But my guess is most people looking at Hawk or StopTech wouldn’t pay the premium for these pads.
    Do Endless MX-72 pads, good fluid such Endless RF-650 or even Ate, TyrolSport Solid front caliper bushings, braided steel brake lines, and StopTech (solid or slotted) rotors - I did cryo on the front and you’re going to have the best brakes possible with stock calipers. These pads will grab fine with the first stop yet still have modulation for positioning in parking spots, low dust, no squeal, and face ripping frictional coefficient when hot, plus excellent pad and rotor wear. A+ Much better upgrade than a tune...
    Junker’s 2013 B8.5 S4
    • Suspension: H&R ARBs, CR-15, H&R 10/12mm wheel spacers
    • Braking: Endless MX-72 & RF-650 fluid, StopTech cryo slotted rotors, Tyrolsport brake lines & caliper bushings
    • Motor: GIAC - Stage 2, Redline oil
    • Coming soon: GIAC - TCU, Bilstein B12 Pro-Kit
    Jan 24 2017
    Quote Originally Posted by steampunkjunker View Post
    Cold bite is next to worthless. The stock pads have this and nothing else, plus noise, plus squeal, and lack a high frictional coefficient at any reasonable temperature.
    You've just repeated exactly what I told a few posts before.
    Jun 21 2017
    NorCal
    The Truth! The TyrolSport caliper bushings are just as good as they were on my MkV GTI. The smooth and even pad and rotor wear I think is from these... plus better pedal feel. ;)
    May 07 2016
    Quote Originally Posted by RWD2quattro View Post
    My .02 cents
    I bedded mine. Should have mentioned
    Sent from my
    '18 S5 - BBS / EPL
    Established Member Two Rings 2013S4's Avatar
    May 20 2017
    NW Indiana
    The first day with the hawk pads are a big difference. But once bedded, I really like the more linear braking and my wheels stay much cleaner.
    Sent from my SM-G920T using Audizine mobile app
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    scheming this thread, i guess its safe to say stick with OEMs
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Grade: B-
    I've had a completely opposite experience. Obviously the bite was far worse than OEM when they were bedding in, but it improved dramatically after a couple hundred miles. Still a little less than OEM, but I like that because IMO the OEM pads have far too much initial bite and aren't linear at all.
    I have no problems with cold stopping performance and they dust far less than OEM. It helps to mention what rotors you run. If you are running a slotted rotor, that will cause far more dusting. I'm running OEM spec Zimmerman rotors. The other massive benefit over OEM is that the HPS 5.0s are SILENT.
    The really moneymaker though is their performance during repeated high speed stops. I've seen no fade at all slowing from nearly 150mph during a 1/2 mile airstrip event. That was not the case with OEMs.
    You say performance is "fine". How hard do you drive and do you do any drag racing or road course laps? To truly speak on the performance of these pads, it's probably good to have done a good amount of high speed or repeated stops.
    Sounds like the Akebono Ceramics would have been a better idea for your driving style.
    - - - Updated - - -
    Quote Originally Posted by JeriQo View Post
    That's what you got from this?? lol
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jul 08 2015
    Quote Originally Posted by Vogz View Post
    theres alot of mixed opinions.
    Jun 29 2015
    Danbury, CT
    I can pretty much echo everything said in here. I love my HPS 5.0 pads over stock. Way less dust, linear braking, and I felt improved performance.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    My Q5 is too new for pad replacement, but I've used Hawk HPS pads on several other applications and really like them.
    One of the things I disliked about OEM pads on those other applications (all performance cars) was that the initial "bite" was misleading because too much braking force was at the beginning and the remaining force was not linear.
    HPS pads provide a very progressive, linear increase in stopping power as you increase pressure, directly in proportion to the amount of force applied. This may take a few miles to acclimate to the linear braking force, but it is much better to know that pedal pressure increase means something predictable and repeatable. They also don't fade as much in repeated high speed braking.
    The added bonus is less dust. I don't buy them for the lower dust. I get them because I think performance oriented cars need linear brakes and less fade.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    True, but absolutely no one is recommending the OEM pads.
    If you beat on your brakes at all, buy the HPS 5.0s. If you don't buy Akebono Ceramics.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by MSq5 View Post
    My Q5 is too new for pad replacement, but I've use Hawk HPS pads on several other applications and really like them.
    Couldn't have said it better myself.
    May 07 2016
    Quote Originally Posted by amusante View Post
    This is probably an accurate assumption.
    "Less" dust (not zero), improved performance/linear braking and less squeaks..
    '18 S5 - BBS / EPL
    Jun 21 2017
    NorCal
    Exactly. People in these threads keep acting like “cold bite”is a good thing. Stock pads are totally bipolar at very low speeds like when parking. They are nearly impossible to modulate. And then they have no bite when slowing down from faster speeds. And they squeal and dust like crazy to add insult to injury. No thanks!
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Their website only shows them for the TT RS?
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Jun 21 2017
    NorCal
    Quote Originally Posted by Whitee View Post
    Check EndlessUSA under MX-72 and click the euro applications button and get the front and rear part number.
    Then you just ask Nengun for the price and they will post it to the website. You can just buy from there but confirm the front and rear EIP part numbers look okay.
    GMG uses those on all of their customers 911... and they used an Endless race compound on their ALMS cars.
    Jun 21 2017
    NorCal
    GMG uses those on all of the 911 Cup cars... and they used an Endless race compound on their ALMS cars.
    Jun 21 2017
    NorCal
    https://youtu.be/QGhZVGDGh6c
    Mar 14 2016
    TheFarEast
    quick qns, are these pads in any way "grabby"?
    thats what i hated with regards to the stock pads.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I'm going with the Endless pads on my 996 Turbo when I need brakes.
    Jun 21 2017
    NorCal
    There’s also an MXRS compound which is basically an MX-72 with a little additional high temp stability - slightly more track friendly. I couldn’t get Nengun to order my pads in that compound because it’s probably a custom pour but just FYI. There’s also an awesome endurance pad that everyone uses at the 24h of Nurburgring (MA45?) but I think something like that would be the same situation and more expensive. I’ll start another thread on these sometime and not clutter this thread, but the whole reason I switched out Hawk HPS back in the day in my GTI was because I was barely able to stop with my foot in the floor coming up on an accident on the 5 at night in SoCal. I’d never sacrifice anything with regards to braking capabilities... especially when no one will allow a safety cushion anymore and all of the lane changes without indicators etc. For me it’s brakes then suspension then power last... especially with a 4000 pound car.
    Jun 21 2017
    NorCal
    Quote Originally Posted by ReDeViL View Post
    They are relatively high mu (frictional coefficient) once warm for such a heavy vehicle and cold they stop stockish but without the gum eraser grabbiness.
    The complete lack of slow, cold modulation was a deal breaker for me with OEM pads. I could barely inch my car forward in my parking spot and was always concerned I’d end up bumping into something. The stock pads must be set up to be compatible with Canadian and Nordic winters or something.
